DIY Downstream O2 Sensor Replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by erik530195, Dec 13, 2017.
  1. Dec 13, 2017 at 4:49 PM
    erik530195
    erik530195 [OP] Instagram: @toyota_vintage
    2003 Tacoma Prerunner Double Cab TRD
    A.R.E. Bed Cover; Upgraded fender flares; PA System; spotlights on tow hitch
    After noticing a rattling noise upon starting and acceleration, I crawled below to figure out what the problem was. The downstream O2 sensor was having issues. I immediately noticed the rubber gasket is completely rotted. And there doesn't seem to be a bolt on one side holding the whole assembly in place. I can move the entire sensor and the metal shield which causes the exhaust to make a strange sound. (Obviously I did this only once and won't be driving it except perhaps to the shop) Ideally, I would like to fix it myself, is this doable? I am mainly worried about access since the metal shield is keeping me from accessing it with any tool.
    There is a good picture of the metal shield on this thread:
    https://www.tacomaworld.com/threads/rear-o2-sensor-shield-replacement.502439/
  2. Dec 14, 2017 at 1:21 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    not sure how mechanically inclined you are, but the shield/o2 sensor just bolt on. You can get a bolt from a hardware store and gasket from toyota. Should be a fairly easy fix.
  3. Dec 14, 2017 at 3:06 PM
    erik530195
    Will try it. Do you have any tips on how to actually get in there? It feels like there aren't any bolts on the threads at all...
  4. Dec 15, 2017 at 12:05 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
