DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Jun 13, 2016 at 6:44 PM
    #301
    yotastaco
    yotastaco Well-Known Member
    NC
    2015 MGM TRD OR
    See Build
    I have some Kester spools right now. I use it with my Delphi Weatherpack connectors and small electronic projects and it works great.
  2. Jun 13, 2016 at 6:47 PM
    #302
    MoQS
    MoQS Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    Thanks yotastaco!
    yotastaco likes this.
  3. Jun 13, 2016 at 6:49 PM
    #303
    yotastaco
    NC
    2015 MGM TRD OR
    See Build
    Also, I avoid lead-free solder as much as possible. It's not fun to work with and just go-green garbage.
    MoQS likes this.
  4. Jun 13, 2016 at 7:02 PM
    #304
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Cool. That should help. I didn't know non lead free solder was even available.
  5. Jun 15, 2016 at 9:06 AM
    #305
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I finished the RTMR. I used the 7 terminal metripak for the switch wires. Also the accessory cable for the spots has a third wire to control the hi/low/strobe function.
    BYJOSHCOOK and dcsbtaco like this.
  6. Jun 17, 2016 at 10:08 AM
    #306
    Ecrub
    Ecrub Well-Known Member
    Eric
    Brea, Ca
    2016 DCSB TRD OR 4x4
    What a great guide! I may have to try and build one instead of buying one.
  7. Jun 20, 2016 at 11:22 PM
    #307
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Bussman all wired up and mounted. I just need to run the wires to the switches and drop in an 80A fuse.
    Crom, tacozord[OP] and BYJOSHCOOK like this.
  8. Jun 21, 2016 at 4:41 AM
    #308
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Did you drill into the side of the truck to mount it?
  9. Jun 26, 2016 at 7:55 AM
    #309
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Has anyone reused a junk car fuse box?
    I have an old 98 civic waiting to be crushed.. it has a fuse box under hood. Is this worth building an aux fuse box for light bars out of this.?
    Whole fuse box has plastic covers top and bottom (removed for pictures)
  10. Jun 26, 2016 at 8:23 AM
    #310
    G.T.
    G.T.
    CONUS
    I think that's a pretty damn good idea.
    ChemDawg[QUOTED] likes this.
  11. Jun 26, 2016 at 10:45 AM
    #311
    ChemDawg
    Maine
    2005 sr5 4x4
    :thumbsup:I was hoping it would work out..now I just gotta figure the wiring out..o_O
  12. Jun 27, 2016 at 7:10 PM
    #312
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    @tacozord
    Does anyone know why the red Switch Power wire comes from the fuse panel and not just from the RTMR. You already have power available from the RTMR without tapping into another circuit if you just bring an additional wire.
    Is it ok for the circuit to have full time power or does it need to be located on a relayed circuit like the Tail Relay which comes on/off with the Ignition and Accessory key position. That's the only reason I can think of.
  13. Jun 27, 2016 at 11:58 PM
    #313
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    That's pretty much the reason, to only power it when the ignition is on. You could just power it from the RTMR if you want the switches and accessories to be available anytime.
  14. Jun 28, 2016 at 12:07 AM
    #314
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    That makes sense. I found a relayed circuit to tap into.
    Edit: Actually I don't know what I was thinking in my previous question. The power wire for the switches can't come straight from the battery otherwise the lower LED will be always on. It needs to go to the something in the Tail Relay circuit so that it shuts off with the Key Ignition/Accessory.
  15. Jun 28, 2016 at 11:49 AM
    #315
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Sry, just saw this :D
    No. I used two 6mm bolts/machine screws to connect to some existing threaded holes. I added a couple of oversize nuts as spacers since the surface is not completely flat and I added a bent plate to compensate for the slope of the body. It would help if the plate flange was a bit longer and prebent. I was afraid to bend the aluminum.
    BYJOSHCOOK[QUOTED] likes this.
  16. Jun 28, 2016 at 12:02 PM
    #316
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Its fine! Thanks I'll look into something like that. Also what screws did you use to mount the box to the mount? I need longer ones but I couldn't get the right pitch at Home Depot
  17. Jun 28, 2016 at 12:05 PM
    #317
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Lowes has a better bolt selection, at least in my area.
  18. Jun 28, 2016 at 12:10 PM
    #318
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'll have to check them out too
  19. Jun 28, 2016 at 12:30 PM
    #319
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yeah, it is a very fine thread. The screws are #10-32 as per the chart in the OP. I ordered the metric version which uses M5 screws but they sent me the wrong one.
  20. Jun 28, 2016 at 12:36 PM
    #320
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Awesome thanks! I'll see if I can find some of those local
