DIY Bed "bar"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06rubi, Apr 15, 2011.
  1. Apr 15, 2011 at 5:38 PM
    06rubi
    06rubi [OP] Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    I started making a bed "bar" For the Tacoma today. My plans for it is to support the rear tire carrier I am making. But it can work as a simple DIY bed bar for bed lights, CB antennae and D-rings. I used 1 1/4" x 1 1/4" x1/8" angle, 4.5" angle grinder, T30 torx socket, Tape measure and a drill with bits.
    First remove the bed rail with a T30 torx socket.
    Measure and cut the angle to the desired length. Measure the holes remembering that the inner diameter is not the same as the outside of the angle. I used a piece that I cut to mark and measure. Then i used the bed rail as I guide to mark the holes.
    Once you are sure the angle is marked correctly drill your holes with a 9/32 bit then you can use a step bit to make each hole fit better if your measurements were a bit off.
    Next install using the same bolts that the bed bar uses. I fabed up a simple bracket for a bed light or a CB antennae (note the CB antennae need to be grounded properly this is just an example of what you can do). You can also use some D-rings for extra tie downs. Then of course paint! I am welding my light mounts, CB antennae and tire carrier mounts still so I havent painted it yet.
  2. Apr 15, 2011 at 10:14 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    nice! DIY always kick ass
  3. Apr 15, 2011 at 10:21 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    i like!!!
  4. Apr 15, 2011 at 10:55 PM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    can i ask why you would want to cover up your track that can hold the cletes and stuff.... :? I have my bed light and my cb mounted into the rail and i can still put the cletes on there.. as tie downs...
  5. Apr 15, 2011 at 11:14 PM
    06rubi
    Kenney
    Pueblo West, CO
    I removed the bed bar completey and going to replace It with this. I'm building a tire/hi-lift in bed rack and that is part of my base. Just figured I'd give people an idea of different options to mount stuff.
  6. Apr 15, 2011 at 11:16 PM
    jackrules
    Jack
    San Diego
    i'm all for different!!! I just really love my bed rails haha...
    this seems like a much more sturdy way of mounting... the bed rails don't seem too strong when i put a lot of torq on them
  7. Apr 17, 2011 at 4:27 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    looks good!
  8. Apr 17, 2011 at 4:30 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    I like it!
