DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Apr 3, 2018 at 8:39 AM
    #601
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Anyone? Bueller? Trying once more before I order Friday.
  2. Apr 8, 2018 at 8:41 AM
    #602
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
  3. Apr 8, 2018 at 10:09 AM
    #603
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    http://www.arbusa.com/uploads/PDF/airCompressors/airCompressorTechSpecifications.pdf
    I say yes. The max amperage of the compressor under load would be 22.9 amps. The maximum per circuit for the RTMR is 30 amps. I would ensure it is connected on a 10 AWG from the RTMR.
    Bottom line, ensure the maximum amps drawn from the RTMR does not exceed 80 amps combined at any given time. This is what the Bussmann 15303 series is rated for.
    SportsmanJake[QUOTED] likes this.
  4. Apr 8, 2018 at 10:36 AM
    #604
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ARB says that compressor draws 22.9 amps at 29psi, so figure up to about 30 amps at 40psi. Yes you can wire it to a Bussmann if the back of the Bussmann also uses 10ga wire on that circuit. It will limit your overall (same time) usage as Bussmann rates the buss bars at 80 amps.
  5. Apr 8, 2018 at 12:47 PM
    #605
    Philly100000
    Philly100000 Unknown Human
    Phillip
    Regina, Saskatchewan, Canada
    2011 Toyota Tacoma 4x4 DCLB TRD Sport Edition
    I think the proper way to connect an ARB compressor to the Bussmann is via the isolation switch and not with the power/ground leads because of the high amperage they put out. Instead leave the power/ground leads connected to the battery and have the compressor itself controlled through the isolation switch and your rocker switch via the bussmann. It won't matter that the compressor is wired directly to the battery because it will never start until your both your rocker switch is turned on and the isolation switch also is turned on from low pressure inside.
    Essentially it's the same thing as the wiring harness supplied by ARB, only you're reducing the amount of wires under your engine bay by going through the bussman instead. Mine is wired in this way and it works flawlessly
  6. Apr 14, 2018 at 5:33 AM
    #606
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    I would really like to build my own, but its cheaper to buy one from @Yotamac. But by the time you pay for all the minimums its gets expensive. Thanks for the write up it was a great read!!
    Quadabaum likes this.
  7. Apr 14, 2018 at 10:29 AM
    #607
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Thanks for the feedback. But everything in life is not necessarily about being cheaper. By building yourself you’re learning about how it goes together and that aids immensely in troubleshooting and install. And speaking of that, once you buy it, you’ll still need to install and add accessories. This will require tools and wire and connectors etc. So in the end, how much are you really saving? If you have questions, will the seller answer them all or will you come here to ask?
    Best of luck!
    Chapman, Badderup and Grand dude like this.
  8. Apr 14, 2018 at 10:31 AM
    #608
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    I enjoyed building mine not perfect ,but mine !
  9. Apr 14, 2018 at 2:11 PM
    #609
    Nazupag524
    Nazupag524 Well-Known Member
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Heavy ass pig sitting on 35s
    Mine is almost ready to call the engine bay Home. It’s been a long ongoing process but In the end I’m glad I built and not bought. 79281353-7E5E-40A7-8C25-1FE500C4DC19.jpg7726158F-476C-4B7B-99F2-0E508AE9F9BE.jpg
  10. Apr 14, 2018 at 2:37 PM
    #610
    tacozord
    2015 DCLB 4wd SR5
    Hell yeah! Looks great!!!!
  11. Apr 14, 2018 at 7:34 PM
    #611
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Thanks man. Your write up is a thing of beauty. Thanks for your time.
    tacozord[QUOTED][OP] likes this.
  12. Apr 14, 2018 at 7:35 PM
    #612
    tacozord
    2015 DCLB 4wd SR5
    So glad to be of help. I never thought the tutorial would have this much longevity. I'm beginning to think it was worth it. I really like hearing about and seeing pics of peoples builds and installs. It's awesome!!!!!!
    rob1208 and Nazupag524[QUOTED] like this.
  13. Apr 14, 2018 at 7:47 PM
    #613
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    All the cool kids are using it. :thumbsup:
  14. Apr 14, 2018 at 9:12 PM
    #614
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    Very useful for sure !!!
    I just build not only one, but 2 RTMR based on your work. One is a 15303-2, the other one, the one I will use, is a 15303-5. I intent to sell the other one within Canada once I complete it.
    I decided to build mine with a 15303-5 since I needed more flexibility between a negative or a positive trigger for the relays. Still working on it a bit but it is almost ready to be installed. I'll be posting pictures soon.
  15. Apr 15, 2018 at 12:36 AM
    #615
    tacozord
    2015 DCLB 4wd SR5
    Fantastic! Show some pics for sure. I’ve built two for my truck as well. One in the engine compartment that this tutorial outlines. The second one is slightly different, and I’ll get around to showing pics at some point. It’s in the bed of my truck for the auxiliary battery and accessories
    PzTank and elclem21[QUOTED] like this.
  16. Apr 16, 2018 at 5:20 PM
    #616
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    If anyone is interested selling me enough parts, minus wire, to build 1 of these I would be interested. Paypal at the ready.
    Ill buy wire also but its easier for me to get so I dont really need the specific amount for this kit.
  17. Apr 16, 2018 at 5:33 PM
    #617
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    She’s in!!! Just gotta terminate the harness inside and hook up power to the breaker. 5A8D7003-1ECB-4592-85B2-908065A67532.jpg
    SwampYota and tacozord[OP] like this.
  18. Apr 16, 2018 at 5:42 PM
    #618
    tacozord
    2015 DCLB 4wd SR5
    Looks good. Great feeling, eh?!?
  19. Apr 16, 2018 at 5:45 PM
    #619
    Nazupag524
    Jeremy
    Elizabeth, CO
    07 DCSB 4x4
    Hell yea. Like I said this project has been going on for way too long. Time to check another one off of the long list.
  20. Apr 16, 2018 at 5:52 PM
    #620
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
