DIY Bolt-On Frame Plates for Sliders
Discussion in 'Armor' started by 1 Bored Clerk, Nov 9, 2013.
  1. Feb 17, 2018 at 8:34 AM
    #401
    1 Bored Clerk
    1 Bored Clerk [OP] Well-Known Member
    Vancouver, WA
    '13 4x4 AC TRD OR
    I haven’t seen this problem before. But, as has been suggested, don’t mess with the frame. Notch the slider plate. You can v notch it, drill a hole, whatever you want. Toyota does like to try new things from time to time. A batch of frames may have gone out with extra bits and we’re not a big enough sample group size to have run into many of them. If I have accurate measurements of where these extra bits sit, I could change the frame plate file to accommodate.
    DoorDing likes this.
  2. Feb 17, 2018 at 8:57 AM
    #402
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    This is how I had to cut mine / drill to get it to work with my new frame
  3. Feb 17, 2018 at 9:01 AM
    #403
    1 Bored Clerk
    Vancouver, WA
    '13 4x4 AC TRD OR
    Huh, interesting. I didn’t realize the extra rivets were on the face of the frame. For some reason I thought they were on the bottom. So, in that light, definitely don’t V notch the frame plate! Haha. The notch at the end is easy enough to add. The hole farther over...I’ll need dimensions. Preferable from the top of the frame plate, down. Then from the end of the frame plate, over. If anyone can give me those dimensions, post em up and I’ll rev the files.
  4. Feb 17, 2018 at 9:06 AM
    #404
    crolison
    Ar vah da, CO
    POS
    Two on the front, one of the bottom
  5. Feb 17, 2018 at 9:35 AM
    #405
    crolison
    Ar vah da, CO
    POS
    Used a step bit to drill the hole.
    You can see all three extra rivets in this photo
  6. Feb 17, 2018 at 1:47 PM
    #406
    topher347
    topher347 Member
    Beaverton, Oregon
    2008 Toyota Tacoma Access Cab
    Mine only has the extra on the bottom of the frame. Seems to be a lot of variations.
  7. Feb 22, 2018 at 5:24 PM
    #407
    topher347
    topher347 Member
    Beaverton, Oregon
    They're close to done now! Just need to get my nut plates figured out and made this weekend, and then I'll hopefully be painting them on Sunday. Using the Rustoleum Bed Liner aerosol. Heard good stuff about it and should be easy to touch up. Hopefully they're mounted on Sunday or sometime next week. Gotta give a shout out to my buddy Tim at out here for helping me get them done in a much faster manner than I would have been able to myself. Hopefully I'll have some finished pics of them on my truck coming up in the not too distant future!
    1 Bored Clerk[OP], D2. and Simpleton like this.
  8. Feb 22, 2018 at 6:13 PM
    #408
    Simpleton
    Simpleton Well-Known Member
    Orange County
    2017 DCSBOR
    None as of yet
    PREP PREP and more PREP! I have has bad luck with the rustoleum bed liner flaking but I attribute it to my lack of sufficient cleaning of the parts I did.
  9. Feb 23, 2018 at 4:08 AM
    #409
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    those look fantastic!
  10. Feb 23, 2018 at 7:07 PM
    #410
    topher347
    topher347 Member
    Beaverton, Oregon
  11. Feb 24, 2018 at 6:18 PM
    #411
    topher347
    topher347 Member
    Beaverton, Oregon
    Painting and mounting tomorrow!
    1 Bored Clerk[OP] and D2. like this.
  12. Feb 26, 2018 at 8:08 AM
    #412
    D2.
    Dan
    Nova Scotia, Canada
    thats clean!
    is it DOM Tube or HREW?
    I've been trying to find free plans for Draw through tube bender on the internet for a few days, but no so much luck. I want one that tells you how to make the dies as well.
  13. Feb 26, 2018 at 10:33 AM
    #413
    topher347
    topher347 Member
    Beaverton, Oregon
    DOM. Had some last minute fitment issues so they should be installed Thursday or Friday.
  14. Feb 26, 2018 at 7:36 PM
    #414
    Tree Top Flyer
    Tree Top Flyer New Member
    michael
    84 toy truck sr5
    was buick v6 w/ blower 600 hp , putting it back stock been in garage for 30 years
    I'm a bit out of touch, are the newer Toyota frames c channel? I have a 1984 which is box frame. The frame is like new as the truck sat inside for the last 30 or so years. I just started a total resurrection of the truck do you suggest I reinforce this frame too? This is a standard cab short bed, are there drawings for this frame?
  15. Feb 27, 2018 at 10:47 AM
    #415
    ldanny
    ldanny Well-Known Member
    where are you guys getting the hardware?
  16. Feb 27, 2018 at 9:35 PM
    #416
    Simpleton
    Orange County
    2017 DCSBOR
    None as of yet
    got mine from McMaster Carr for convenience but Ace home depot and lowes all have grade 8 hardware.
    ldanny[QUOTED] likes this.
  17. Feb 28, 2018 at 4:54 AM
    #417
    topher347
    topher347 Member
    Beaverton, Oregon
    On my 2nd gen it is no longer fully boxed. So I imagine anything similar for your would be a completely different design.
  18. Feb 28, 2018 at 4:57 AM
    #418
    topher347
    topher347 Member
    Beaverton, Oregon
    Pretty much all of my local hardware stores (Ace, Orchard, etc) has the right grade and thread and pitch, but I had to mix and ma Ch a bit because they’d only have about 4 or 5 or any given variety. So some have different heads, some are stainless some aren’t, that kind of thing. If I hadn’t bought them so close to needing them I’m sure there’s be relatively inexpensive places online where you could get them all the same and everything. Did that for the body lift bolts back when I had an Xterra but can’t remember what site I used.
  19. Feb 28, 2018 at 5:19 AM
    #419
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    Tractor Supply has a good selection and they're by the pound.
    Simpleton[QUOTED] and ldanny like this.
  20. Feb 28, 2018 at 11:58 AM
    #420
    ldanny
    what were the sizes? Its going on my second gen.
