DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Nov 24, 2020 at 9:15 PM
    #1041
    Londo-Cat
    Londo-Cat Well-Known Member
    Guy
    2020 SR5 4x4 v6 w/predator package & midnight black metallic
    TRD Skidplates (Front/Back) Predator XP package
    It depends on the particular relay itself - it could be SPST, SPDT, DPST, DPDT. So depending on what you want to switch on, off, or combo's of that.
    SR-71A likes this.
  2. Dec 3, 2020 at 6:52 PM
    #1042
    ufmurph
    ufmurph Active Member
    2019 Magnetic Grey DC OR
    Craftsman Garage Door Opener
    Thanks for the wright up! I used all the information as a basis for my build. Didn't come out as good as the OP but I'm pretty happy with it.
    PXL_20201127_190240389.jpg PXL_20201127_190214167.jpg PXL_20201125_204330671.jpg PXL_20201125_153603213.jpg PXL_20201122_193908958.jpg PXL_20201122_193901724.jpg
  3. Dec 5, 2020 at 1:04 PM
    #1043
    akaboras
    akaboras Member
    CA
    2nd gen 4x4s
    Big thank you @tacozord ! It took awhile and a few challenges along the way but I did it!
  4. Dec 12, 2020 at 10:11 PM
    #1044
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Made a little more progress on my build today. Wired the switch panel.
    A33B7F01-0870-466A-A16F-4941A4C66A0A.jpg 864FA7A2-DDA6-4A66-B9E0-66378D1AAE3D.jpg I added a few options not in the write up. Since the switches and relays will mostly be for lighting, I used dpst switches and will tap into the brights as well as the reverse lighting circuits. 4 of those switches will be tied to the brights, 1 to the reverse and all will also have fused ignition 12v. The 6th switch is just a spst switch that will just have ignition 12v power. Thinking I’m going to hook my cb to that switch so I can ditch the cigarette lighter plug I’ve been running. Need to order a couple of terminal blocks for the first 2 switches. I wired the bottom lights to work with the dash dimmer and wired the tops to come in when the accessory is on regardless of if it comes from the ignition power or the brights/reverse power.
    Big thanks to the OP for the excellent write up. I never would have tackled this project without it. It’s definitely given me confidence and taught me a lot.
    ready to get this thing installed and powering stuff!BA01DFDE-64BE-48C5-9A35-55BF883A546D.jpg
    tacozord[OP] and daveeasa like this.
  5. Dec 12, 2020 at 10:17 PM
    #1045
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Looks really clean! Good work!
    ToyotaDriver[QUOTED] likes this.
  6. Dec 13, 2020 at 8:44 PM
    #1046
    Londo-Cat
    Guy
    Started my Bussman RTMR Fuse/Relay Block project today. Been gathering the parts for a month now. Time to start.
    That's it for today. Tomorrow, adding the cable assemblies!
  7. Dec 16, 2020 at 9:35 AM
    #1047
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Awesome! I love how people are spring-boarding off the tutorial and adapting the knowledge to their own situation. Well done!!!
  8. Dec 16, 2020 at 9:36 AM
    #1048
    tacozord
    2015 DCLB 4wd SR5
    Looks like a good start! Great work.
  9. Dec 18, 2020 at 4:40 PM
    #1049
    Londo-Cat
    Guy
    OK - back to the Bussman RTMR Fuse Relay build. Did all the connectors - used 14 gauge on the right and 18 gauge on the left. I don't need 20 amp on anything right now - 99.999% is done with 15 amp or less. If push comes to shove - I can always switch out a 14 gauge wire with a 12 gauge one for anything that needs 20 amps (like a winch).
    Almost completed. Relays in - wired up and tested.
    Need a 6 port plug (on order...) now - have to make an Aluminum base for it. I know there are ones out there - but I want something real specific - and the ones that are pre-made are still too basic - so need to go *custom* (as usual) :101010:
    SwampYota, ufmurph and saundern like this.
  10. Dec 19, 2020 at 7:53 PM
    #1050
    WHIT4K3R
    WHIT4K3R Well-Known Member
    Salt Lake City, UT
    2016 Quicksand Tacoma TRD Sport
    Bilstein 6112/5160 with OME DAKAR Leaf Pack FN-FX PRO Wheels OVTune Mobtown Offroad Rock Sliders Avid Offroad Front Bumper Guard Falken Wildpeak Tires Prinsu Roof Rack & Ridgeline Handles Borla Catback Exhaust K&N Straight Pipe Intake Morimoto XB LED Headlights Depo TRD PRO Taillights -MESO V2 Upgrade MESO Puddle Pods with Switch MESO Ultimate DRL Turn Signals V5 MESO Red Start Button MESO Quicksand Interior Trim MESO Overhead 6-Switch Panel Rigid 30" E-Series Light Bar - Midnight Rigid D-Series Pod Lights - Midnight Rigid 360 Yellow Fog Lights StopTech Slotted Front Rotors - Cryo TRD Brake Pads OEM TRD PRO Grille Anytime Camera Anytime Front & Rear Camera Clazzio Beige Leather Seat Covers BPF TRD Skid Plate Relentless Fab Hi-Lift & Shovel Bed Mounts CMC SpiderTrax - 1.25” Spacers RDJ Fender Flares TacomaPros Busmann Fuse / Relay Box Custom Engraved Shift Knob
    After a few weeks of building and waiting on parts I’ve finally got this sucker installed and working like a charm... I really like this... 10/10 would recommend tackling this project! :D
  11. Dec 20, 2020 at 10:37 AM
    #1051
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Currents generally run higher in 12v systems than they do to accomplish the same thing off 110V. A 20A 12V winch might not pull a wheel barrow(most use heavy cable for that rather than “wire”). Even window motors are 5-10A. Even if it still works, running current through undersized wires leads to power loss and voltage drop making motors run slow, lights run dim, and fridges struggle to stay cold. While it’s certainly possible to go overboard with wire thickness, under sizing can be a false economy, especially when running off stored power. You probably already know that but it’s worth repeating. Wire length also affects what size makes a better choice since voltage drop is proportional to length. Some charts provide ohms/ft specs so you can easily determine whether a given size/length is overkill/acceptable/or inadequate to your needs.
    Area51Runner and tacozord[OP] like this.
  12. Dec 30, 2020 at 1:46 PM
    #1052
    Blain
    Blain I ain't got time to bleed
    Tx
    I'm about halfway through wiring the bussman and have a few questions regarding the OEM style switch. The only thing this will currently be running is a Diode Dynamic light bar. The light bar will be wired into the first relay/fuse block on the bussman. I have a OEM style switch that will be going in a blank in the dash.
    I'm planning to piggyback the dash light for the switch (RED 2) off the adjacent fog light switch.
    The (RED 1) wire connects to the switch harness and the specific wire in the harness we made for the first relay/fuse block, correct?
    My question, what does the (GREEN) wire connect to? The "add a circuit" wire put in our harness? Something else?
    If I'm only using OEM style switches, do I need the single "add a circuit" wire and the red/black stripe, brown wire in the harness we made?
  13. Dec 30, 2020 at 3:05 PM
    #1053
    Blain
    Tx
    After doing more reading I believe the (GREEN) on the switch is tied to the "add a circuit" hot/keyed ignition. Since I'm not running a full switch panel, and I'm piggybacking off the adjacent fog light switch for backlighting, I believe I can ignore the two conductor brown, red/black stripe wire. It's there if I expand in the future.
    So, GREEN to fused "add a circuit", RED 1 to bussman relay/fuse block for light bar, RED 2 to piggybacked fog light switch illumination, BLACK to ground.
  14. Dec 30, 2020 at 3:15 PM
    #1054
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Started a build of one of these and really wanted the ground bus bars but had limited room. Was working with a vendor on a new bracket and we discovered that you can just stack the mounting holes of the blue sea mini bars over the RTMR holes to save space. Looks like this (note there’s no ground going to the switch harness as my switches are grounded inside the cab to a variable ground for dimming):
    Figured someone might appreciate the idea if you’re struggling for space like I am.
    Puppypunter, WHIT4K3R and daveeasa like this.
  15. Dec 30, 2020 at 3:19 PM
    #1055
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Random question which is sort of appropriate for this thread. Has anyone done an in cab aux fuse box? If so, linky to a post or product would be much appreciated. TIA.
  16. Dec 30, 2020 at 3:20 PM
    #1056
    Blain
    Tx
    I'm cramped for space too and I already bought longer bolts to go through the bussman mounting holes, leaving enough to attach the bus bars with a nut on the backside.
    kmorgan3 likes this.
  17. Dec 30, 2020 at 3:29 PM
    #1057
    ufmurph
    The green is the power source through the switch to the relay. If you want your lights to work when the truck is off, you need to find a constant power source. I tapped into the "dome" light circuit in the cabin fuse panel. Red 2 connects to an accessory source so the switch lights up with your dash lights. I tapped the "IG1 NO2" circuit for that. The end result is, I can turn the lights on without the accessories on, and the switch lights up when the truck is running. If you want the lights to shut off when you turn off the truck you will need to find another fuse to tap into. Connect the wires to a 9v battery and you can see how the switch works.
  18. Dec 30, 2020 at 3:37 PM
    #1058
    Blain
    Tx
    Sweet, thanks.
  19. Dec 30, 2020 at 6:33 PM
    #1059
    bagleboy
    Scott
    Norcal, Santa Rosa
    I put an 8-way fuse panel under the cup holder(manual so it’s actually easier to access than the stock panel) and split the main buss so it’s 1/2 always hot and 1/2 ignition hot. Also added a grounding block. Ground and always hot 1/2 have #10 wire and ignition hot has #18(switch activation power so only a few amps) on an add-a-fuse. Actually 4-#10 wires bundled together come in under the driver’s seat just behind a stock grommet, panel hot&ground, compressor hot, plus an extra for fridge power or whatever. I have on board air with a manifold in the center console so that’s where my pressure switch is and puts that close to my compressor switch.
    Area51Runner likes this.
  20. Dec 30, 2020 at 6:57 PM
    #1060
    daveeasa
    David
    PNW
    It’s as if we share a mind? I’m of course way behind you but eyeing those grommets today for 4 gauge to amplifiers. Currently running off trailer brake controller but planning a dedicated line.
    photo of current state. Gonna hit you up for photos of yours via DM.
    C7E44C14-E5BF-41A3-93C4-1B213A7C3BCB.jpg CFAFD935-D643-4E98-A319-E6E23D76F7C1.jpg
    SR-71A and SwampYota like this.
