DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Dec 4, 2015 at 9:37 AM
    #101
    JStrider
    JStrider Member
    James
    TX
    2005 Jeep Wrangler Unlimited
    2.5" lift; Rocker Guards
  2. Dec 4, 2015 at 9:52 AM
    #102
    tacozord
    tacozord [OP] Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    I snipped that image out of the datasheet for the RTMR.
    As for the RFRM, here's the link to the Bussmann RFRM webpage at the Cooper Industries Eaton website.
    On this page, there are two links, one for the datasheet and another for a sales drawing.
    With regards to the RFRM, the drawings are not split up for each model like they are for the RTMR. But hopefully these links provide you enough information to answer your questions or help you.
    JStrider[QUOTED] likes this.
  3. Dec 4, 2015 at 9:54 AM
    #103
    JStrider
    JStrider Member
    James
    TX
    I hadn't been able to find that sales drawing. Thanks!
  4. Dec 4, 2015 at 9:56 AM
    #104
    tacozord
    2015 DCLB 4wd SR5
    Putting together a kit is not that difficult. But the heaviest cost is actually in the tooling and wiring. So I'm not sure if it would be worth it.
    Keep in mind that you have to buy minimums for the terminals and cable seals, and the cost of 100 components vs 20 isn't that big of a deal. Furthermore, when you're talking about a RFRM, you might as well just get the 100 minimum anyways because the box requires more. Last, one you thing you might not be considering is that mistakes happen during assembly. So you definitely want waste.
  5. Dec 4, 2015 at 10:03 AM
    #105
    tacozord
    2015 DCLB 4wd SR5
    Also wanted to let you know, that with the setup the tutorial outlines, power to the switches are provided from a fuse-tap off of the OEM under-dash fuse panel, which is live only when the ignition is on. This means that the five relay circuits are ignition on only. If this doesn't work for you, then you can switch to a different fuse off of the panel or route power in a different way.
    As for the fuses, they get power directly from the battery. So this means they're live all the time. Five are dedicated for the relay circuits, so you can't count them because they're associated with the switch power. But the other five fuses are live always. In my truck, I'm currently using two circuits. One is for my hood lighting and the other is for a dome light in my shell. Both of these can be turned on with the ignition off.
  6. Dec 4, 2015 at 11:32 AM
    #106
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    Makes this one seem like a steal!
    http://pma4x4.com/product/relay-box/
  7. Dec 4, 2015 at 12:15 PM
    #107
    tacozord
    2015 DCLB 4wd SR5
    Yes and no. It's not an exact comparison. While that box is cheaper, you're getting a lot less.
    You're not getting 10 Metri-Pack connectors, male and female.
    You're not getting a Weather-Pack connector, male and female.
    You're not getting Metri-Pack and Weather-Pack terminals, male and female.
    You're not getting Molex connectors to connect to the switch panel, male and female.
    You're not getting Molex terminals, male and female.
    You're not getting a long wiring harness to connect to the switch panel.
    You're not getting heat shrink and braided sleeving.
    You're not getting two external ground busbars.
    You're not getting 4AWG power and ground wires. Based on their pictures you're getting less.
    You're not getting 10AWG wire for all your accessories. Instead, you're getting 12AWG and 14AWG.
    You're not getting GXL or TXL automotive wire. Instead, you're getting GPT, which is rated at a lower temperature.
    You're getting a fusible link instead of an ANL fuse and holder.
    So with that said, not all of the above is required or even preferable for some people. But this is what I used for the tutorial and what is factored into the cost. Also, I'm not saying PMA4x4's box is unacceptable. If it fits your needs, then it would be a great box and recommended. In fact, I provided a link to it in Part 1 of the tutorial as an alternative.
    DrFunker, Blackout14 and kitsym like this.
  8. Dec 4, 2015 at 12:18 PM
    #108
    SportsmanJake
    VA
    2006 Tundra
    Thanks for the comparison! And thanks for the detailed write up. I was able to follow along and understand what you were talking about.
    tacozord[OP] and Blackout14 like this.
  9. Dec 4, 2015 at 12:20 PM
    #109
    G.T.
    G.T.
    CONUS
  10. Dec 8, 2015 at 6:33 AM
    #110
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    Yes!!! man i really need to do this.. I've dragging. also been so busy with work and side work every weekend. ugh! :(:annoyed:
    DrFunker[QUOTED] likes this.
  11. Dec 8, 2015 at 6:34 AM
    #111
    DrFunker
    DrFunker Well-Known Member
    Me too. May have to do this next mod season. :rolleyes:
    Dj Suisav[QUOTED] likes this.
  12. Dec 8, 2015 at 6:41 AM
    #112
    Dj Suisav
    Saul
    San Antonio, TX
    THIS IS AN ABSOLUTELY IMMACULATE WRITE UP. JESUS CHRIST!!! I THINK I NEED NEW UNDERWEAR!!!!!! haha I've been wanting to do this for the longest time. The placement is sexy as hell, and the cleanliness is absurd. BEST WRITE UP OF EVER!! MAD PROPS!!:annoyed::headbang::bowdown:
    Blackout14 likes this.
  13. Dec 8, 2015 at 6:42 AM
    #113
    Dj Suisav
    Saul
    San Antonio, TX
    After seeing this super clean setup. It will be my next mod. no doubt!
  14. Dec 8, 2015 at 6:42 AM
    #114
    Dj Suisav
    Saul
    San Antonio, TX
  15. Dec 8, 2015 at 9:11 AM
    #115
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
  16. Dec 12, 2015 at 5:13 PM
    #116
    CascadesTacoma
    CascadesTacoma Well-Known Member
    Seaside, CA
    '14 DCSB TRD OR
    2014 DCSB TRD OR
    Anyone know of a fuse slot in the engine fuse box which is "ignition on"? I have checked every damn slot with my multimeter and I think they are all "always on". I'm trying to wire up my solenoid. So far I've had to connect it to a random hot spot when I want to connect the batteries.
    Thanks
  17. Dec 15, 2015 at 8:52 AM
    #117
    Dj Suisav
    Saul
    San Antonio, TX
    Will do thank you!!
  18. Dec 15, 2015 at 10:13 AM
    #118
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Wow this has to be the most complete and informative write up I have ever seen on TW. Big props to you @tacozord! Thank you and great job, super informative! If it's OK with you I will getting in touch with you sometime in the near future.
    DrFunker likes this.
  19. Dec 15, 2015 at 12:18 PM
    #119
    Dirtboyz
    Dirtboyz Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    That is one hell of a complete and thorough write up. Bravo! Wish more people were like this on their DIY. Here is mine with a blue sea fuse block only have a 30" light bar and led hood lights into it know still haven't changed my power for the switch to the inside so the switch cuts off with the truck but haven't had any problems with it draining my battery. I just make sure the switch is off when I get out and yes I know it still pulls some power but not a lot I checked image.jpg
    Dj Suisav and DrFunker like this.
  20. Dec 23, 2015 at 3:02 PM
    #120
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    Hey OP just to kinda cut to the chase what would you say would be the price of one of these bad boys the way you built it in total at the end? Just trying to see if building my own will save enough to make it worth wild
