DIY Coolant Service Question & Advice needed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GibbsTacoma, Dec 10, 2024.
  1. Dec 10, 2024 at 7:25 AM
    GibbsTacoma
    GibbsTacoma [OP] Well-Known Member
    Charlotte Metro Area
    2010 Tacoma TRD Sport DCSB 2wd
    Question yall:
    For a DIY Coolant Service, should I just perform a drain from the drain plug & reservoir and refill w/o draining from the block (the 2 drain bolts near each wheel well) OR do I need to drain the block as well? I'm nervous about those two small bolts near the block. Thanks In advance.
  2. Dec 10, 2024 at 7:46 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Just drain the radiator.
    Drive a week and do it again and maybe even one more time.
    Than don’t worry about it again for 5 plus years.
  3. Dec 10, 2024 at 7:57 AM
    GibbsTacoma
    Thanks. Will do.
  4. Dec 10, 2024 at 8:29 AM
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    Drain and fresh refill.
  5. Dec 10, 2024 at 8:32 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    this is what I do. Every other oil change (~8k oci) I do a fresh gallon.
    GibbsTacoma[OP] likes this.
  6. Dec 10, 2024 at 8:43 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    Drain and fill the rad..that's all I do..Oh...I do use toyota coolant..
  7. Dec 10, 2024 at 9:53 AM
    TacoTuesday1
    FL
    You can. I did once.
    after that I do the radiator. Like when I did the water pump. My upcoming denso rad replacement plan is use 2 jugs. Drain from rad. Doesn’t need more than that given its history.
