DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Dec 11, 2022 at 8:58 AM
    #1321
    r3k
    r3k Well-Known Member
    wow, read the entire thread, all 66 pages and i still dont understand half. never felt so dumb, the world should just kill me.
    mach1man001 likes this.
  2. Dec 11, 2022 at 10:04 AM
    #1322
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Relax, it is a lot but if you break it down and reread each of the first posts individually a few times it becomes clear. It just takes time to get familiar with each of the parts and also each step in the process. It definitely had my brain spinning forever awhile. It’s practically a new language but with a comparatively small vocabulary. Learning new things is what school was supposed to train us how to do. It’s a process and the op provided a well written textbook.
    Roof Walker and Area51Runner like this.
  3. Dec 11, 2022 at 10:59 AM
    #1323
    Roof Walker
    Roof Walker Well-Known Member
    SE Michigan
    2021 Tacoma TRD Pro MT
    Maxxis Militia
    That would make you normal, so don’t sweat it! I too read the entire thread, but also re-read many of the key posts… over and over, until my understanding and confidence improved. Just take your time and write out a list or two of what you are trying to accomplish and check them off as you make progress.
    mach1man001 and Area51Runner like this.
  4. Dec 11, 2022 at 11:20 AM
    #1324
    panicmonster
    panicmonster no
    Anchorage, AK
    2021 Mallcrawler Pro
    Check out quoted post below. @yodataco made the original content a PDF. I printed it and found it much more digestible in hard copy, and easier to reference when working on stuff, crossing items off the list, etc.
    yodataco[QUOTED] likes this.
  5. Dec 11, 2022 at 1:49 PM
    #1325
    bagleboy
    Scott
    Norcal, Santa Rosa
    This, I also found that as my understanding increased I was able to imagine how I might do things differently to customize it for my needs. Give yourself the time to allow for that.
  6. Dec 11, 2022 at 3:20 PM
    #1326
    r3k
    please let me know if i get this right, some other things confused me so i want to do the very basic.
    battery > breaker > bussman> switch > accessory
    i dont need anything else right?
    the blue sea confuses me, why does people still use it when the bussman have it's own fuse?
  7. Dec 11, 2022 at 3:31 PM
    #1327
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Can you share what your ultimate end goal is? What are you doing/planning to run?
    Here is what I did -
    https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/page-50#post-22048046
    SwampYota likes this.
  8. Dec 11, 2022 at 3:38 PM
    #1328
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Is that PDF available for all of us? It would be more convenient to use a document rather than a laptop...
  9. Dec 11, 2022 at 3:43 PM
    #1329
    r3k
    run 20inch diodedynamics on the sso bumper, run the winch, run the arb compressor and run the roof rack led thru the bussman. probably run 2-1 watt led on the inside hood so when u open the hood the led automatically turns on.
    i'm only gonna have to 2switches "inside" the winch switch and compressor will be in the hood, somewhere near the bussman.
  10. Dec 11, 2022 at 3:50 PM
    #1330
    Area51Runner
  11. Dec 11, 2022 at 4:22 PM
    #1331
    Scott B.
    Scott
    Georgia
  12. Dec 11, 2022 at 4:26 PM
    #1332
    r3k
    one of the things that confuses me is why use a blue sea fusebox when u already have a bussman?
  13. Dec 11, 2022 at 4:31 PM
    #1333
    Scott B.
    Scott
    Georgia
    Where are you talking about? The OP uses Blue Sea bus bars, not fuse boxes.
  14. Dec 11, 2022 at 4:32 PM
    #1334
    Scott B.
    Scott
    Georgia
    It's more like this:
    battery -> breaker (or large fuse) -> bussman -> accessory
    The switch output feeds into the bussman.
  15. Dec 11, 2022 at 4:36 PM
    #1335
    r3k
    i thought i saw it where there was a blue sea fusebox then to the bussman. that's what confused me. i think i messed up and combined all teh different threads i've been reading about this the last 2 days.
    thank you for the help.
  16. Dec 11, 2022 at 4:41 PM
    #1336
    Scott B.
    Scott
    Georgia
    A relay, in the bussman, is just a electronically controlled switch. The reason/advantage to using a relay is it can handle a lot of current (up to 30 amps) whereas a switch can handle about 2 amps safely. (Yes, I melted a switch in my younger years...)
    Keep rereading the articles - this is really a simple concept that will click in your head. You'll get it.
  17. Dec 11, 2022 at 4:41 PM
    #1337
    bagleboy
    Scott
    Norcal, Santa Rosa
    Since the Bussman has both fuses and relays the layout isn’t linear like your description.
    Battery feeds the Bussman which powers the relays through the built in fuses and then to the accessories but the switches are a parallel circuit.
    Battery> Breaker > Bussman fuse > Bussman relay> Accessory > Ground.
    Switch power (ignition hot or always hot fused source) > Switch > Bussman relay > Ground.
    The switch circuit activates the relays but the accessories get power from the fuse that supplies each relay.
    Area51Runner and Roof Walker like this.
  18. Dec 11, 2022 at 4:45 PM
    #1338
    Scott B.
    Scott
    Georgia
    BTW, the winch draws too much power to run through the bussman. You want the winch tied directly to the battery. See this post in my build thread: https://www.tacomaworld.com/threads/scott-b-s-2015-ac-build-expo-style.368814/page-13#post-22543143
    Area51Runner likes this.
  19. Dec 11, 2022 at 4:52 PM
    #1339
    r3k
  20. Dec 11, 2022 at 5:15 PM
    #1340
    Area51Runner
