DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Oct 15, 2020 at 10:26 PM
    #1021
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Remember, each fuse or relay slot is limited to 30A so a single 75A trailer circuit should be separate from the Bussman and have a dedicated fuse or breaker. I’d recommend a breaker so you can easily de-energize the circuit when not towing. Any individual circuits(lights, trailer brakes, etc) that don’t exceed the 30A per circuit limit can be run through the Bussman so if it’s just the total that exceeds the limit then you’re gtg. Also, beyond the 5 relays housed in the Bussman you can use any of the other 5 fuse slots to supply power to 5 more remote relays so it’s possible to have the Bussman supply power to up to 10 relays but only 5 of them would be built in. Just remember, the 80A limit applies to what you can have on at any given time. Just as your house electrical panel carries more in breakers than it can safely supply so can the Bussman(add up all those 20A and 15A breakers and you’ll see what I mean).
  2. Oct 17, 2020 at 7:47 PM
    #1022
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Did you get this powdercoated? Have it coated yourself? Or rattle can?
  3. Oct 25, 2020 at 9:05 AM
    #1023
    inthebed
    inthebed Well-Known Member
    2010 Tacoma TRD Off-Road Prerunner
    I will be buying a large number of parts for my cooper busman to build two of them for my Tacoma and a 4Runner.
    If anybody is interested I’ll piggyback my order and buy them what they need to make this. I’ll probably be ordering next month! :)
    All I ask is a fair extra cost, that’s still cheaper than going the route of buying it all from the websites mentioned in guide. I totaled it and it came out to about: 300 due to outrageous minimum parts purchases. So please feel free to DM me.
    PzTank likes this.
  4. Oct 25, 2020 at 9:13 AM
    #1024
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I also have some parts lying around from the minimum order number I had to get when I built mine. I can let you know what I have and maybe we can work something out.
  5. Oct 25, 2020 at 9:19 AM
    #1025
    inthebed
    That would be awesome. I need enough for two of the 15303-2-2-4 .
    saundern[QUOTED] likes this.
  6. Oct 25, 2020 at 11:28 AM
    #1026
    bagleboy
    Scott
    Norcal, Santa Rosa
    DelCity has all the stuff you need(Bussman, relays, terminals, connectors, breakers, fuses, even wire at good prices) except the Tacoma specific mounting plate along with lower minimums(low enough you don’t have extras if you don’t want them) and if you go over $99 shipping is free(not hard with one build and almost unavoidable doing two). Under $99 and it’s better to buy elsewhere but I’ve yet to find a place that can beat them if you do spend that much.
  7. Oct 27, 2020 at 2:40 PM
    #1027
    Pyrotech
    Pyrotech Well-Known Member
    Rattlecan...
    Gave it a good sanding ro rough it a bit and tk remove the oxide. Then an acetone wipe, etching primer and then filler primer , sanding with some.fine sandpaper repeat filler primer then a several.coats of satin black.
    Once I get the bigger powder coat oven done, I might pull it off and beadblast and powdercoat it.
    SR-71A likes this.
  8. Oct 31, 2020 at 12:41 PM
    #1028
    wally11
    wally11 Well-Known Member
    Mark
    2017 Black DCSB
    So I’m ready for switches. Has anyone found some mini-switches of good quality that you could fit 4 into the change pocket area on the left side? I know they make 3 please panels for oem style or Carling type rockers but I want to fit 4 in there. S-tech sells some but I was wondering if there are others and also how people are doing their switch layout if not doing the OP’s method. I have crawl control there and no sunglasses pocket. I like MeSo’s panels but they have not come up for sale.
  9. Oct 31, 2020 at 1:07 PM
    #1029
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    You could use some "double" switches. They are available from a number of sources. You just need to source a face plate for the "tall" Toyota switches like this one.
    https://www.extremeterrain.com/cali...VBwCGCh0cLQAxEAYYAiABEgJyuPD_BwE&gclsrc=aw.ds
  10. Nov 6, 2020 at 2:52 PM
    #1030
    Warpig9k
    Warpig9k Active Member
    I notice a lot of people using the blue sea fuse box or the switch pros setup. Those do not have relays. Are they not worried about having so much power going straight to the switches?
  11. Nov 6, 2020 at 6:02 PM
    #1031
    bagleboy
    Scott
    Norcal, Santa Rosa
    Doesn’t the switch pros use solid state instead of relays? FET’s can handle way more than 30 or 40A. The “switches” on the switch pro only handle signal level current.
  12. Nov 6, 2020 at 7:46 PM
    #1032
    bagleboy
    Scott
    Norcal, Santa Rosa
    CustomConnectorKits has 10% off for November, use TURKEY10
    inthebed likes this.
  13. Nov 7, 2020 at 5:03 PM
    #1033
    inthebed
    Has anybody installed switches to the right side of the left oem dash switches, behind the oem driving light switch/brights for driving, location?
    I plan on installing 3 ch4x4.com swtiches there with their mounting plate and was just wondering if there's enough room behind that location or if it's possible to make enough room behind it.
  14. Nov 7, 2020 at 8:16 PM
    #1034
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yes, there’s room. Uh, wait, you mean to the right of the upper row of switches? I just checked and there’s frame and stuff behind there. Maybe enough room for one or at most two but the surface is curved and the ch4x4 panels are flat. You’d be better off with an IGGY panel in the center cubby or around the cup holders
  15. Nov 7, 2020 at 8:37 PM
    #1035
    bagleboy
    Scott
    Norcal, Santa Rosa
    I also added one to the armrest panel.
  16. Nov 8, 2020 at 5:15 AM
    #1036
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    :popcorn: pics??
  17. Nov 8, 2020 at 7:49 AM
    #1037
    bagleboy
    Scott
    Norcal, Santa Rosa
    Not of that one but my sig link shows how I made panels that go in the center cubby and also replaced the 4-slot/2 power ports with 7 small switch slots. I basically added more abs to the back side of the armrest panel and made a router jig to cut a stepped hole for the rocker switch to snap into. It made sense to me to put my sliding window control with the other window controls.
  18. Nov 15, 2020 at 11:02 PM
    #1038
    Londo-Cat
    Londo-Cat Well-Known Member
    Guy
    2020 SR5 4x4 v6 w/predator package & midnight black metallic
    TRD Skidplates (Front/Back) Predator XP package
    I have to say I was completely impressed by this post. Most informative - and exactly what I was looking for. Loved it!
    tacozord[QUOTED][OP] likes this.
  19. Nov 24, 2020 at 1:08 AM
    #1039
    inthebed
    What’s the difference between a 5 pin, and a 6 pin relay?
    Also which fuse should I tap for power so I can use a relay, on it’s own, almost like a switch to turn on or off something.
    Or can I do this with a 6 pin relay? And would I be better off with a 6 pin relay? Also what’s the max amps I can send to one of these posts if I was to steal ignition power to know it’s on for example a under-seat lighting kit.
    I also wanted to do this with switched power and a switch in the cab as separate, both on to activate just like the previous question, for the acc portion to hard wire a dash camera.
  20. Nov 24, 2020 at 7:14 PM
    #1040
    bagleboy
    Scott
    Norcal, Santa Rosa
    Not much, both are used to switch between two circuits but the 6-pin has two common terminals along with the normally open and normally closed pins plus the two coil pins. If all you want to do is turn something on you can use a 4-pin relay. A 5-pin relay can switch between two possible “on” choices. Connecting two 5-pin relays together you can make a reversing switch for motor control (windows etc.) or use a dpdt switch if it has sufficient current rating.
