DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Jun 5, 2020 at 2:29 PM
    #941
    SigBoy
    SigBoy Well-Known Member
    2020 TRD Off-Road, Access Cab
    The minimum order quantity for many of the items on the parts list is above and beyond (especially the wire), so I imagine there might be someone here that has done this project and is sitting on a bunch of extra parts. Perhaps you would like to recover some of the cost and sell me some of it?
  2. Jun 5, 2020 at 2:32 PM
    #942
    Sh2
    Sh2 Well-Known Member
    2016 Tacoma SR5 Double Cab
    Ovtune 2.0, Prinsu, 4xinnovations sliders, Southern Style Offroad Slimline with Warn VR Evo 10s
    SigBoy[QUOTED] likes this.
  3. Jun 11, 2020 at 5:23 AM
    #943
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Hey fellas, I’m the middle of my build and managed to goof up one of my connectors on the Bussmann. In mucking with it, I pulled the wire loose and of course the pin stayed in the Bussmann. What tool do I need to get that puppy out?
    Thanks!
  4. Jun 11, 2020 at 6:18 AM
    #944
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Check out this video to see if it will help you.
    PzTank likes this.
  5. Jun 11, 2020 at 1:07 PM
    #945
    RushT
    North Texas
    Appreciate that. I have some tiny screwdrivers and will try and give that a try. Last night didn’t work, but I wasn’t so aggressive with the torque.
  6. Jun 11, 2020 at 2:11 PM
    #946
    ACEkraut
    Aaron
    Durham, Maine
    I have found gentle prying most effective. Just keep moving the pick around while gently pulling on the wire on the backside. Also, take a look at one of the pins that is identical but not inserted yet to see Where you need to pry and what you need for a motion to release it.
  7. Jun 11, 2020 at 2:22 PM
    #947
    RushT
    North Texas
    :). Wire’s already out. That’s the big issue. I noticed after I’d added my 4th accessories harness that I’d forgotten to put the little blue keeper on it. With a well applied shrink tube, it wasn’t going to go in so I was going to have to disassemble it to redo the tube and keeper. That’s when the wire tugged free.
    Add: the pin isn’t out.
  8. Jun 11, 2020 at 4:30 PM
    #948
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Use one screwdriver or thin probe to release and a second to push the terminal out. Done correctly it shouldn’t take much force at all so be careful and patient.
    SR-71A likes this.
  9. Jun 12, 2020 at 8:46 PM
    #949
    RushT
    North Texas
    Finally hit the magic rain dance and the scrub i had left in there popped free.
    Progress, a little peeved about making the first one a little too short but decided not to redo it.
    885A17A9-3EF5-42BA-9BEB-D62BEB76C335.jpg 62EE1AE2-A624-40ED-B42F-EE97DC5579A1.jpg
  10. Jul 2, 2020 at 4:42 PM
    #950
    ECE208
    ECE208 Active Member
    Evan
    Idaho
    2013 White Access Cab Tacoma SR5
    Never done any wiring at all before. But I just ordered everything to build one. How would I wire the Cali raised LED switches? Also looking for a plate to mount everything to. I have a 2013 2.7 MT access cab 4x4 if that helps
  11. Jul 6, 2020 at 3:24 AM
    #951
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Welcome.
    Read, or re-read @tacozord ’s first few posts in this thread esp this one on installation:
    https://www.tacomaworld.com/threads...n-rtmr-fuse-relay-block.399454/#post-11086094
    EVERYTHING you need to know is included.
    If you’ve never done any wiring before and have to ask how would you wire the LEDs, you might not have the requisite knowledge to do a safe build and install of the bussmann. You might want to reconsider and buy a pre-assemble one then have someone install it for you. This can be dangerous. Trucks do burn...
    As to where to get the mounting plate, that too is covered in the lessons at the beginning of this thread.
    Good Luck. Be Safe.
    tacozord[OP] and SR-71A like this.
  12. Jul 6, 2020 at 8:44 AM
    #952
    ECE208
    Evan
    Idaho
    I likely don't have all the knowledge to do the install. But I'm trying to learn it. I'll have to reread his original post a few more times for sure though! My confusion is the switches I was looking at using only have 4 connections instead of 5. So I don't believe they dim. Just on or off with the dash lights or when toggled depending on how I wire them. The description on the Cali Raised LED site isn't that great so I'm just trying to see if these switches will work for me the way I want them to. And the mounting plate options seem to be all for automatics is why I asked. A member was making them and did a group buy but that's no longer available. I was just wondering if anyone else had any suggestions to save me from searching haha. But I will continue the search. I appreciate the response though and thank you for your help.
    PzTank[QUOTED] likes this.
  13. Jul 7, 2020 at 3:11 PM
    #953
    bagleboy
    Scott
    Norcal, Santa Rosa
    They do dim. Cali-raised uses the same switches found all over the net. They have 5-pin connectors but only 4 wires are used(Unless you have the double switches). Two are for the switch function and the other two are power/ground for the independent led. The switch dependent led get power from the switch and shares ground with the independent led. Dimming is done on the ground side so it doesn’t affect switch function. Because of this dimmer ground is not th same as chassis ground.
  14. Jul 11, 2020 at 3:13 PM
    #954
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    1st, thank you OP. There was a ton of time and effort that was put into this post and it has helped a lot of people understand a bit more about auto electrical. Thanks.
    Final finished be install today. I wanted an OEM type look - meaning if someone other than a Tacoma World member looked under the hood, high probability they won't notice the install.
    Designed a bracket and had a 3rd party cut/bend it. Made a 'through hole' midi fuse holder, by mounting two Littlefuse midi fuse holders (midi 498) on either side of the panel. I found some nylon washers at Home Depot I used to isolated the threaded rod than passes through the bracket. The 80A midi fuse can be accessed top side, but the wires are hidden bottom side. Here are some pics:
    20200711_125350.jpg 20200711_125417.jpg 20200711_125514.jpg 20200418_103419.jpg 20200216_155150.jpg 20200216_155242.jpg 20200216_155536.jpg
  15. Jul 11, 2020 at 3:32 PM
    #955
    Pyrotech
    Pyrotech Well-Known Member
    NICELY DONE!
    it does look very OEMish.
    PzTank likes this.
  16. Jul 15, 2020 at 10:29 AM
    #956
    ECE208
    Evan
    Idaho
    So since they share a ground, would I just not use the independent LED ground wire in the wiring harness that connects to the bussmann? Like I could just use the ground that connects to the external buss bar? I'm sorry this is so basic. I'm just trying to understand how to do a clean install.
  17. Jul 15, 2020 at 4:27 PM
    #957
    bagleboy
    Scott
    Norcal, Santa Rosa
    It takes awhile for all the details to become clear but once they do you’ll see that each individual part is simple, only the sum of all of the simple things makes it complicated.
    The ground wire from the the switch is only for the two leds. Connect it to dash dimmer ground if you want dimming or connect to any chassis ground including the one the Bussman is connected to for no dimming. Connect the switch power wire to a fused source and connect the led power wire to dash lights power(on with headlights only) or another 12v source including your switch power if you want them on with the switches. Keep in mind though, if you need any of your switches hot with ignition off that last one will be a parasitic drain on the battery. I do dash power and ground to make them all behave as stock switches, i.e. on with headlights and dim with the rest of the dash.
  18. Jul 24, 2020 at 11:28 AM
    #958
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Very nice!
    Pyrotech likes this.
  19. Jul 24, 2020 at 6:35 PM
    #959
    wally11
    wally11 Well-Known Member
    Mark
    2017 Black DCSB
    I have found a few places that you can buy kind of just what you need. I throw in the caveat that I have assembled the parts but have yet to build or screw anything up. I did add an error factor when ordering.
    https://ceautoelectricsupply.com
    https://www.customconnectorkits.com
    https://www.electricalhub.com
    The tray and switches are what they are. I did have the 4awg wires/parts professionally crimped. Also note mounting locations can differ and that the OP is a great photographer because this stuff is small. Fat fingers beware lol.
    tacozord[OP] likes this.
  20. Jul 26, 2020 at 6:20 PM
    #960
    tacozord
    2015 DCLB 4wd SR5
    Thanks dude!
