DIY, Brake fluid flush, 4x4 - TRD Off-Road with Speed Bleeders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Mar 22, 2015.
  1. May 22, 2017 at 6:56 AM
    #61
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    I installed these yesterday along with extended brake lines and bleeding was a breeze. Never bled brakes before, so I don't have anything to compare it to, but it was extremely easy using the speed bleeders.
    Stryker420 and TACOVRD like this.
  2. May 22, 2017 at 8:39 AM
    #62
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Added unnecessary expense. Tube in a bottle of fluid works the same and just as easy. That is unless you just pull in to a field and let the fluid fly.
  3. May 22, 2017 at 8:57 AM
    #63
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    I also did this over the weekend, can confirm sizes listed are good for 05 TRD off-road. Could not find any actual "speed bleeder" brand so went with some by Goodrich. Did the install + bleeding both were super easy. I got an extra for the clutch have not done it yet.
    I have done all the variations, and in fact still have & use a Motive pressure bleeder on my 2 other cars. I went with the speed bleeders on the Tacoma because it does not have a threaded cap on the reservoir like my other cars & pressure bleeder do. After doing the Tacoma, frankly the speed bleeders are far easier all around. I also have a few motorcycles and since you can reach the brake lever/pedal easily while opening/closing a bleeder with a wrench, I never thought to put speed bleeders on them. I think I will now. That way you can track reservoir levels much easier while squeezing levers etc.
    I hear the clutch on a Tacoma is difficult to bleed, anyone done it yet with a speed bleeder?
  4. May 22, 2017 at 9:38 AM
    #64
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    In principle, yes.
    But, you really should watch to ensure fluid is not leaking around the bleeder screws, and that the hose both stays submerged in fluid and does not come off the bleeder screw.
    The main concern I have with this method is sucking the air in the tube back into the brake system. I suppose you could fill the tube with fluid before putting it on the bleed screw...
    BillsSR5 likes this.
  5. May 22, 2017 at 9:45 AM
    #65
    stump jumper
    Bill
    Texas
    Get the right size and first concern is solved. Use a short piece and first pump of pedal pushes all the air out. Never had a jar turn over. I use a glass jar not plastic.
  6. May 22, 2017 at 12:45 PM
    #66
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    To each his own, money well spent IMO. If your happy so be it. SB's are quality bits.
    Norton likes this.
  7. May 22, 2017 at 1:27 PM
    #67
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    It is difficult to bleed all air from the clutch. I tried a SpeedBleeder on the slave, but it didn't work any better than traditional method.
  8. May 22, 2017 at 5:22 PM
    #68
    ajpagosa
    SW Colorado
    OK thanks I'll take a look. Another car I have, the trick is to remove the slave from its mount, and hold it upside down while you bleed it. Don't even know if that is possible with the Tacoma.
  9. May 22, 2017 at 6:28 PM
    #69
    samiam
    Sam
    Stinky Vegas
    I don't think that is possible. The problem area is the fluid line inside the engine bay where it makes a sharp upward loop then down, and that is where air gets trapped.
  10. May 23, 2017 at 6:36 AM
    #70
    ajpagosa
    SW Colorado
    Of course not, that would be too easy. :( I'll take a look next time I'm in there. Thanks.
  11. May 23, 2017 at 10:29 AM
    #71
    stump jumper
    Bill
    Texas
    Lots of companies stay in business selling people stuff they really don't need. It is your money and to spend how you want. I prefer to spend mine on things that add real value.
    Lester Lugnut likes this.
  12. May 26, 2017 at 4:22 PM
    #72
    HB Taco
    Curt
    Most of the vendors here are selling stuff that peeps dont NEED, but want. The reviews speak for themselves. Thousands of happy customers on all types of vehicles with them. Say what you want but most people that buy them love them.
    Also I spent more on dinner last night then on the SB's.
    Bambino and Norton like this.
  13. Dec 5, 2017 at 5:44 PM
    #73
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    Can anyone vouch for these sizes for 3rd gen?
  14. Dec 5, 2017 at 5:56 PM
    #74
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    sub a dub dub
  15. Mar 21, 2018 at 11:23 PM
    #75
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I installed speed bleeders today and bled the brakes. This was my first time bleed8ng brakes and it seemed to go well. One thing I couldn’t figure out was during this step I pushed the brake pedal 20 or more times as instructed by the the owners manual.
    After I pushed the brake about 5 times the pedal firmed up and would barely go down. On the next push of the pedal the pressure would completely go away and remain this way for the 15 or so remaining pedal pushes.
    Is this step decreasing the pressure in the system limiting fluid loss when you switch bleeder screws?
  16. Mar 22, 2018 at 10:22 AM
    #76
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Dot 3 or 4 on the upcoming Valvoline Synthetic Fluid
  17. Mar 22, 2018 at 10:28 AM
    #77
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    Why do it with truck on?
    Stryker420 likes this.
  18. Apr 23, 2018 at 5:03 AM
    #78
    Skywalker15
    Skywalker15 New Member
    Luke
    South Carolina
    2010 Tacoma TRD Off-Road, 1997 Tacoma LX 2WD
    Did this yesterday (2010 TRD Offroad, BTW) and I'm wondering if I did something wrong. I did not use speed bleeders. Instead I was under the truck and my wife was pushing on the brake pedal. It went exactly as described for the rear brakes - the pump pushed the fluid through nicely. However, when I moved to the front I didn't get the same results. When she pushed the brake pedal, I got very little fluid flow and the pump didn't run like it did on the rear. Long story short, I ended up doing the front the old fashioned way (press and hold pedal, open bleeder, close bleeder, release pedal, repeat).
    Did I do something wrong or misunderstand the procedure? I warned her about not pushing the pedal too far and possibly hurting the master cylinder seals, so could she have not been pushing far enough? I asked her to push the pedal a little harder/farther a couple of times and it didn't seem to make a difference. While finishing up the fronts, the pump would run for a couple of seconds about every 3rd or 4th bleed cycle, but if you just pushed the pedal and held it, with the bleeder open, the pump wouldn't cycle (~2-3 sec on/2-3 sec off) like it did for the rear.
    Ultimately got the job done and I'm happy with the results - ran about a liter and a half through the system. Just looking for some clarification for next time.
  19. Apr 23, 2018 at 5:36 AM
    #79
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Clutch = SB1010..........5 spd so I need 5 bleeders :)
  20. Apr 23, 2018 at 11:51 AM
    #80
    Driftns2k
    Driftns2k Well-Known Member
    C
    Corvette ls2
    Built and blown
    Nice write up!
