DIY -- Behind the Seat Storage Bins -- Regular Cab 2nd. Gen.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ready2dodamage, Jul 10, 2013.
  1. Jul 10, 2013 at 5:41 PM
    ready2dodamage
    ready2dodamage [OP] Well-Known Member
    Shawn
    Nashville, TN
    2006 Reg Cab 4x4 - 4 Banger
    I <3 my regular cab, however, I hateloathdespise the lack of storage options.
    Can I get an amen?
    Building on trg37's brillance [http://www.tacomaworld.com/forum/2n...gular-cab-storage-bins-behind-bench-seat.html] I decided to make some storage bins. Tried a slightly different design, used the floor and rear wall of the cab to "complete" the bins and saved quite a bit of space. Eventually, I plan to cover them in speaker carpet.
    Let me know what y'all think!
    Two afternoons, 3 pounds of sweat, one extremity (kidding, but really almost) and 20ish bucks later :yay: :woot: :yay:
    Tools
    -Tape Measure
    -Square
    -Pencil
    -Circular Saw and/or Mitre Saw
    -Hack Saw w/ metal blade.
    -Clamps
    -Drill and bits
    -Impact w/ 9/16 socket.
    -Flat Bar
    Hardware & Supplies
    -"Handy Panel" (2'x4') of 3/4 MDF.
    -Four (4) 5/16 bolts 1"1/2 length OR threaded rod; (4) 5/16 hex nuts; (4) cap nuts; (4) 1"1/2 fender washers; (4) 1"1/4 fender washers
    -Box of 1"1/4 or 1"1/2 wood screws.
    -Beer
    -Patience by the boatload
    -A friend or neighbor to let you borrow anything you're missing.
    Prep the Mounting Bolts
    Cut the heads off your 5/16 bolts or cut your threaded rod to desired length. I found 1 1/4" to be the ideal size for fitting the bolt into the rail and getting a tight, flush mount.
    Thread the nut that will be inside the cab mounting rail onto the "cut" end of the bolt to avoid stripping the cap nut when tightening.
    My bolting system.
    Building the Boxes
    I decided to use these two holes (marked in purple) for two reasons:
    (1) A 5/16 bolt fits perfectly and (2) ease of access, given those open slots in the rail.
    Driver Side Bin Measurements
    Passenger Side Bin Measurements
    Installation
    Wiggle the bolts into the holes.
    Feed them through the MDF using a flat bar to hold pressure or pry the bolt forward.
    Once you get one bolt through, loosely attach the washer and cap nut to hold it before attempting the other bolt.
    Turn the cap nut snug by hand and then hit fast and hard with an impact (9/16 socket for 5/16 cap nut)
  2. Jul 10, 2013 at 10:39 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Looks good.
  3. Jul 11, 2013 at 10:15 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Well done OP
    Great thread with included measurements :thumbsup:
    I thought about doing a similar concept but opted to modify the existing plastic bins and building a custom box and mounting backing
    Good job
  4. Jul 11, 2013 at 10:22 AM
    SkottK62
    SkottK62 Well-Known Member
    Nice work. Simple and clean. I like it.
  5. Jul 11, 2013 at 10:49 AM
    ready2dodamage
    Shawn
    Nashville, TN
    Thanks! I should've added that my Tacoma is a '06.
    Not sure how much the interiors have changed from year to year...I guess either way it's probably best to double check my measurements before firing up the saw :)
  6. Jul 11, 2013 at 10:55 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    bravo! i think a single cab is in my future for trash runs. i will definately use this cause its such an awesome design.
  7. Jul 11, 2013 at 10:57 AM
    Kulahaga
    Kulahaga Tacomaized
    Roger
    Florida Panhandle
    2010 * Regular Cab * 2.7 * Manual
    Curt Receiver Hitch * Firestone RideRite Air Springs * OEM Chrome Grill * OEM Intermittent Wipers * OEM Cruise Control * UltraGauge * * Anytime Fog Lights * Cargo Bar & Cargo Net * Pop & Lock and Bully Tailgate Security * TonnoPro Tri-Fold Tonneau Cover * Backup Camera * * LED Interior, Under Door, Under Hood & Cargo Lighting * Pin Stripes * Wet Okole Seat Cover * ImMrYo Mirror Mod * DVR207 Dash Camera *
    Amen!!! Too cool!:D Great write-up. You got me to thinking about a little variation to include a subwoofer along with your idea.
  8. Jul 11, 2013 at 11:01 AM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    that's bad ass
  9. Jul 11, 2013 at 12:01 PM
    TigerTaco
    TigerTaco Kick His A$$ Seabass
    Austin
    Alabama
    08 5lug RC Taco
    Subbed. I guess I know what I'm doing this weekend.:D
  10. Jul 11, 2013 at 12:03 PM
    Zonktified
    Zonktified Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
    Bravo sir...well done!
  11. Jul 14, 2013 at 8:04 AM
    ready2dodamage
    Shawn
    Nashville, TN
    I should also mention that I chose this width so the box essentially sits flush vertically along the edge of the "hump" that runs along the rear cab wall.
    However, given the width I chose, I sacrificed either 1 or 2 clicks of backward seat adjustment. Since I'm 5' 7" the loss is irrelevant to me, but I'm sure it would make a difference to the taller folks out there.
  12. Jul 15, 2013 at 9:06 PM
    ready2dodamage
    Shawn
    Nashville, TN
    Thanks but I'm definitely lacking the equipment, space and expertise to mass produce. These consumed my entire weekend and thankfully I had an extra day off from the 4th. Lol.
    I think this would be a great project for a sheet metal fabrication shop. I'd imagine a similar design would be cheap and easy to produce. Group buy?
  13. Jul 15, 2013 at 9:20 PM
    Future Tacoma
    Future Tacoma Well-Known Member
    Jeff
    Colorado
    Purchased a new 2013 Tacoma Double Cab 4WD
    Stock at this time.
    I think it looks great! Very nice job.
  14. Jul 30, 2013 at 2:53 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Awesome work!!!!!
    :popcorn:
  15. Mar 10, 2014 at 5:57 AM
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    Will this work with the storage shelf from a double cab behind the bench seat in reg cab?
  16. Mar 11, 2014 at 3:00 PM
    ready2dodamage
    Shawn
    Nashville, TN
    Not sure. If you sent me a photo and some dimensions, I could try and measure it?
  17. Jan 25, 2015 at 5:56 PM
    jagergirll
    jagergirll Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO2 A/T 245/75R16 Camper Shell
    Great thread and good idea for the storage. After reading several other threads I have seen people say they can't make modifications because they don't have a place to do it. So today I decided to make these by hand using only a cross cut saw, level, tape measure, hammer and nails. It was a cold wet day so I built it in my living room while watching Net Flix. I purchased the materials at Lowe's and you could have bought everything pre cut. I just bought 1Ă—12 white board, and cut everything to size.
  18. Jan 26, 2015 at 7:23 AM
    ready2dodamage
    Shawn
    Nashville, TN
    ^Impressive ingenuity! For some reason I can't click on/enlarge your photos? From what I can tell they look good! Nice work!
  19. Jan 26, 2015 at 7:42 AM
    Winker
    Winker Well-Known Member
    Paul
    Kentucky
    2019 Subaru WRX
    You can see the pictures in their gallery. It's the camera looking decal under the avatar. They are much bigger in the gallery.
    I don't know how this thread has alluded me so long. I'll have to do something similar. I feel like an idiot for not thinking of doing something so simple. Way to go.
  20. Jan 27, 2015 at 4:31 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    They are pretty neat. I am glad I saw this thread. It makes my truck more organized.
