DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Jul 8, 2016 at 10:28 PM
    #321
    TACOtrd1106
    TACOtrd1106 Well-Known Member
    Cali
    2012 Black TRD 4x4
    I have an issue. I used a t tap to get power from my dash. I tapped into my traction control switch to power my lower independent switches. I did manage to power all my switches but lost power to my traction control switch. Any help would be appreciated
    My guess is that my switches are drawing too much power?
  2. Jul 27, 2016 at 12:07 AM
    #322
    kitsym
    kitsym Well-Known Member
    Portland, OR
    2015 4x4 MGM DCSB TRD Sport
    My guess is that you may have cut the power wire to your switch. That is either caused by too small of a t-splice or it may have been crimped down too hard. The +12v is powering your switches, but it's not connected to your VSC switch.
    I would check out that connection as the switches require very low current.
  3. Aug 7, 2016 at 6:18 PM
    #323
    iambuho
    iambuho Well-Known Member
    Salt Lake City/Chicago
    2013 MGM AC 4x4 SR5
    First off, I love this set up. I built mine over the winter, installed in spring and really like having switches for all my lighting.
    That being said, I have one more switch spot available and I have an idea what to use it for, just not sure how to do it with this setup.
    Anytime back up camera mod. I understand Croms tutorial for his particular application, but not sure how to apply it to this particular fusing and switching setup which would use my last available switch location in headliner. Any help would be much appreciated. Thank you.
  4. Sep 29, 2016 at 8:47 AM
    #324
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Sorry if this is off track but does anyone have a place and the part numbers if I want to redo my H10 fog lamp connectors? I looked and couldn't find the pieces themselves, only the one's with wires on them. Can they be taken apart and put on my factory wires? There are some very smart people in here and figured someone might know this stuff to help me out
  5. Oct 24, 2016 at 4:28 PM
    #325
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    What it be possible for one of you guys to give me the dimensions of a Bussman fuse box? The website doesn't have the dimensions for the one listed in the original post.
  6. Oct 24, 2016 at 4:42 PM
    #326
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Part 2 of this tutorial gave you a link to the datasheet for the box. Here it is again. All the specs that you're looking for are in there.
  7. Oct 24, 2016 at 8:08 PM
    #327
    Philly100000
    Philly100000 Unknown Human
    Phillip
    Regina, Saskatchewan, Canada
    2011 Toyota Tacoma 4x4 DCLB TRD Sport Edition
    Built mine quite a while ago, but havn't shared it here. I carry lots of spare fuses in mine lol
    https://www.tacomaworld.com/threads...verland-adventure-build.380144/#post-13384669
    RNJNKE and trekker like this.
  8. Oct 24, 2016 at 8:27 PM
    #328
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Why didn't I think of keeping my spares in the empty spots? :facepalm:
  9. Oct 25, 2016 at 11:07 PM
    #329
    RAWKON
    RAWKON Member
    Montana
    TRD Off Road
    :DSubbed, planning future upgrades!
    RNJNKE likes this.
  10. Nov 3, 2016 at 11:21 AM
    #330
    Yotamac
    Yotamac Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    BadDNA likes this.
  11. Nov 8, 2016 at 2:08 PM
    #331
    Tcgator
    Tcgator Well-Known Member
    Tyler
    Fernandina beach
    2017 Quicksand TRD Offroad
    Does anyone happen to have any leftover parts that i can buy/have to build my RTMR? i know that all these parts unfortunately come in a minimum order, so just seeing if anyone out here has any left over parts such as terminals, weather packs, etc.... Thanks you guys!
  12. Dec 29, 2016 at 2:05 PM
    #332
    Tac0maSteve
    Tac0maSteve Well-Known Member
    East Bay, CA
    '15 TRD Off Road Icon Ext. Travel
    DCSB... No mods here
    I will be doing a modified version of this build using the 10 relay/40 fuse or Circuit Breaker box and want to use the external bus bars like this project used. However, I cannot find a Blue Sea 10 gang BusBar that matches or is close to the length of the RTMR 10 relay box. I know I could use the shorter 10 gang BusBar they have w/ longer wires, but would like a longer (matching length) one to keep everything very organized during the building process of this box.
    Does anyone have recommendations on a different brand that would match the length better? Links or PMs would be highly appreciated.
    Here is the 10 RTMR is will be building with
    http://www.connectorconcepts.com/bu15rffuremo.html
    Here is the shorter BusBar I have found. I would like this twice the length with only a single row of screws.
    Blue Sea 10 Gang https://www.waytekwire.com/item/78250/Blue-Sea-Systems-2301-Common-BusBar-/
    Mademan925 likes this.
  13. Dec 29, 2016 at 4:16 PM
    #333
    tacozord
    2015 DCLB 4wd SR5
    Blue Sea makes a 20 Gang busbar that is long. You could always use that and not use 10 of the screws.
    Otherwise, you could also make one yourself. You'd simply need some metal to drill and thread holes. Then a couple stand-off posts or plastic or something for insulation.
  14. Jan 2, 2017 at 4:05 PM
    #334
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Amazing write up. Great job OP
  15. Jan 3, 2017 at 12:30 PM
    #335
    Tac0maSteve
    East Bay, CA
    Ahhh yeah bought all my supplies! Doing a modified version with a 10 relay fuse panel though. I'll report back after it's all done.
    Spare Parts and ACEkraut like this.
  16. Jan 3, 2017 at 1:19 PM
    #336
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Post some ongoing progress pics so we can all live vicariously through you!:thumbsup::bowdown:
  17. Jan 3, 2017 at 1:21 PM
    #337
    Tac0maSteve
    East Bay, CA
    Will do. Playing the waiting game for parts right now.
  18. Jan 3, 2017 at 2:26 PM
    #338
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I built my RTMR box knowing I would never need 40 fuses. With that being said, I decided to use one side of fuses (20 in total) as my "negative buss" so that one of the posts into the box is for + and the other for -. I liked this cleaner look (no external buss bars) but it does mean I have to carry double the amount of fuses (since all power from the RTMR are fused at both positive and negative supplies. Fuses are cheap anyways.
  19. Jan 3, 2017 at 2:37 PM
    #339
    Tac0maSteve
    East Bay, CA
    Funny that you did this because I wasn't planning on doing the external bus bars either. Doing the same setup you're running. Running it was a 150a circuit breaker too. Is this what you did or did you use a larger fuse?
    rob1208[QUOTED] likes this.
  20. Jan 3, 2017 at 2:46 PM
    #340
    rob1208
    Rob
    SF Bay Area
    i just used the blue sea 100a circuit breaker
    https://www.amazon.com/gp/product/B0051P01BW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I like having the breaker cause I can easily flip it open/off when I need to tweak something on the box. Plus, I don't have to carry spare fuses.
    Spare Parts likes this.
