DIY control arms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LS_Liberty, Nov 2, 2021.
  1. Nov 2, 2021 at 5:04 AM
    LS_Liberty
    LS_Liberty [OP] Member
    Anyone build their own upper or lower control arms?
  2. Nov 2, 2021 at 5:21 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    I'm planning on something, maybe a +2"... have built arms in the past, mostly for power-sports.
    LS_Liberty[OP] likes this.
  3. Nov 2, 2021 at 5:24 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  4. Nov 2, 2021 at 5:32 AM
    LS_Liberty
    I want to do the same and go forward maybe an 1 1/2. I saw that jdfab sells the offset control pockets to move the control arms forward.My question at what point do you end up with too much positive caster,or could you offset the upper slightly to offset it?
  5. Nov 2, 2021 at 5:56 AM
    Jowett
    Brian
    North Adams, MA
    I have not gone that far yet, but a good guess would be to start with moving the lowers forward 1.5". That will get the arms and available caster adjustment in a nice neutral area.
  6. Nov 2, 2021 at 6:01 AM
    LS_Liberty
    Another thought ,how wide can you go before longer axles are required?
  7. Nov 2, 2021 at 6:05 AM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
  8. Nov 2, 2021 at 6:09 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
  9. Nov 2, 2021 at 6:20 AM
    LS_Liberty
  10. Nov 2, 2021 at 7:04 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Yup.
    J-arm UCAs with tubular LCAs for a long travel setup, and OEM width tubular LCAs.
    I don't recommend it, unless your actual hobby is fabrication.
    There's a tremendous amount of geometry that goes into making the front suspension work, and unless you're just copying an OEM part you'll potentially change all of it. If you do want to change shit plan to cut the shock tower/UCA mounts off and start from scratch.
    Start by researching "Instant Center", "Bump Steer", "King Pin Angle", "scrub radius", and "Roll Center" as it relates to double wishbone suspension.
  11. Nov 2, 2021 at 7:14 AM
    LS_Liberty
    I love doing fab work,I’ve done a few 3 link and 4 link jobs,I just haven’t messed around much with IFS.
    Arcticelf[QUOTED] likes this.
  12. Nov 2, 2021 at 7:20 AM
    Arcticelf
    Gladiator
    Get a copy of this, and start designing.
    Race Car Vehicle Dynamics https://www.amazon.com/dp/1560915269
    If you've done double triangulated 4 link IFS is just another way of tackling the same problems.
  13. Dec 17, 2021 at 5:38 PM
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    Just out of curiosity I searched for this. I swear you could probably build a Tacoma from scratch if you wanted just searching tacomaworld
