DIY: Differential Breather Extension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toy4Life, Sep 25, 2008.
  1. Aug 22, 2016 at 9:35 AM
    #181
    Jebediah
    Jebediah Well-Known Member
    Eli
    Colorado
    1998 White TRD.. 'Augustus'
    I'm sorry that I'm confused, but can someone help me clarify? I'm about to put in an order for a union part #90404-51026 and I bought 1/4 vaccum line with a in-line fuel filter. Is this the correct set up (the same as the original post that was created with the fuel filter). Would this be a free flowing breather. I'm sorry, just confused.
  2. Aug 22, 2016 at 10:00 AM
    #182
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2015 4WD DCSB
    Yes, it's free-flowing. The union screws into the place where the current breather is. It's 100% open and is threaded on one end to screw into the differential and is smooth on the other end for the 1/4" hose to fit onto (it needs to be clamped). Run the hose to the gas tank and attach the in-line fuel filter.
    Jebediah likes this.
  3. Aug 23, 2016 at 1:49 PM
    #183
    islanti
    islanti Well-Known Member
    1998 Tacoma SR5 V6 4x4
  4. Aug 23, 2016 at 1:54 PM
    #184
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
  5. Aug 23, 2016 at 10:43 PM
    #185
    islanti
  6. Aug 24, 2016 at 5:30 AM
    #186
    zacharypaul89
    Zach
    Georgia
    2015 4WD DCSB
  7. Sep 6, 2016 at 1:14 PM
    #187
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
  8. Sep 6, 2016 at 6:53 PM
    #188
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  9. Sep 6, 2016 at 7:35 PM
    #189
    FirstGen Jer
    Jeromey
    Thanks, ya I briefly read up on this so sounds like I need to do a little more research....
  10. Sep 6, 2016 at 8:39 PM
    #190
    David K
    Well, maybe they are using the correct end and only saying check valve? But, you can get the parts real cheap at the dealer. See my mod sig link.
  11. Sep 6, 2016 at 8:46 PM
    #191
    FirstGen Jer
    Jeromey
    That's my issue. Nearest dealer is two hours away. Probably just order from camelback or something though
  12. Sep 7, 2016 at 8:17 AM
    #192
    David K
    Parts can be UPS'd or mailed to you... if not the local dealer, then ones that do.
  13. Sep 7, 2016 at 8:48 AM
    #193
    FirstGen Jer
    Jeromey
    Yep camelback is a Toyota dealer that gives a TW discount. Thanks, appreciate the help.
    David K[QUOTED] likes this.
  14. Sep 21, 2016 at 2:39 PM
    #194
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
  15. Sep 24, 2016 at 6:38 AM
    #195
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
  16. Sep 24, 2016 at 6:43 AM
    #196
    CStoy
  17. Dec 13, 2016 at 12:33 PM
    #197
    brianjjeffries
    brianjjeffries Well-Known Member
    Brian
    Los Angeles, CA
    2016 Tacoma TRD Sport 4x4
  18. Dec 13, 2016 at 3:48 PM
    #198
    David K
    I don't see any breather in that second link? Just two insert (barbed) adapters and tube with clamps.
    It really isn't complicated, the front breather and union adapter can be ordered at Toyota parts, the tube and clamps at an automotive or hardware store... and some cinch ties.
  19. Dec 14, 2016 at 12:34 PM
    #199
    brianjjeffries
    Brian
    Los Angeles, CA
    Yeah if that is all I need then I should be able to handle it. I thought there was more to it.
  20. Aug 1, 2017 at 1:39 PM
    #200
    callmeammo
    callmeammo Well-Known Member
    This is such a messy thread for a sticky on what is repeatedly referred to as an "easy" mod.
    Here is my question after reading this thread which should hopefully clear things up for people in the future as well:
    The first post mentions 1 "union" (Toyota part# 9040451026) and 1 small in-line fuel filter. If I use both those parts, I take it I am good and have a 2 way extended breather?
    Or, do I have to order the 2 way breather from the front differential (#90930-03136) and use it in place or in addition to the in-line fuel filter?
    Thanks.
