DIY Bed Bars - Rhino Rack RTV and Aluminum Extrusion Cross Bars
Discussion in '3rd Gen. Tacomas (2016-2023)' started by El Tigre, Mar 26, 2022.
  1. Mar 26, 2022 at 9:32 PM
    El Tigre
    El Tigre [OP] Well-Known Member
    Long Beach
    2018 DCSB TRD Sport 4x4 6speed
    Armrest MOLLE Panel (https://www.tacomaworld.com/threads/3rd-gen-center-armrest-molle-panel.712437/) Hood Scoop Hidden Baja Designs S8 10" Diode Dynamics SSC2 Pro Ditch Lights Bilstein 6112 front Bilstein 5160 rear Bakflip MX4 DIY Bed Lights RGB Rock Lights Modified Amazon 8 gang switch controller (thread coming)
    *All pics below in second post*
    TLDR: BakFlip MX4 to secure truck bed, Rhino Rack RTV track, diy mounts and crossbars, rooftop tent and more!
    I've got a BakFlip MX4 on my 2018 DCSB and have absolutely loved it for the last few years. I play hockey, soccer, go to the beach and camp (among other things) so having security and be able to lock it in the bed is a huge convenience. It does cause some problems when it comes to mountain biking or transporting some other items as I don't like driving with it opened up.
    Did some research and had seen some people mounting racks over their tonneaus and I know there are some companies that make brackets that slide underneath them, however with how the BakFlip mounts those brackets didn't seem ideal and were also somewhat costly.
    Cue the DIY hat and some inspiration from other TacomaWorld posts. I ordered some 1/4-20 rivnuts, matching stainless steel buttonhead bolts (to try and keep them low profile in the track), RhinoRack RTV track (usually used on camper shells/toppers for mounting rack systems), some 1530 aluminum extrusion, and had some spare 3" x 4" square steel tube.
    By popping off plastic caps on the bedsides I was able to drill some holes to mount the rivnuts and then drilled corresponding holes in the plastic caps as well. I placed the RTV tracks on top of that and was sure to put some silicone in the holes to prevent any rusting and bolted them in place.
    I took the square steel tube I had and cut it into smaller squares to act as the mounting feet that connect the crossbars to the RTV tracks. I’ve since removed the whole system, resurfaced and painted the steel to prevent rust, and even 3D printed some end caps for a cleaner look. Somewhat visible in last photo.
    I've taken this off roading on trails and had the RTT mounted with no problems whatsoever! Future plans include fixing my Thule bike racks to it, mounting a diy PVC pressurized shower underneath and I'm sure plenty more.
  2. Mar 26, 2022 at 9:38 PM
    El Tigre
    Long Beach
    Bed side caps removed
    Holes drilled and rivnuts placed with silicon for rust protection
    RTV rails fully installed alongside BakFlip
    Making the steel mounts
    97D8AC87-EB5A-43F0-9731-66E427E2952E_1_105_c.jpg FC5B8219-0C90-4317-AD78-45F97A4B86E8_1_105_c.jpg
    Resurfaced and painted with Rustoleum Hammered Black
    Racks mounted
    7DCED160-371A-4134-A961-E1D87BBEBE5D_1_105_c.jpg 0D3DA090-5800-47BB-96E7-0D5136CF6B1A_1_105_c.jpg
    Endcaps 3D printed
    Final product with RTT mounted
    setopete and kas2828 like this.
  3. Jun 21, 2023 at 1:24 PM
    El Tigre
    Long Beach
    Finally made some upgrades to this bed set up swapping out my custom DIY bed bars for some actual ones albeit Amazon Specials. I had spent some time searching for low profile bed bars as I didn't want a full bed rack, and didn't want anything that was too high up in the air in order to attempt and keep SOME aerodynamics. After finding some from bigger name companies, I kept searching around and found a few options on Amazon that were much less in cost, but looked identical to the name brands. As I know many name brands that are made overseas often come from the same factories and then get branded here in the states.
    These fit perfectly on the Rhino Rack RTV rails I'd already installed and so far have held up to the task whether it was something as simple as bikes or heavier items like my rooftop tent.
    Here are all the pieces laid out (with one bar assembled). Assembly took maybe 30 minutes and was extremely straightforward.
    Easily mounted in to the RTV rails I already had installed for my previous DIY bars. Used some square nuts in the RTV track and some M6 bolts at the right length to bolt down. Has been extremely secure thus far.
    Looks a lot cleaner than the DIY bars in my opinion. T-slots on the top and bottom allow for easy attachment of accesssories, and they have been sturdy as all hell. Threw on some Front Runner quick release tent mounts which has been a huge help for easily mounting and removing the tent.
    Hansamzac likes this.
