DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Nov 24, 2018 at 6:54 AM
    #701
    bikesinmud
    bikesinmud Well-Known Member
    Washington
    Thanks, just need to source some connectors that will allow me to run the switches in a row and at the same time allow easy replacement if needed. To bad these won't allow for switchbacks.
  2. Nov 24, 2018 at 7:11 AM
    #702
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What? The switches have removable connectors. They're not hardwired with just wires hanging out the back. Just unplug the connector and hook up a new switch if a switch dies.
  3. Nov 24, 2018 at 8:00 AM
    #703
    bikesinmud
    Washington
    understood.
  4. Nov 24, 2018 at 9:39 AM
    #704
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Nobody makes switch backs with loose pins for the small push switch but since 3 of the 4 wires are common to all of the switches you can bundle/crimp those into 3 sets connected to 1 wire each and reduce it to the number of switches plus 3. If you use the dash dimming circuit for illumination then 2 of those come from inside the cab and if you grab switch power from a fuse tap then only 1 wire from each switch ends up going through the firewall. Edit- OP includes a deducated ground wire back to a ground buss which is a good idea since many problems stem from poor grounding. This ground wire isn't necessary if you use the stock dimmer circuit, only if you have grounded accessories inside the cab or don't use the dimmer circuit to ground the switch leds. Any accessories outside the cab would be grounded to the busses located at the Bussman. End edit
    One way to make the sets is by using a plug. Say you have 6 switches, you get a 6-way plugs and connect all of the common switch wires to one side and then daisy chain the feed to all the connections on the other side. You would then need 4 plugs, one for each of the power, illumination power, ground, and finally one for all the switch control wires. It's more tidy to just crimp and seal the 3 sets but easier to pull a pin from a plug than undo a crimped/soldered/heat shrink sealed connection. Since the switch bodies are universal that's unlikely but only if you're swapping a switch, other things can fit in those locations that don't have the same connector. My center console has 7 locations but 4 don't use the same connector, 2 seat heater controls, the AUX/USB port, and a 12V display USB charger, only the the 2 camera switches plus one remaining blank might use the common connector.
    I just used Molex mini fit jr plugs for all the connectors, they're available in 2,3,4,6,10 pins.
    bikesinmud[QUOTED] likes this.
  5. Nov 24, 2018 at 10:07 AM
    #705
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you don't have all your switches the plug idea makes it easy to add them later on as well, you just crimp pins onto the 4 wires and push each one into the appropriate connector. As long as your Bussman feed conduit has a wire for each possible switch location you're gtg.
    bikesinmud likes this.
  6. Nov 27, 2018 at 7:01 AM
    #706
    tacomavan
    tacomavan Well-Known Member
    Oregon
    i'll echo this statement. I've been around quite a few communities and boards in my day and this is one of the best, most comprehensive tutorials i've ever seen.
    and as someone who loves to tinker and learn, i say thank you sir. This is going to keep me busy for awhile
  7. Nov 29, 2018 at 11:01 AM
    #707
    brohirrim
    brohirrim Well-Known Member
  8. Nov 29, 2018 at 9:54 PM
    #708
    bagleboy
    Scott
    Norcal, Santa Rosa
    Switch backs just use female spade connnectors, this is why the toyota small push switch has no corresponding switch back, it uses a proprietary connector with leads.
  9. Dec 2, 2018 at 5:17 PM
    #709
    bikesinmud
    Washington
    Apologies if this was previously discussed, but what accessories are safe to run from the non-relayed side? I was planning on using the relayed side for my LED light bar, Driving lights, Air compressor, winch power. And the non relayed side for bed lights, rock lights, rear/back up lights and some under hood lights. (still waiting for a few more supplies and I start building!)
  10. Dec 2, 2018 at 7:47 PM
    #710
    bagleboy
    Scott
    Norcal, Santa Rosa
    It depends on switched or unswitched and if switches are used, what kind. For just a power run whatever the wiring and the fuses that fit will allow such as awg10 for 40A. For one of the tall left dash switches, they are rated for 20A but for the toyota small push switch(center console switches) only 3A. Keep in mind the total simultaneous amp draw for the Bussman is 85A and the Blue Seas is 100A.
  11. Dec 11, 2018 at 9:11 PM
    #711
    Pyrotech
    Pyrotech Well-Known Member
    This should be a MUST read for anyone planning on doing any electrical add-on to there vehicle. This will eb going to to the top of the mod list.
  12. Dec 11, 2018 at 9:43 PM
    #712
    LandLover
    LandLover Well-Known Member
    Andrew
    17 Tacoma Limited
    Can anyone subbed on this thread help me locate where I can get a bracket to hold RTMR and breaker for my 3rd gen?
    If that is not an option any longer share best possible areas to mount?
  13. Dec 12, 2018 at 2:38 AM
    #713
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    @paranoid56 has made trays for people. I don't know if he does 3rd gen or just 2nd gen.
    There's also PowerTrays.com.
  14. Dec 12, 2018 at 5:15 PM
    #714
    PowerGuy
    PowerGuy Well-Known Member
    Mac
    Holden Beach, NC
    17 TRD OR Access Cab, 4x4
    FN FX Pro wheels/265/70/17 Nitto Terra Grapplers G2
    Try tacomapros.com
  15. Dec 21, 2018 at 4:00 PM
    #715
    Pyrotech
    anyone sell a kit with all the components? I am a rather build this, but with the minimum order on the pieces, it prices it higher than buying one.
  16. Dec 22, 2018 at 7:30 AM
    #716
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    try @Sandman614
  17. Jan 8, 2019 at 7:21 PM
    #717
    timinNC
    timinNC Well-Known Member
    tim
    2008 tacoma - super white
    flatbed and working on more
    is there an option to do this with more fuses??
  18. Jan 8, 2019 at 8:47 PM
    #718
    bagleboy
    Scott
    Norcal, Santa Rosa
    There's a larger 10 fuse/10 relay unit or you could add an additional fuse only box(4, 6, 8, 10 fuses) with another fuse or breaker feeding it. A lot of people do that anyway to have a fuse box closer to what it feeds. Such as another bussmann or fuse box in the bed with a secondary battery. In my case I put a small 6-way under the center console and sanded the tabs on the cup holder to ease access. I also split it so that 3 are always hot and 3 are ignition hot. Remote fuse boxes can allow you to substitute a single long heavy wire feeding several much shorter small wires and is one way to tidy things up.
    timinNC[QUOTED] likes this.
  19. Jan 12, 2019 at 6:40 PM
    #719
    Taco-Obsessed
    I'm wiring up my switch panel. Does anyone see anything wrong with jumpering all my positives together and powering them with the add a fuse wire? I would also jumper all my grounds together. Just skipping the whole tapping into the pos and neg dimmer wires. Don't care if the switches don't dim. 6 @OTRATTW switches using a beautiful @Iggy switch panel. 18 gauge wire.
  20. Jan 12, 2019 at 7:38 PM
    #720
    Taco-Obsessed
    Their 5 pin switches. upper and lower LED lights. two pos (power to switch and LED) and two ground. The fifth is the power out to the relay to switch the relay to power the accessory. I am asking about jumpering the two pos and two neg, not the 5th pin to the relay Maybe I'm using the wrong lingo or misunderstanding your response (thanks for the response by the way @Blackout14 ). The OP tapped one pos and one neg to the dimmer wires to be able to dim the switches. I want to skip that all together and jumper both pos to the add a fuse and jumper both ground together. Hope that makes sense. It works with a 9v on one switch. see any issues doing it with all 6 and an add a fuse (power with ignition) for all 6? Different approach than the OP.
    Blackout14 likes this.
