DIY AUX Input in 05+ Stock Head Unit that overrides FM
Discussion in 'Audio & Video' started by pscrev20, Jul 2, 2012.
  1. Aug 8, 2012 at 5:00 PM
    pscrev20
    pscrev20 [OP] Member
    Philip
    Shenandoah Valley of VA
    05 Taco Double Cab
    AUX jack in stock radio, overtakes FM.
    The issue is not the ground... It has to do with the way the DSP chip inthe radio amplifies sound. It basically amplifies the sound that is the loudest. on the input, so if the CD you have playing has loud music on it, it could overide, even just slightly, your jack you have soldered in. Another method would be to de-solder the wires from the CD contact and use a jack like I've listed above with a 4 conductor cable. This would then disconnect the audio coming from the CD player so that it cannot bleed through.
  2. Aug 8, 2012 at 5:06 PM
    pscrev20
    Philip
    05 Taco Double Cab
    Not a bad idea, but I guess that the title of this thread is a little miss-leading. This mod overrides all tuner capabilities, FM and AM. Since the DSP uses 1 input for the Tuner and that is where I tapped in, it doesn't matter if you are on FM1, FM2, or AM this mod will override it. To do what you are asking, you would have to figure out how to tap into/re-program the tuner chip and don't believe it can be easily done.
  3. Oct 8, 2012 at 2:05 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Has this mod been tried on the jbl units?
  4. Oct 11, 2012 at 12:50 PM
    pscrev20
    Philip
    05 Taco Double Cab
  5. Nov 13, 2012 at 2:35 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    Can anyone tell me the amount of resistance the two resistors have? I messed up one of mine, and need to know what to replace it with. ASAP please!
  6. Nov 14, 2012 at 1:32 PM
    pscrev20
    Philip
    05 Taco Double Cab
    Someone else had the same issue. I believe that they are not actually resistors but filtering capacitors. I would try to get 2 2.2uf bi-polar capacitors from RadioShack and see if that will work for you. I had one PM that the person tried resisters and could not get any volume. Seems like they would be filtering caps to me at that point. Let me know if that works.
  7. Nov 15, 2012 at 7:46 PM
    RCOTaco
    Dalton
    Hamlet, NC
    Worked like a charm man! You're a lifesaver! Thank you!
  8. Jan 6, 2013 at 12:47 PM
    Soylent17
    Soylent17 New Member
    I would suggest adding a switch (button) to the circuit that can disable aux input without having to unplug your device. Pretty simple addition that would add convenience.
  9. Jan 7, 2013 at 1:52 PM
    gtrplr
    gtrplr Member
    Chachi
    Vancouver, wa
    05 SR5 4x4
    3" revtek front, 1.5 aal trailmaster rear, 265 70R16 Toyos, K&N filter, rubber between rear springs.
    Excellent idea!
  10. Jan 24, 2013 at 4:43 PM
    papercuts
    papercuts Member
    leesburg ga
    07 prerunner SR5 TRD
    Would the numbers be the same for the solder points on a Jbl unit. I finally found r256/255 and r355/356. Watya think.
  11. Jan 26, 2013 at 3:58 AM
    pscrev20
    Philip
    05 Taco Double Cab
    Really hard to tell. The JBL unit may use a different DSP Chip and if it does, then inputs may be in a different place. Look around on your board and make a note of the numbers on any chips like the one pictured in mine. Look them up on Google and you will probably find a wiring diagram with all the inputs and outputs. That's how I located mine.
  12. Jan 27, 2013 at 6:42 AM
    papercuts
    papercuts Member
    leesburg ga
    I found them but i already did the cd player mod. Much easier to do. I still messed up though. Lol. I dont have sound outa my left side while listening to a cd but thru the aux input it works just fine. Lol. I had an issue gettin the solder to stick on the left pin. But i got it to stay eventually. Lol. I dont need the cd player anymore anyways.
  13. Jan 30, 2013 at 4:31 PM
    dork18
    dork18 New Member
    Gregory
    Los Angeles
    2006 Pre runner SR5 4X2
    i broke a cap. so i was wondering if the polarity is important while installing the cap. please i need a reply asap thanks.:)
  14. Feb 1, 2013 at 9:03 AM
    pscrev20
    Philip
    05 Taco Double Cab
    The replacement capacitors I listed should be non-polarized, so it should not matter. If the Cap you have has a - or + listed on it, it is probably the wrong one.
  15. Feb 25, 2013 at 7:03 PM
    #35
    Ludo
    Ludo Member
    Houston, TX
    06 Prerunner
    What does the screen on the radio look like when you are using the fm aux mod?
  16. Mar 13, 2013 at 10:19 PM
    #36
    OneJay
    OneJay that non tacoma guy
    Brian
    Blackhawke's big spoon
    No tacoma. :(
    Ok, I need some suggestions, because I'm having a few issues. I followed these instructions on this thread, but with nothing plugged into the AUX, the radio plays only out of the drivers side speakers. When I plug the cable into the AUX, the sound comes out of both sides, and when I plug my ipod in, the radio stops, but I cannot hear the ipod music. The entire time, there is a high pitched whining static noise.
    Any help or suggestions would be fantastic. I'm kind of a newb at audio stuff. Thanks!
  17. Mar 14, 2013 at 3:35 AM
    #37
    papercuts
    papercuts Member
    leesburg ga
    Not really sure it can be fixed. I did the same thing to mine but i did the cd player aux. u can mess with the aux plug while the radio is playng and ground the aux out and u will get sound outta both speakers. But that would take some playing around with and is a hassle. Maybe u can call some repair shop that deals with this kinda stuff and see if they can help. Luckily it doesnt bother me becuase i listen solely to my iphone when in my truck.
  18. Mar 14, 2013 at 10:54 AM
    #38
    OneJay
    Brian
    No tacoma. :(
    Hmm, ya it's pretty confusing. I removed the wires from the circuit board, and now the radio works just like it did before. Maybe my soldering skills just aren't up to par. The connections in there are a LOT smaller than I thought they'd be.
  19. Mar 15, 2013 at 8:14 PM
    #39
    pscrev20
    Philip
    05 Taco Double Cab
    The contacts you attach to are very small and it is easy to either over-solder them or under-solder them. I messed up the 1st time but was able to repair it and still make it work with the AUX jack installed. Helps to use a fine solder and a low wattage/small solder iron (not a solder gun as they are way to big for this).
  20. Mar 22, 2013 at 11:24 PM
    #40
    casper3t
    casper3t New Member
    UPDATE 1-26-2013: The resistors listed below are actually Capacitors. If you mess one up, simply go to RadioShack and purchase some 2.2uf bipolar capacitors to replace. Make sure you replace both, not just one.
    Do you have a picture of the caps you bought? I couldn't find any surface mount ones.
