DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Nov 7, 2015 at 11:42 AM
    #61
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'm just heading out but the quick answer is you need to bring power to your relay coils (via switches) from a source that is only live when the truck is started. I believe there are IGN fuses behind the dash that meet that criteria.
    - add a fuse from slot that is only hot when truck is started
    - run that to your switches
    - out from switches to relay coils
    - main power running through relays from battery
  2. Nov 7, 2015 at 11:52 AM
    #62
    InTheRough
    InTheRough Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I was having a similar conversation with Iggy on PM. This would only help for items that are relayed.
    There is no switch for these items except on the items themselves. If the power is constant, they will stay on unless I turn each item off. For instance, if I have my seat warmers set on "3" on the dial, they would stay on at "3" (even if the truck is off) until the batteries are drained. Which can also be viewed as a safety hazard if the seat warmer wiring fails.
    I am really just interested in shutting off the power to this positive terminal of the box completely unless the ignition is on. I am just having a hard time finding a cheaper solenoid solution that is on when low amps are applied and off when the low amps are removed. I'd rather not pay $160 for the ML-RBS but that is what it is made for. I think the SL-ACR is a decent solution but I don't know if it could handle the constant power or, if it is like the ML-ACR, it needs a jolt of power to open and a jolt of power to close.
  3. Nov 7, 2015 at 12:15 PM
    #63
    bayrak
    bayrak Well-Known Member
    Vancouver Island
    White 2008 DCLB TRD Sport
    Coastal Offroad Armour, Flippac, Ion Alloy Ion Rims , 285 BFG Ko2, Next Level Audio System, Uniball UCA, FOX 2.5 CO's
    Awesome Writeup! Thanks for putting in the time to share with us! Cant wait to start this project1
  4. Nov 7, 2015 at 4:01 PM
    #64
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I installed a solenoid like what you are showing, except I got a marine one that is water proof. I then put a fuse tap on an accessory (key on -hot) into the fuse panel under the dash on the drivers side and ran that back to the solenoid. So I came off the battery with a battery cable to the solenoid and then to my Bussman panel. I can take some pictures and post them if you like... Sorry unless that is considered thread jacking, then pm your email and I will take the pics and send them with a better description.
    :cheers:
  5. Nov 7, 2015 at 4:08 PM
    #65
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Do you happen to know the model number of the solenoid that you used? I just placed an order for this solenoid but still am not convinced it is the more appropriate:
    http://www.amazon.com/dp/B008R1T5IM
    I understand how it would all go together, just not sure which part is the most appropriate for the application.
    I'm not the OP but it seems pretty relevant to the topic.
  6. Nov 7, 2015 at 4:17 PM
    #66
    floodedkiwi
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    Here is the one I purchased
    http://www.delcity.net/store/Soleno...sulated-Continuous-Weather-Resistant/p_743396
  7. Nov 7, 2015 at 9:54 PM
    #67
    DesertBighorn
    DesertBighorn Active Member
    Doug
    WA
    14 DCLB 4x4 MGM
    Wow!!! Incredible write-up. Thanks for the detail. It must have taken a long time to put this together.
    -Doug
  8. Nov 8, 2015 at 7:49 AM
    #68
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    I haven't researched what specific part I would use to achieve what you're asking for, but a solenoid is what's needed. In this case, run a wire from your fuse panel ACC circuit(or similar) to switch the solenoid when the ignition is on. Then the Bussmann would receive power through the solenoid. You just have to make sure the solenoid is rated at 80 amps or higher.
  9. Nov 8, 2015 at 7:51 AM
    #69
    tacozord
    2015 DCLB 4wd SR5
    No problem at all. I've said this previously...this is only one way to build and install one. There are various modifications and adjustments available. So I'm all for learning a different or more efficient way to do something. If you have something to add, them go for it!
  10. Nov 8, 2015 at 11:04 AM
    #70
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Thanks for the response. I actually ordered this solenoid yesterday and should be here tomorrow. I found a member talking about it on the FJ forum I think.
    http://www.amazon.com/gp/product/B000CEBXRS
  11. Nov 9, 2015 at 7:07 AM
    #71
    SunSetPrez
    SunSetPrez Well-Known Member
    Orange County
    This awesome
  12. Nov 9, 2015 at 7:51 PM
    #72
    Killbuzzjrad
    Killbuzzjrad Well-Known Member
    Jared
    San Antonio, TX
    2009 DCLB TRD Sport 4x4
    Love this write-up. This is going to help me tremendously. Much respect.
    :thumbsup:
    tacozord[OP] likes this.
  13. Nov 10, 2015 at 9:24 AM
    #73
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    WOW! Informational treasure trove here... Very nicely done!
    The parts and tools section alone is awesome! Then the tutorial to boot...
  14. Nov 11, 2015 at 7:07 AM
    #74
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Remarkable effort. Incredible contribution. This is textbook material. I can't imagine the total time it took to put the tutorial together.
    Crom and tacozord[OP] like this.
  15. Nov 11, 2015 at 4:45 PM
    #75
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    I've just ordered some of the parts to start on this...I was in NO WAY thinking there would be this level of detail in a diy thread. I'm not 100% sure I'll go to the intricate details with all the connectors you did but I'm a fair bit OCD myself so I'm probably gonna bring up the waytek website here again shortly ;) This really is one of the best write ups I've ever seen....you win the Internetz
  16. Nov 11, 2015 at 4:56 PM
    #76
    tacozord
    2015 DCLB 4wd SR5
    The way I built mine is only one way to do it. Of course, the decision to use connectors or not is personal as is the type of connector. So I'd like to think that mine is a very flexible install. If you're able to gather enough info from the tutorial to help you with your install, then I achieved my goal. Best of luck and feel free to share your install. I'd enjoy seeing pics.
  17. Nov 11, 2015 at 5:09 PM
    #77
    commonsense87
    commonsense87 Well-Known Member
    Noah
    Edwards, CO
    2013 DCLB w/ Flatbed
    35’s and a flatbed ‍♂️
    subd! Thanks for all the info, definitely going to help me get the ball rolling for my next project.
  18. Nov 13, 2015 at 12:18 PM
    #78
    diverdale
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    all my parts have been ordered :thumbsup:. The min quantity stuff included so I'll have some extra connectors and whatnot but that's cool. I love those connectors. Already have most of the crimp tools and cutters. I should be starting on mine next week
  19. Nov 13, 2015 at 12:37 PM
    #79
    tacozord
    2015 DCLB 4wd SR5
    Awesome!!!
  20. Nov 13, 2015 at 12:55 PM
    #80
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    How much did everything cost you?
