DIY: Badge Removal/Painting/Installation
Discussion in 'Detailing' started by mgage10, Jun 13, 2010.
  1. Jan 18, 2014 at 5:00 PM
    #281
    Lindsey Walrod
    Lindsey Walrod Well-Known Member
    Lindsey
    Oregon
    '13 black beauty
    Just what I needed!
    69TACO16 likes this.
  2. Jan 18, 2014 at 5:12 PM
    #282
    Lindsey Walrod
    Lindsey
    Oregon
    '13 black beauty
    Imma go for plum crazy purple on my badges! Will putting purple over black make the purple darker? That's what I'm going for.
  3. Feb 20, 2014 at 6:34 PM
    #283
    TacoSupreme07
    TacoSupreme07 Member
    Tyler
    Bradenton FL
    07 TRD Off Road Superwhite
    2.5" level, BHLM, 2011 superwhite sport grille, blacked out emblems, Pioneer double din HU, Cobra CB+ PA system, debadged all but 'TACOMA'
    I know what im doing this weekend...
  4. Apr 9, 2014 at 8:52 PM
    #284
    Esckay
    Esckay Well-Known Member
    Sean
    Whale's Vagina
    2013 TRD Sport 4WD DCLB
    OME 885s, Dakars, 30" LED bar, G4 elite, auto pop n lock to pd, tint
    Sub'd
  5. Apr 29, 2014 at 6:25 PM
    #285
    brandaves
    brandaves Member
    Brandon
    EVERYWHERE
    12' SR5 DCSB 4X4
    Now that is murder!:D
  6. Jul 6, 2014 at 6:06 AM
    #286
    KDOG
    KDOG Well-Known Member
    Belleplain, NJ
    Bilsteins, OME 884s, 3 stage progressive AALs.
    Sorry for not reading through 29 pages for this question. But will the badges stick back on to a derped surface? Thinking of derping my whole truck but still trying to decide what to do about the badges.
  7. Jul 6, 2014 at 6:13 AM
    #287
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    1999 Scooby Doo LGT 2008 P71
    Yes
    I'm going with no.
  8. Jul 6, 2014 at 6:44 AM
    #288
    KDOG
    Belleplain, NJ
    :( Dang... Hmmmm....
  9. Jul 6, 2014 at 6:53 AM
    #289
    LUSETACO
    Dennis
    Aim-ish country PA
    Yes
    If you're dipping the whole truck why not just leave them on? Then you could paint or dip over the dip on the emblems. ;)
  10. Jul 6, 2014 at 1:36 PM
    #290
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    Or peel it off the emblems
  11. Nov 28, 2014 at 6:30 AM
    #291
    thecoz
    thecoz Well-Known Member
    Tim
    Columbus Ga
    07 DC 4x4 6 speed
    K&N drop in, flowmaster 40 dumped before rear axle, 20% tint up front. 3 inch fat bobs coilover. Rear aal and zone shocks. LR UCA. 1.5 inch rear block. CBI moab 2.0 front bumper with wrap around guard. Smittybuilt 9500lb winch. URD short throw shifter.
    Here's mine speedway blue metallic
    MHARMS likes this.
  12. Jan 8, 2015 at 2:34 PM
    #292
    SETNHOOK
    SETNHOOK Member
    Denver
    '15 TRD DCSB
    General Grabber AT2 265/75 16, SCS SR8 16" Matte Gunmetal, Billstein 5100 Adjustable Lift Kit from Toytec, Color Matched Grill, TRD Colorado Decals
    Have you tried plasti-dip? Last 4 ever and 3 times less work. Looked great on my old car and I could blast it with a pressure washer. Didn't start to come off for 2 years. Then, when you want to switch colors, voilà, peel it off and do it again. Have not started to play with the Taco I just bought yet. Will post pics when I do. Yours definitely looks great though. Good work.
  13. Mar 31, 2015 at 10:41 AM
    #293
    lands11
    lands11 New Member
    Landon
    Vermont
    2010 Barc Red 4X4
    First post! I have my badges drying right now. I pretty much followed this instructional to the T. I went with a flat black paint and a flat clear coat. I'll post step by step with pics when it's all said and done! So far it looks exactly how I wanted it to.
  14. Oct 13, 2015 at 7:02 AM
    #294
    DarkPath
    DarkPath Cars & Coffee Williamsburg
    Williamsburg VA
    2011 Barc Red Tacoma TRD Sport DCSB
    Barcelona Red - Dueler H/Ts, Step-Bars, TonnoPro Bed Cover, Bug/Wind-Deflectors, Tailgate clamp, Black Emblems, Anytime-on Cree Fogs. ZXE HdLites
    Although I didn't read every post in this thread (so I may have missed it) but it looks like everyone is removing badges to plastic dip them... It has always been my understanding that the whole point (and real wonder of Plastic dip (and similar products)) is to dip in place... I only had my Tacoma a week before completing this mod - Plastic-dip spraying the badges On the vehicle. The real key to plastic dipping is the cleaning step of the badge other part to be dipped. Wash and rinse well.. And then using a lint free cloth, wipe area with Isopropel Alcohol..
    Rough mask with paper drape around badge area to avoid any overspray mist and aid in clean up later.
    Do a fine mask (within 1/8 inch of badge)
    Coating is a 4 step..
    1. Lightly coat all directions up/down and X across to get all edges. Dry time: 15 mins minimum between coats.
    2. Repeat
    3. Repeat
    4. Repeat. Final Coat Dry time: 30 Mins
    Gently remove fine masking - Dip will pull from body to badge edge - Perfectly..
    Any jagged tear away(s) are easily remedied with a wooden toothpick - including inside letters like A & O. Gentle use of toothpick avoid any marring of clear coat.
    If for some reason you have a strange tear.. Just take 5 mins remove all dip from the badge.. Wipe down with alcohol and once dry - repeat the steps..
    Tips:
    Important tech tip: There are two kinds of painters tape - the wide 2" kind is wrinkled (like yellow masking tape) and while great for rough masking.. Not the best for fine edges. You want 1" wide flat 3m painters tape for the fine edge masking. It appears to have a semi-glossy appearance (3m)
    I Rough masked all Badges to be dipped / and then fine masked - Before beginning to paint with Plastic dip.
    Walk around vehicle coating each badge as described above. By the time you are back to the 1st badge the plastic dip dried sufficiently while tending other badges.
    4 trips around the Truck and 40-45 mins later (< Algebra not employed) & all badges are drying with 4 coats applied. Remember, that final coat has longest dry time (30 mins) So go have a beer!
    Then:
    Starting with 1st badge remove fine edge masking to reveal your work.. If you like the result - remove all overspray masking.. (Any over-spray wipes away with alcohol..)
    Remember - slow steady pressure when pulling/removing edge masking produces the best results. Keep toothpick handy.
    Reapply wax and buff areas where alcohol was used for prep or cleanup to remove overspray.
    Lfaub03 and CM2 TT like this.
  15. Oct 16, 2015 at 4:22 PM
    #295
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
  16. Oct 17, 2015 at 10:55 AM
    #296
    DarkPath
    Williamsburg VA
    I hate chrome on a vehicle... Did I tell you that?
    For my next trick... Black Pearl front Toyota Emblem... Completed it back mid-week. Turned out perfect to my eye - just in time for Cars and Coffee...
    Here is the product: $16 Dupli-Color SHD1000 Shadow Chrome Black-out Coating Kithttp://www.amazon.com/Dupli-Color-SHD1000-Shadow-Black-out-Coating/dp/B003E2AC0E
    This too is a paint in place product...
    Tech Tip:
    #1. If painting in garage - Open Hood - makes it unnecessary to mask out hood
    #2. After masking out all around the emblem - drape behind emblem to avoid spray painting radiator...
    Clean emblem with ammonia based product... (For good adhesion of product.)
    Lightly coat emblem with Shadow product - let dry..
    (View in Natural lighting between coats.)
    Repeat to achieve personally preferred level of Pearl effect.
    Let all coats dry... (If you spray too dark shadow is removable with Alcohol based products)
    Once desired affect is achieved and dry...
    Spray lightly with clear coat (included) to complete the job.
    Once dry remove all masking... Enjoy the Better than Chrome new look.
  17. Oct 21, 2015 at 8:05 AM
    #297
    chasten_beck11
    chasten_beck11 Well-Known Member
    Chasten
    Arab, Alabama
    2005 Blue Tacoma TRD off road
    3" lift kit, complete sound system, more to come..... just got this truck
    Does the double sided tape make the badge stick out any?
  18. Oct 21, 2015 at 8:07 AM
    #298
    Tacoma SS
    Denver
    Just a little bit, but you can't notice it looking straight at them just from looking at an angle
  19. Oct 21, 2015 at 8:18 AM
    #299
    chasten_beck11
    Chasten
    Arab, Alabama
    Oh okay. Last time I did a badge removal like that I just got the adhesive that they use to put them on with at the factory and it ended up looking good, but it came off after about a year. I don't think I used enough, I was just wondering how much it would stick out with the tape.
  20. Oct 21, 2015 at 8:19 AM
    #300
    Tacoma SS
    Denver
    The thickness of the tape that you use. Like a 16th of an inch, really not much
    ChadsPride likes this.
