DIY Auto Mechanics Can Save You BIG Money
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timmah!, Jan 20, 2020.
  1. Jan 21, 2020 at 5:48 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I work on ships, Drilling out broken stainless steel bolts and trying to extract them with easy outs are from the devil!!!
  2. Jan 21, 2020 at 6:07 AM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    No need to remove tire just turn it for more room. It can be a pain to get off if it gets slightly over tightened.
    Honestly you’re not saving much by changing your own oil. Cost me about $30 to do it myself. I’ve just always enjoyed doing it and it gives you a chance to crawl under your truck and see what’s going on down there.
    GQ7227[QUOTED] likes this.
  3. Jan 21, 2020 at 6:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    another FYI is when you take off the old filter it contains almost 1/2 quart of old oil and to try to keep it upright as much as possible when pulling it out of the wheelwell, which takes some practice because basically you can only use 1 hand to unscrew then pull out thru the hole, if you dump it you'll have a big mess to clean up:frusty:. the more you do it the better you'll get, like an Indy pit crew.
    GQ7227 and Sreppep[QUOTED] like this.
  4. Jan 21, 2020 at 6:34 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    $30 is reasonable, its just that these dealers are starting to say $50 is a 'good deal' for non-synthetic oil, at that price I am needing to do the cost/benefit analysis, if i was equipped with a walk underneath open pit like I had access to and changed my own oil in the early 90s working at the quickLube on my old used car i would probably be doing it myself, its just laborious having to remove the skid plate which i thought was the only way to do the work and struggling to crawl underneath at my age and health issues is an added tax to consider
    QMEDJoe likes this.
  5. Jan 21, 2020 at 6:38 AM
    QMEDJoe
    Joe
    It’s funny how age factors in. I was going to replace my rear o2 sensor this morning and my lower back said “oh no your not!” :D
    GQ7227[QUOTED] and BillsSR5 like this.
  6. Jan 21, 2020 at 6:42 AM
    BillsSR5
    bill
    2014 SR5
    If you plan on trying the oil change yourself I would suggest before draining the oil to try unclipping the mud guard reaching in the hole to see if you would be able to unscrew and remove it safely, I have very very very long arms and from a squatting position could barely reach the filter unscrew it and then replace it in reverse. if you have medical conditions this could be very compromising to do. it might be best to remove the skid plate(royal big pain in the ass) or take it in to a garage to have it done.
  7. Jan 21, 2020 at 6:54 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    there is a local DIY garage rental lift in my town that is $40 an hour, i just used it yesterday to rack up a $70 charge to get out of 0 degree F weather! and do some needed emergency frame work.
    i could spend hours underneath that lift inspecting & checking everything out and rack up a rental bill in the multi-hundreds of $$$ very quick!
  8. Jan 21, 2020 at 6:58 AM
    BillsSR5
    bill
    2014 SR5
    $40 per hour plus the cost of needed supplies in 0 degrees weather doesn't add up, I would find a garage running a Oil change deal for the same amount of money, especially if your medically compromised and have never done the oil change before, try it yourself when summer comes. I would scan the web find a good oil deal
  9. Jan 21, 2020 at 7:04 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    I get free oil changes as long as I own it, I gave up on the other stuff when I looked under the hood of my 2002 Tundra but I do keep my 4 lawn mowers serviced and running ( 2 at my house, 2 at moms house)
  10. Jan 21, 2020 at 7:07 AM
    BillsSR5
    bill
    2014 SR5
    only problem is these days those oil change places don't grease the driveline which is a good idea at the time of the oil change, guess you could roll under with your own grease gun tho, never understood why they dropped that service
    QMEDJoe and GQ7227 like this.
  11. Jan 21, 2020 at 7:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, i only found that out recently that i now have to make a 'special request' to lube the driveline at the dealer service dept. so far they have not added an extra fee which when they do i will get most grumpy and give them an ear full of their genuine Toyota care service. So i crawled underneath the next day to inspect it and found they even missed one or two zerks
  12. Jan 21, 2020 at 7:20 AM
    QMEDJoe
    Joe
    Tried to do that yesterday to my buddy’s kids 3rd gen 4Runner and I couldn’t get my grease gun to prime. ...brand new tube of red and tacky in there :mad:
    GQ7227 and BillsSR5[QUOTED] like this.
  13. Jan 21, 2020 at 7:29 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Interesting topic. Not really about how to change oil and filter ..... I had no dad to teach me . Mothers car kept breaking starter motors because they were not installed properly. (no shims (gm product) to adjust contact with ring gear on driving vane..) So I had autoshop in high school and decided to change the starter myself.... From the ages of 16 to 57 been doing my own stuff except for air conditioning charging and some front end alignment stuff. Got a lot to show for it in terms of saving thousands $ . Taught my son a lot of stuff and he just graduated with a degree in high performance motorsports...... Yes some people think I'm nuts for spending so much time fixing my own cars and trucks... but they don't see my bank account..... Plus there is some satisfaction - a lot of satisfaction and it meets my need (everyone has this need) for self actualization.
  14. Jan 21, 2020 at 7:52 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    The economics of wrenching on my own vehicles is definitely a motivator to learn. To me it's also just fun.
    Cost wise if I tally up the total dollars spent on my truck...everything from the truck itself, oil changes, tires, wheels, flatbed camper, 2nd gas tank, dual batteries I've still spent less than buying a stock 3rd gen. If you add in my daily driver now your talking a modded 3rd gen which, compared to my truck as it sits, I don't see as a good value.
    This all because I do about 95% of mine own work.
    Edit: Add in timing belt, replaced the whole AC system, carrier bearing, tundra brakes, replace all the suspension including bushings. I've saved tens of thousands of dollars probably.
    Timmah![OP] likes this.
  15. Jan 21, 2020 at 7:55 AM
    #35
    BillsSR5
    bill
    2014 SR5
    you can get one of these mini grease guns at harbor freight with a discount coupon, they also sell refill cartridges and a flexable hose attachment, doesn't cost much with a coupon, doesn't take up a lot of space
  16. Jan 21, 2020 at 7:59 AM
    #36
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lmfaooooo where have you been :rofl::rofl::rofl:
    :D:D:D
    Itchyfeet[QUOTED] likes this.
  17. Jan 21, 2020 at 8:01 AM
    #37
    BillsSR5
    bill
    2014 SR5
  18. Jan 21, 2020 at 8:06 AM
    #38
    BillsSR5
    bill
    2014 SR5
  19. Jan 21, 2020 at 8:10 AM
    #39
    Fishnwiz
    Bill
    It will be at the dealership, I’d hope they would but I’ll be sure to ask and check. I’ll watch them from the window a time or two
    BillsSR5[QUOTED] likes this.
  20. Jan 21, 2020 at 8:11 AM
    #40
    BillsSR5
    bill
    2014 SR5
    another guy said they will do it on request with an extra charge:spending:>the Stealership
