DIY Camper Electrical Build (feedback wanted)
Discussion in 'Technical Chat' started by smoss33989, Mar 31, 2020.
  1. Mar 31, 2020 at 10:51 AM
    smoss33989
    smoss33989 [OP] New Member
    Steven
    2010 Manual Green Tacoma SR5
    Hey folks,
    I have been living/camping out of my Tacoma seasonally for the past few summers and fall and it is time to upgrade the power system.
    I decided to start with a system that runs off my alternator with the ability to add solar later if needed. Here is a crude drawing of what I plan to do. I would love to hear people's thoughts and feedback and if I am missing anything major. This is probably a very simple task but this is something I haven't done before.
    I plan to post photos of the build and updates on how it is working!
    Thanks,
    Steven
    2010 Tacoma V6
    6 Speed Manual
    Raysan210 likes this.
  2. Mar 31, 2020 at 9:14 PM
    Raysan210
    Raysan210 Well-Known Member
    Ray
    2010 grey Tacoma TRD
    asudevil likes this.
  3. Mar 31, 2020 at 10:23 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  4. Apr 1, 2020 at 10:54 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have a run that long in my truck (~18') I used expensive but efficient 00 gauge wire. IIRC there would be a 3% drop over that length with 00 gage at 13 volts.
  5. Apr 1, 2020 at 4:23 PM
    smoss33989
    Steven
    Wow that is quite the in-depth post. thanks! definitely some good bits of info I will use.
    Wow 00 that is a beefy cable, I will have to do some more research. I am planning on using 4awg currently but I definitely had concerns with the length of the cable. any links to info on cable efficiency?
    -Steven
  6. Apr 1, 2020 at 10:11 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Voltage drop depends on current not voltage. Ohms per foot times feet times current. 18’ of 00awg cable at .0779 ohms per thousand feet has a resistance of .0014 ohms. The voltage drop at 100A would only be .14V, barely 1% of 13V. Good for a winch connected to the battery but seems excessive for anything powered by a battery. To get to 3%(.39V) you’d have to be drawing closer to 300A. That’s a fair amount of money and weight penalty(~7lbs of copper). If 3% drop at 100A is your max you’d be about there with 3 or 4 awg(.19 or 24 ohms per thousand feet). Up to you though.
    source
    https://www.powerstream.com/Wire_Size.htm
    HBMurphy[QUOTED] likes this.
  7. Apr 2, 2020 at 9:52 PM
    HBMurphy
    Paul
    So California Coast
    None
    Since having both batteries in the back of my cab, I looked at how could I ensure that I would be getting the little to no voltage drop between my winch and batteries and between my alternator and batteries. It was nearly 11 years ago so I have no idea of what my assumptions were at the time, I just knew I wanted a efficient path for electrons to zip through. I do think the breakers on either end of it are 200 amp).
    I remember something like this:
    200 amps
    150 amps
    bagleboy[QUOTED] likes this.
  8. Apr 3, 2020 at 3:03 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    That makes more sense to include the round trip for the voltage drop.
