DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Apr 25, 2016 at 8:31 PM
    #241
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I didn't really think of this til all my stuff arrived but how do you wire, say, a pair of led backup lights in parallel with MetriPack connectors?
    If you use a 4 pin connector then you have to add jumpers on the female side which means doubling up the wire when you crimp the pin (as shown). If you are using 12ga or 14ga wire I don't see how this will fit in the seals.
    If you use only 2 pin connectors then you have to run the wires from LED2 into the back of the LED1 connector which means doubling the wire when you crimp the male pins.
    Just wondering what do...
  2. Apr 25, 2016 at 8:38 PM
    #242
    Manwithoutaplan
    ID
    very impressed by this thread well done OP :thumbsup:
  3. Apr 26, 2016 at 5:44 AM
    #243
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I did mine this way
    rob1208 likes this.
  4. Apr 26, 2016 at 7:21 AM
    #244
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Ok cool. So you just doubled up the wire when you crimped the top two pin connector?
  5. Apr 26, 2016 at 7:24 AM
    #245
    G.T.
    G.T.
    CONUS
    You guys are doing all of this amazing wiring and I'm sitting here still trying to relearn how to tie my shoes. Overtime I come back to this thread I am even more impressed with my fellow TW members. Great work folks.
    Crom and Chux like this.
  6. Apr 26, 2016 at 7:26 AM
    #246
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    LoL. I'm learning alot too. Those WeatherPack/MetriPack type connectors make it look easy. I think all the GM vehicles use WeatherPacks now so it's basically OEM.
  7. Apr 26, 2016 at 7:33 AM
    #247
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Yep...no problem at all
  8. Apr 26, 2016 at 7:48 AM
    #248
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    I ordered all the stuff to make a relay box. When I got it all, I had ordered the wrong box. It only had one bussbar. coulda made it work but I wanted two bussbars. That was another $12 shipping charge from waytek. Then I had to ship that box back. Cost $4 to ship it to them wtf! Oh well. Ive got my box built, but in my stupidity I forgot to order the correct pins for the 2 pin weatherpak connectors.
  9. Apr 26, 2016 at 10:36 AM
    #249
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Does anybody know the bolt specs that are on the 2nd gen drivers side fender where many people are mounting their brackets? Also the specs on the bolts for the Bussmann RTMR itself? Mine didn't come with any mounting hardware. I made a bracket last night, but these are the only pieces I'm missing from having this preliminary step finished.
    EDIT: It looks like for the bussmann what's needed are #10-32 or M5 threaded inserts. Source
  10. Apr 26, 2016 at 11:02 AM
    #250
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    fender bolts are M8
    TaylorU likes this.
  11. Apr 26, 2016 at 12:02 PM
    #251
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Ok so this is the wiring diagram for the backup lights. Same deal for the fog pair and anything else that wants to be in parallel.
  12. Apr 27, 2016 at 11:00 AM
    #252
    mountainmonkey
    mountainmonkey Well-Known Member
    Colorado
    '13 Double Cab TRDOR DCSB
    Never enough
    How much does this flexible cable cost and where can I get it?
  13. Apr 27, 2016 at 11:20 AM
    #253
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    You can get it through me once it lands mid may.
    I didnt think anyone on TW or some one outside of an audio world would really be interested in something like this. The cost is not cheap and is only sold in a 50ft spool. Works out to be 15.8$ per foot for a cable under rated at 1000Amps per 20ft section
  14. Apr 27, 2016 at 12:11 PM
    #254
    mountainmonkey
    Colorado
    Never enough
    Does that mean $15.80 per foot or 15.8¢ per foot? One is in my budget, the other is not haha. Looks like a sweet product though.
  15. Apr 27, 2016 at 12:13 PM
    #255
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    lol i think you know the answer to that one :p
  16. Apr 27, 2016 at 4:18 PM
    #256
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Yeah...I've worked with some big ass copper running power to DC power plants. It was called 750 and I can't remember what it was but I do remember it was like $20/ft or some shit
  17. Apr 27, 2016 at 5:25 PM
    #257
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Yeah big wire! Stuff is about as stiff as your frame lol. I know a few people who ran it as a chassis ground in unibody cars
  18. Apr 27, 2016 at 11:59 PM
    #258
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    Did you end up wiring your backup pods/LEDS to a switch or to turn on automatically when reversing? Just curious.
  19. Apr 28, 2016 at 7:26 AM
    #259
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'm still in the middle of wiring but thinking you should be able to do both. If the LED can get power from the OEM reverse wire or from the switch then it would come on/off when in reverse or it would come on/off with the switch.
  20. May 1, 2016 at 4:35 PM
    #260
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    I decided I did NOT want them to come on EVER (automatically) when I was in reverse. Don't want to unintentionally blind someone. A switch was my choice. It's in my overhead panel so it's easy to reach and if I don't have enough light in reverse I can just throw the switch.
