DIY BackRack/Headache Rack cheap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrbadwrench, Jul 22, 2010.
  1. Jul 22, 2010 at 3:28 PM
    mrbadwrench
    mrbadwrench [OP] Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Needed some cheap insurance on the back window of the truck - thems windows ain't cheap!
    This cost me nothing, materials laying around were used. Should take you about 15 minutes, not including paint drying time.
    STEP 1:
    Jack up your vehicle. You'll need easy access to the underside of the bed. I used a Cat TH560B (*If one of those isn't available, you can substitute an SUV jack*).
    SAFETY NOTICE: If you use your telehandler or forklift to lift your truck, only lift one side at a time, even if you have 60 inch forks and can span the whole frame - Keep 2 wheels on the ground for safety! Also, watch out for your door mirror - the fork carriage can hit it. Ask me how I know!
    Correct lifting point for forks:
    Watch door mirror:
    STEP 2:
    Get your materials. I used predrilled angle galvanized steel I had laying around.
    STEP 3:
    Get some bolts
    STEP 4:
    Get an angle grinder with cutoff wheel, and a power drill. Bench grinder also helpful.
    STEP 5:
    Cut your materials, and wipe down with Acetone if you are going to paint them. Ya want yer paint ta stick!
    STEP 6:
    Install outer frame. Use bolts with washers on your bed rail. Get everything straight and level. Loosely tighten bolts.
    STEP 7:
    Cut some angle brackets from your angle material, and bolt your frame to the bed floor. You'll have to drill holes.
    STEP 8:
    Install mesh or grill. I used wire shelving from the hardware store. Good sturdy stuff and easy to cut up. Now you're done!
    Best regards from the farm.
  2. Jul 22, 2010 at 3:39 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    You might be a Red Neck... when you use a forklift to jack your truck up!
    Damn, I wish I lived on a farm!
  3. Jul 22, 2010 at 3:48 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Doesn't quite have that OEM touch .. lol but awesome if you need it!
    I wish I had a forklift ...
  4. Jul 22, 2010 at 3:50 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    props for you. it dont look too pretty but it gets the job done!
  5. Jul 22, 2010 at 4:13 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Hey the price is right and it does what it's supposed to do. Good job !:)
  6. Jul 22, 2010 at 4:13 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    x2
    and the forklift lift
  7. Jul 22, 2010 at 5:31 PM
    chaztoyo
    chaztoyo Well-Known Member
    Chaz
    West TN
    10 Tacoma DCSB TRD Sport White
    Love the forklift. Nothing quite like making do with what you have.
    Sometimes I think that's a forgotten talent. Now most folks seem to think they have to go to Wally world to get everything.
  8. Jul 22, 2010 at 5:33 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    For a work truck its perfect
  9. Jul 22, 2010 at 5:57 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Congrats , I think ?
  10. Jul 23, 2010 at 9:46 AM
    mrbadwrench
    Cleveland Ohio area
    Couldn't agree more. Always been a fan of using floatsom and jetsom to build what I need, when possible. Reduces landfill waste and saves enormous amounts of money, so you can spend that money on other things! :cool:
