DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Sep 10, 2017 at 9:11 PM
    #401
    Roo1041
    Roo1041 Well-Known Member
    Riley
    Tuscaloosa, AL
    2003 Toyota Tacoma Prerunner
    aFe CAI 3" OME Nitrocharger shocks w/ 883 Coils Rear OME Dakar Leaf Pack 17x8 ATX AX324 Assault Wheels 265/70R17 BFGoodrich Rugged Terrain T/A Tinted Windows to match stock rears
    Thanks for the responses. I have read the first page many times. I guess I shouldn't have asked the first question as I knew that you could put them up there but was just wanting to know if the switch backings would fit haha
  2. Sep 10, 2017 at 10:20 PM
    #402
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It's a lot to absorb. I'll be doing it eventually after both my brain and wallet have absorbed enough. I've started acquiring bits but want to know more about what I'll be hooking up to it as well. That list is steadily growing but the more I know the better I'll be able to order correct parts. Take your time and reread it cover to cover until you have it down pat. If you're like me there's lots of new concepts and this is one place you really have to get right the first time.
  3. Sep 11, 2017 at 1:08 PM
    #403
    88tacos
    88tacos Member
    2008 red dbl cab trd sport
    Can i use 14 gauge wire for the switches?
  4. Sep 11, 2017 at 1:10 PM
    #404
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    sure, but overkill if you are just triggering relays.
  5. Sep 11, 2017 at 1:11 PM
    #405
    88tacos
    88tacos Member
    Its because i already have some.
  6. Sep 11, 2017 at 7:16 PM
    #406
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    This is music to my ears. You exemplify exactly why I wrote this tutorial. Research. Plan. Prepare. Learn. Build. Right on! Looking forward to seeing your install.
  7. Sep 11, 2017 at 7:18 PM
    #407
    tacozord
    2015 DCLB 4wd SR5
    Using switchbacks would have been nice. But they simply won't fit in the sunglass holder. That's why I built it the way that I did.
    Roo1041[QUOTED] likes this.
  8. Sep 11, 2017 at 7:55 PM
    #408
    bagleboy
    Scott
    Norcal, Santa Rosa
    Thanks, you've laid it all out so well I want to fulfill the promise.
    Technically I don't think so unless they simply don't fit. Awg14 is going to make a much thicker bundle going through the firewall and up the A-pillar.
    One question I'm trying to resolve is I'm planning on using an MF1050 compressor mounted somewhere aft of the drivers seat forward of the rear wheels(~8-10')and it uses calls for a 30A fuse which seems at the upper limit for the Bussman fuses and relays. Should I instead use a separate 40A fuse/relay with Awg8 or will awg30 w/30A relay be sufficient? The max tank size will be 1.5 gal w/ a 90-120psi switch and it won't be used for long, high volume fills(mostly air bag adjustments).
  9. Sep 11, 2017 at 8:36 PM
    #409
    tacozord
    2015 DCLB 4wd SR5
    According to the Specifications of this compressor, it's recommending a 30A fuse. Therefore, you should be good with 10AWG wire and a 30A fuse connected to the RTMR.
    https://static.summitracing.com/global/images/instructions/qin-mf1050 manual.pdf
    Keep in mind that the RTMR is rated for a total of 80A. So it's certainly rated to handle the compressor. You just need to heed caution when running multiple accessories that could potentially breach that 80A threshold. With that in mind, you simply need to use the correct gauge wire and fuse as I indicated above.
    Cheers!
    bagleboy[QUOTED] likes this.
  10. Sep 11, 2017 at 10:58 PM
    #410
    bagleboy
    Scott
    Norcal, Santa Rosa
    Thanks, a big part of planning is listing and tracking these various considerations. When I have a more complete idea of what all might be added I can decide whether any fuse/relays need to be outsourced if the total simultaneous current gets too high. I think the high current additions are likely to be short duration usage(compressor, heated seats, etc,) so I would just have to be careful to not hop in and start flipping things on willy nilly. And get an 80A breaker so I can say "oops", instead "crap!". Since joining I've spent many hours reading just a small portion of the amazing mods here trying to pick out what things I'd like to add. This popped up as one of the foundation mods. Some others are neither mechanical nor electrical in nature so they only wait in the wallet que. then again, I haven't nearly finished reading so who knows what I'll find.
  11. Sep 11, 2017 at 11:02 PM
    #411
    bagleboy
    Scott
    Norcal, Santa Rosa
    And thanks for the mf 1050 link, just what I needed since little of that is on the outside of the box(checked one out at pep boys).
  12. Sep 13, 2017 at 9:45 PM
    #412
    bagleboy
    Scott
    Norcal, Santa Rosa
  13. Oct 20, 2017 at 10:44 AM
    #413
    bagleboy
    Scott
    Norcal, Santa Rosa
    The most difficult thing about this is the shopping.
    ScottyR likes this.
  14. Oct 21, 2017 at 9:28 AM
    #414
    bagleboy
    Scott
    Norcal, Santa Rosa
    Ordered the rtmr so I can work on the mounting plate while I figure out how much other stuff to get.
  15. Nov 1, 2017 at 7:16 PM
    #415
    Slickrick0999
    Slickrick0999 Well-Known Member
    Rick
    2010 SR5 4x4 dblcab shorty
    Fixed console button Cabinet lock on panel under seat 2016 wheels
    So, has anyone added up the total cost of starting from nothing?
  16. Nov 1, 2017 at 9:26 PM
    #416
    bagleboy
    Scott
    Norcal, Santa Rosa
    Total cost is a moving target and depends on how you buy the parts to assemble it and the add ons like connectors, welding cable, fuses or circuit breakers, mounting panel, external buss bars, accessory connectors, switches, interior mounting panels... How much "it" costs depends mostly on what "it" is. Some places like Delcity have low or no minimums but the pieces cost a bit more. Still cheaper if you're building only one than buying the minimums from Waytek but if you're building several than it goes the other way. Plus there are some tools to buy which add up. The actual rtmr and 5 relays is ~ $50 shipped from Waytek if you order nothing else from them and put the rest of your kit together a la carte from several sources. Given the high degree of customization inherent in each build I don't see how a GB could work even if some poor slob were willing to bag up each of the many groups of parts and reship. The only options really workable are buy one that is maybe what you want or build one that is what you think you want and order heavy on connector parts. When I finally decide on my order I'll certainly post the total but it probably won't be the same as someone else's.
    rob1208 likes this.
  17. Nov 1, 2017 at 9:57 PM
    #417
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    ^^ this. I ended up going with the 40fuse/10 relay setup and bought most of the connectors, relays, and cables up front. Since I was buying so much extra, I probably spent closer to $400-500 in total but I have a bin full of parts to wire up future accessories and I rewired most of my existing accessories. Depending on what setup you go with, it could be cheaper, same, or more expensive than what I spent on my setup
  18. Nov 1, 2017 at 11:47 PM
    #418
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    I spent roughly $500 for parts and tools. But I got enough stuff for two RTMRs and one set of upgraded battery terminals/cables. Add another set of battery terminals plus an 80 or 100 amp breaker and I can complete the second setup.
    If price is your main concern, just buy one already made. Also worth noting, I did NOT buy the molex crimper. I am a believer that you should use the right tools for the job but I wasn't about to buy a $50 tool I was gonna use once. I managed without it but having that tool would have been much faster/smoother.
    rob1208 likes this.
  19. Nov 2, 2017 at 6:41 AM
    #419
    Slickrick0999
    Rick
    Price is always a concern lol.
    I like the idea of building it myself just because I like to tinker.
    If I could buy one with the same quality I might consider that but I do not know where to buy?
    Thanks
  20. Nov 2, 2017 at 11:48 AM
    #420
    bagleboy
    Scott
    Norcal, Santa Rosa
    Check the op but I think there are one or two places listed there where you can buy the rtmr alone already assembled. You would still need to put together a kit for the rest of your connections though.
