DIY Bump Stops
Discussion in 'Suspension' started by RauthBjorn, Jan 24, 2022.
  1. Jan 24, 2022 at 4:11 PM
    RauthBjorn
    RauthBjorn [OP] Well-Known Member
    Bump stops are way overpriced. $300+ for four chunks of rubber? Not for me!
    After some searching, it appears Jeep people have been known to use hockey pucks, which are much more reasonably priced pieces of rubber.
    Anybody have any thoughts on good sources for 2-4" tall chunks of rubber? I'm quite certain there are better options that will require minimal modification and save hundreds of dollars. Even willing to raid a you-pull-it to source these.
    unstpible likes this.
  2. Jan 24, 2022 at 4:16 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Friday comes fast these days.
    :bananadead:
    I think you are misinformed, old school jeepers used hockey pucks for body lift, they would make horrible bump stops.
    The reason bump stops are expensive is the R&D to get the durometer just perfect for the application and to provide progressive dampening, a hockey puck provides no progressiveness.
    Buy once cry once there's a reason people pay $300 for them.
    That said check out wheeler's super bumps they're not that expensive (I assume you saw the Timbren kit and baulked.) Or the DuroBumps both good products purpose build and engineered vs something that won't work properly or will be potentially dangerous like a hockey puck or some repurposed stock part from another vehicle that would be even worse than factory.
  3. Jan 24, 2022 at 4:18 PM
    eon_blue
    Azusa, CA
    Hockey pucks are made of vulcanized rubber. They will break before they compress. Bad idea for a bump stop.
    Island Cruiser, unstpible and Key-Rei like this.
  4. Jan 24, 2022 at 4:20 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    Energy suspension or other companies make various universal bump stops that can be made to work at around $25 a pair.
    Edit: maybe a little bit more $ than what I said. Prices have went up in the last couple years. Also, full disclosure: I have superbumps front and rear.
    TVH475 and RauthBjorn[OP] like this.
  5. Jan 24, 2022 at 4:26 PM
    C-Rok275
    C-Rok275 Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    Prothane is another company. I had their body mounts and Energy bump stops on my old Suburban.
    RauthBjorn[OP] likes this.
  6. Jan 24, 2022 at 4:28 PM
    RauthBjorn
    Right, I was thinking that vulcanized rubber like a hockey puck would be too hard so I'm looking at any and all rubber chunks for random applications.
    For example, these bumpers are extremely cheap and are in the neighborhood of dimensions needed, while still providing some flexibility:
    https://www.amazon.com/Buffers-Chas...ds=rubber+bumpers&qid=1643070156&sr=8-65&th=1
  7. Jan 24, 2022 at 4:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  8. Jan 24, 2022 at 4:35 PM
    RauthBjorn
    It looks like Prothane and Energy Suspension have exactly the price range I'm looking for, for essentially the same form factor as the overpriced Duro/Wheelers/Timbren parts. As long as I roughly match the shape and size, I can't imagine the performance difference would matter enough to justify the extra $250-300 price tag.
    As posted above, McMaster has plenty of good options too.
    hilighter likes this.
  9. Jan 24, 2022 at 4:35 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  10. Jan 24, 2022 at 4:36 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
  11. Jan 24, 2022 at 5:56 PM
    RauthBjorn
    SIK99Tacoma, t1m829 and po35042 like this.
  12. Jan 24, 2022 at 7:07 PM
    RauthBjorn
    Alright I figured out a solution - for the rears, using these:
    https://www.amazon.com/15712438-523-049-Compatible-Chevrolet-Bumpers/dp/B08MQGR3V3?ie=UTF8
    I will use the Wheelers U-bolt Flip Kit, and then fabricate an adaptor bracket to mount from the Wheelers plate to the bump stops. I have a full machine shop at work, so the brackets will basically be free and cost no time.
    So I'm at about $60 for the bump stops and hardware, saving me about $230 compared to the cheapest commercially available kit.
    SIK99Tacoma, hilighter and t1m829 like this.
  13. Jan 24, 2022 at 7:22 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Who's paying $230+ for non air bumps?
    Naveronski likes this.
  14. Jan 24, 2022 at 7:30 PM
    RauthBjorn
    Not me! Got a link for anything cheaper? Looks like Wheelers, Timbren, and Durobump are all in the >$200-300 range for just the front and rear bumps.
    auskip07 likes this.
