DIY: Coolant flush. Any advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ermine, Jun 27, 2014.
  1. Jun 27, 2014 at 9:23 AM
    Ermine
    Ermine [OP] Well-Known Member
    Colorado
    V6 Tacoma
    3 inch OME Lift
    I have a 2011 V6 automatic. I made the mistake of topping of my coolant over flow reservoir with some green coolant. I realized after what I did was bad. I want to flush all the coolant and put in toyota long life coolant.
    The steps as I understand it are:
    1) drain coolant from radiator, and coolant from engine block (2 drains).
    2.) fill with distilled water and run with heater turned on.
    3.) drain distilled water
    4.) refill with toyota long life coolant or similar product
    5.) burp the system and top off system
    Is this correct? Anything else I need to do? Or tips?
    I figured I could do this myself and not have to pay $140 for a mechanic to do it.
  2. Jun 28, 2014 at 7:50 AM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    Anybody?
  3. Jun 28, 2014 at 7:58 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I don't know about running straight water, I hear it can create steam and crack the block. Personally, I'd just drain it out the best you can and refill it.
  4. Jun 28, 2014 at 8:44 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    You could flush it with water. I did mine with a garden hose once, but it's not really required. The green coolant won't hurt anything, and probably didn't suck any into the system anyway. Drain the overflow and replace with long life coolant and you are good.
    I knocked a hole in my radiator once and after I stopped the leak made it home on three bottles of water and a bladder full of piss. This is why I flushed my coolant system, lol. Ran good, didn't even overheat.
  5. Jun 28, 2014 at 1:36 PM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    I looked into the radiator and the color was slightly orange and not pink so I'm guessing some of the green must have gotten sucked into.
    Ok maybe I will just drain engine block and radiator and refil with coolant and not flush with distilled water.
  6. Jun 28, 2014 at 5:52 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    go ahead and flush it with a hose; then do a final flush with distilled water to minimize the debris that will cook out of the tap water.
    Using the capacity of the system, put in full strength a/f to mix with distilled water. You can go up to 60 percent a/f.
  7. Jun 29, 2014 at 7:18 AM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    Flush with hose huh? I thought that was bad? But guess a distilled water follow up makes it ok
  8. Jun 29, 2014 at 7:27 AM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    The orange color is normal, that's how it looks in mine as well. If you are concerned about it mixing in, your first post procedure is correct, and it doesn't take long to do. Depending on your mileage, might be a good idea to do it anyways.
  9. Jun 29, 2014 at 8:25 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    If you plan on flushing the cooling system yourself, once old coolant is drained remove the thermostat then fill with water and run the engine. This way the water will flo through the whole system without having to reach operating temperature. Then let cool before draining. You can then repeat if you want. Just be careful not to get burned by hot coolant or water. Anytime you drain the cooling system replace the thermostat. It's just good PM.
  10. Jun 29, 2014 at 12:10 PM
    OCNutty
    Northern, Va.
    You can use distilled water for the whole process...I've just used it for the final internal 'rinse', a couple gallons to get the tap water mostly out. If you've seen the scum from an evaporated gallon of city water, you wouldn't want it in those small engine cooling passages or on your thermostat.
    Reason I'm so picky: Toyota spec is to never use any commercial additives, only "High-quality ethylene glycol-based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology."
    That to me, sez only distilled water should be used, and then add full strength oem coolant to max 60 percent strength, based upon cooling system capacity. Some distilled water will always be trapped, so I don't think you want to use 50/50 mixed in this case.
  11. Jul 1, 2014 at 8:51 AM
    Ermine
    Colorado
    V6 Tacoma
    3 inch OME Lift
    Hmm. Ok thanks. Maybe I will just drain and refil with coolant?
