DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Mar 7, 2018 at 12:59 PM
    #541
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Good to hear, should have mine this weekend or early next week, I will update the thread once I have it installed.
  2. Mar 7, 2018 at 1:01 PM
    #542
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Sounds good. Mainly curious how people are connecting the Bussmann to the accessories. I've seen some threads that attach plugs to the end for easy disconnect. Is this how you will wire it?
  3. Mar 7, 2018 at 1:05 PM
    #543
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Nah, I'm going to just solder the leads together or use the crimps that come with the RTMR, and a bus bar for the grounds. Plugs are fine, but I don't see the point if you are not removing or moving whatever is wired around often.
  4. Mar 7, 2018 at 1:12 PM
    #544
    Voltron4x4
    Denver, Colorado
    This and that...
    That's what I figured. Thanks!
  5. Mar 7, 2018 at 1:17 PM
    #545
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    im going to quick connect my stuff, I want to be able to isolate stuff if need be.
  6. Mar 7, 2018 at 4:44 PM
    #546
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    You can just pull the fuse for that as well.
    Spare Parts[QUOTED] likes this.
  7. Mar 7, 2018 at 5:02 PM
    #547
    Spare Parts
    Southern Maine
    True.
  8. Mar 9, 2018 at 2:43 PM
    #548
    4T3Underhill
    4T3Underhill Well-Known Member
    Dustin
    smogland
    2012 Tacoma TRD Pyrite Mica
    Amazing write up! I’ll absolutely be using this for my Tacoma. I use to use the blue sea fuse box, but this Bussmann option looks much more professional and clean. Nice work!
  9. Mar 9, 2018 at 8:40 PM
    #549
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    If you want some ideas check out the thread "show off your aux fuse panels" thread
  10. Mar 11, 2018 at 11:17 AM
    #550
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
  11. Mar 11, 2018 at 12:22 PM
    #551
    4T3Underhill
    Dustin
    smogland
    Thanks!
  12. Mar 18, 2018 at 2:28 PM
    #552
    Mako99
    Mako99 Well-Known Member
    Virginia
    2012 Taco Sport
    Quick (hopefully) question. I’m about to connect my rigid back up lights. Most of the wiring is straight forward. Any ideas what to tap into and where for auto on with reverse lights? Is there a wire to tap into in the cabin to tell the lights to turn on when in reverse?
  13. Mar 18, 2018 at 7:01 PM
    #553
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    https://www.tacomaworld.com/threads/oem-camera-connection-below-dash.30889/
    I hope the answer you are looking for is here. I would use it to activate a relay to turn on the lights when your backing gear is on. In my case I used this tutorial to have my stereo head unit to display the backup camera image.
    Mako99[QUOTED] likes this.
  14. Mar 18, 2018 at 7:10 PM
    #554
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'd use the factory backup light/tow circuit
  15. Mar 18, 2018 at 7:24 PM
    #555
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    https://www.the12volt.com/installbay/forum_posts.asp?tid=137166
    Perhaps I should have checked my sources before, the last link is only for the video. I did my stereo install almost 6 years ago... but now I just remembered I found the actual backing wire on this website.
  16. Mar 20, 2018 at 7:33 PM
    #556
    bburv
    bburv Well-Known Member
    Brian
    New Orleans, LA
    2013 Base Double Cab 4x4
    Alright guys, I need some help. I installed my completed Bussmann setup today and attached some Baja Designs fog lights and my existing CB power to it. Everything went well except now I'm getting some weird problems. My ABS and traction control light came on after about 30 minutes of driving. I didn't hit any buttons or switches, they just came on. When I shut my truck off, they went away but I haven't driven anywhere to see if they would come back on. Also, my Ultagauge went dark and just says "Scanning". Could this be a battery connection issue? I checked it and the terminals are on tight so I'm not sure what it could be. I did disconnect the battery before doing any major connections so that's why I thought that may be the issue. If anyone has any input, I'd appreciate it!
  17. Mar 21, 2018 at 3:19 AM
    #557
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Not sure about the abs and traction lights, but whenever the Ultra Gauge looses power it will do that. Just press one of the buttons, and it will scan and go back to normal.
  18. Mar 21, 2018 at 6:38 AM
    #558
    bburv
    Brian
    New Orleans, LA
    I tried pressing the buttons yesterday and again today with and still have the same screen. Is there some magic combination I have to do?
  19. Mar 21, 2018 at 6:54 AM
    #559
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Not with mine. Whenever the battery gets disconnected or it gets unplugged, I just hit the up or down button and it scans and starts working. Maybe unplug it and plug it back in with the truck off. Then start it back up. I've got an older EM model, so maybe there's something different with the newer model.
  20. Mar 21, 2018 at 6:57 AM
    #560
    bburv
    Brian
    New Orleans, LA
    That was my next thought, I’ll have to try it once I have some free time. Thinking I may have to do the pin jump as well for the VSC/ABS light so I’d have to unplug it anyway.
