DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. May 16, 2016 at 8:07 AM
    #281
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Finally got min finished up this weekend! Only thing connected currently is my carling style USB charger on my iggy switch panel. Now comes my headlight retrofit project, as well as bed and hood light install! Thanks again @tacozord!
    tacozord[OP] likes this.
  2. May 17, 2016 at 11:09 PM
    #282
    Normantaco
    Normantaco Well-Known Member
    Pensacola, Fl
    16 4Runner SR5
    Thinking of building this. I haven't priced it all out. I know some of the connectors/plugs have a minimum order. Anyone that has made the minimum order have extra to sell? Is it worth it, or is the minimum order a negligible amount more?
  3. May 17, 2016 at 11:41 PM
    #283
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    You can use the extra terminals for making connectors for all your lights and other electronics, but you'll then need to order the Metri-Pack 280 male and female housings and retaining clips as well.
  4. May 19, 2016 at 7:04 PM
    #284
    Roo1041
    Roo1041 Well-Known Member
    Riley
    Tuscaloosa, AL
    2003 Toyota Tacoma Prerunner
    aFe CAI 3" OME Nitrocharger shocks w/ 883 Coils Rear OME Dakar Leaf Pack 17x8 ATX AX324 Assault Wheels 265/70R17 BFGoodrich Rugged Terrain T/A Tinted Windows to match stock rears
    Awesome write up! Got mine done in a couple of days and installed in a couple of hours. No more tapping into corner lights. Also built three extra Bussmann blocks; they are for sale in the "1st and 2nd gen for sale" pages. Thanks for the write up!
    TaylorU likes this.
  5. May 19, 2016 at 9:33 PM
    #285
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'm wondering if you can leave out one or more of the relays and wire those circuits up for fuse only so that you can have more than 5 fuse only circuits. Now that I have my system planned out I don't think I will need relays for some of the lights since the LEDs draw such little power.
  6. May 19, 2016 at 9:40 PM
    #286
    Roo1041
    Riley
    Tuscaloosa, AL
    Instead of bridging the fuse to the relay, couldn't you just make more fuse only leads and plug the relay side with the cavity plugs? So instead of having F1R1 F2 F3R2 F4 ect. leads, you would just have like F1 F2 F3 F4 F5R1(or 3 if you want to keep it the same as in OP).
  7. May 19, 2016 at 9:48 PM
    #287
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah. I think that's what I was thinking.
    I'm also trying to remember if you can plug a mini fuse where the relay was. That way removing one relay might free up 2 fuses.
  8. May 19, 2016 at 9:51 PM
    #288
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    I'm not sure what accessories you're using and how much power they're drawing, but just a heads up about LED current levels and safety. A typical LED draws about 20mA at 12v. So if you have ten LEDs in a foot of light rope, then that's 200mA per foot of lights and no longer considered low power. If you want this circuit switched, then I'd definitely use a relay and not control directly.
    Here's a link about electrical safety and the dangers of different current levels:
    https://www.physics.ohio-state.edu/~p616/safety/fatal_current.html
  9. May 19, 2016 at 9:55 PM
    #289
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    oic.
    I think I have about 48W in the rear backups and prolly about the same in fogs and bunny burners each. I was thinking 4 or 5 amps would be pretty typical for an OEM fuse only circuit.
  10. May 19, 2016 at 10:36 PM
    #290
    tacozord
    2015 DCLB 4wd SR5
    You definitely want a relay on those!!!
  11. May 20, 2016 at 4:47 PM
    #291
    tacozord
    2015 DCLB 4wd SR5
    Get these in the mail yesterday from a forum member as thanks for the tutorial. So very grateful. Thank you Taylor!
  12. May 27, 2016 at 5:51 PM
    #292
    Philly100000
    Philly100000 Unknown Human
    Phillip
    Regina, Saskatchewan, Canada
    2011 Toyota Tacoma 4x4 DCLB TRD Sport Edition
    I've got everything I need except the 10 AWG TXL Red & Black Wire, I've been searching locally to see if anybody carries or can get it for me. I've taught about 9 different automotive electrical shops about why it's such a special wire and what it's used for, but cannot find it for the life of me.
    I didn't purchase it from Waytek because they want 68$USD for a 250' spool, when I'll never use that much. If only someone would send me like 10' of each! (hint hint) If not I'll have to just buy it when I return from Moncton, NB. :p
    I'm aware I can use different wire, but I'd much rather use TXL for the specific reason of it fitting in the cavity plugs without being too tight or loose.
  13. May 27, 2016 at 6:11 PM
    #293
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I just got the 12ga GXL from Waytek. I think it was about 40 something for the 250 spool. It fits the RTMR seals better and has plenty of ampacity for my circuits.
  14. May 31, 2016 at 5:16 PM
    #294
    Phoosa
    Phoosa I never saw nothing.
    Truck
  15. Jun 6, 2016 at 12:34 AM
    #295
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Ok, so this was my solution to get a pair of lights wired in parallel. Basically the same as I show in the diagram except I put the double wires on the female side so that the wiring harness could be removed.
    Anyway you can just fit both a 12ga wire and an 18ga wire into the 12ga seals and squeeze everything together in a 12/10ga terminal. Not really ideal since it's not a perfect seal with two wires.
    rob1208 likes this.
  16. Jun 10, 2016 at 12:15 AM
    #296
    DNasty777
    DNasty777 HEATMISER
    Dave
    Rochester, NY
    '16MGMDCLBTRDS4X4
    Sub'd so I can find this easier. Also want to say thanks! This is incredible!
  17. Jun 12, 2016 at 7:33 AM
    #297
    yotastaco
    yotastaco Well-Known Member
    NC
    2015 MGM TRD OR
    See Build
    Awesome write-up. I'd like to add a recommendation for tools. I'm an electronics enthusiast and agree with the soldering station, but having a quality soldering pen is a lot easier when working outside on the truck itself, rather than lugging around your station. I'd recommend a Hakko FX-901 pen and for the station a Hakko FX-888D. I built 90% of my Bussmann RFRM inside and on a soldering station, but those quick fixes outside the soldering pen is a lifesaver. A good set of helping hands also can make things much less frustrating.
  18. Jun 13, 2016 at 4:12 PM
    #298
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Does that 888D get hot? I've been through several soldering irons and heat guns and mini torches and nothing seems to work right. It's like solder doesn't want to melt in my part of the universe.
  19. Jun 13, 2016 at 6:23 PM
    #299
    yotastaco
    NC
    2015 MGM TRD OR
    See Build
    Very. Hakko's are very well known and used in the electronics industry. Make sure you have good solder.
  20. Jun 13, 2016 at 6:29 PM
    #300
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
