DIY bed racks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Nov 10, 2019.
  1. Nov 10, 2019 at 7:03 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Good evening everybody!
    I have a bunch of 1x1 (I think, maybe 1.5x1.5) square tubing. Im thinking of utilizing said material to make some bed bars for a tent. I was just curious as to how to make the mounts? The bars themselves are pretty straight forward although Im not sure if I shuold make the angled or 90 degrees. Anyways, how should I make the mounts and how do I go about mounting them on the bed? Do I just drill anywhere I see fit? Do I drill from the top or side or both? 2 bolts or 1? If yall could help me out and upload pics of you mounts and where they are bolted on it would help me out a lot. TIA
  2. Nov 10, 2019 at 7:04 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Perhaps look at how the fabricators/vendors have designed the bed racks they sell.
    Skydvrr and Wixo[OP] like this.
  3. Nov 10, 2019 at 7:06 PM
    Wixo
    Hank
    Tint, LED interior
    Ive seen some, but there are no up-close pics of how they are mounted. I will keep researching, but I wouldn't want to go up to a company and ask how to replicate their product.
  4. Nov 10, 2019 at 7:11 PM
    Hobbs
    Yep…
    Have you looked for installation documentation from rack vendors? Some may post up such info.
  5. Nov 10, 2019 at 7:11 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Most just sit on top of the bed rails, but bolt into the track system on the sides of the bed.
    Don’t drill into the bed, there is no need to when the bed has a track system to bolt to.
    Skydvrr, Wixo[OP] and shakerhood like this.
  6. Nov 10, 2019 at 7:12 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think I used 3 1/2" x 3 1/2" or 4" x 4" Angle to fit over the rail and bolt into the track.
  7. Nov 10, 2019 at 7:15 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Does this give you any idea? T bolts in the track. You should be able to zoom in.
  8. Nov 10, 2019 at 7:17 PM
    Wixo
    Hank
    Tint, LED interior
    Could you upload some pics?
  9. Nov 10, 2019 at 7:19 PM
    shakerhood
    Southern Ohio
    Let me see if I have anything stashed on my phone.
    Wixo[QUOTED][OP] likes this.
  10. Nov 10, 2019 at 7:19 PM
    Wixo
    Hank
    Tint, LED interior
    Yessir, thats very helpful thank you. Would you be able to tell me more or less how long those bolts are? Do they have a nut on the other side? Self tapping?
    shakerhood likes this.
  11. Nov 10, 2019 at 7:19 PM
    Wixo
    Hank
    Tint, LED interior
    Thanks
    shakerhood[QUOTED] likes this.
  12. Nov 10, 2019 at 7:25 PM
    shakerhood
    Southern Ohio
    This is a decent shot as it shows how the angle fits over the bed rail, it also gets bolted into the track with tamper proof stainless bolts. I went with no rise over the bed but you could fab any height you wish
  13. Nov 10, 2019 at 7:39 PM
    CrispyTacoLover
    I think I commented a few days ago on the exact t nuts you want in a different thread. The bolt length is going to depend on the thickness of the stuff you are bolting down. These bolts are 1.5” long grade 8.
  14. Nov 10, 2019 at 7:43 PM
    CrispyTacoLover
    yep... https://www.tacomaworld.com/threads/black-horse-roll-bar-question.631352/#post-21661150
    I purchased at https://www.zoro.com/te-co-tap-thru-t-slot-nut-38x12-41405t/i/G1717033/?q=41405t
    Bolts and washers came from homedepot or boltdepot. I forget which.
    Wixo[OP] likes this.
  15. Nov 10, 2019 at 7:52 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Those appear to be one inch bolts, unless they are Metric, then they appear to be a 25mm M8? Typically you don't count the "head thickness" just the thread length.
  16. Nov 10, 2019 at 7:56 PM
    CrispyTacoLover
    Yes, they are 1.5 with the head. Your application determines actual length so this is just an example of what I used.
    Most people recommend the t nuts that aren’t threaded all the way through. Those will hose your bolts if you aren’t precise. Hence the reason I recommend and use fully threaded t nuts.
    Fastbilly5 likes this.
  17. Nov 10, 2019 at 8:00 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  18. Nov 10, 2019 at 8:01 PM
    shakerhood
    Southern Ohio
  19. Nov 10, 2019 at 8:02 PM
    t4daddy
    North Alabama
    Per your pic, they are 1.25” with the head included...
  20. Nov 10, 2019 at 8:29 PM
    CrispyTacoLover
    You’re a picky mother fucker aren’t you? Did you account for camera angel, shadows and wine.
    I think the OP gets the idea. You can butt out now.
    zrace, Skydvrr and Wixo[OP] like this.
