DIY Drywall carrier
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Revelations, Jun 30, 2020.
  1. Jun 30, 2020 at 2:52 PM
    Revelations
    Revelations [OP] Well-Known Member
    2014 MGM DCSB
    I had some people request I post dimensions. I'm attaching everything as pics. I hope you guys can figure it out. It should be pretty straight forward.
    Things to note:
    The door hinges you buy should be 360 deg hinges. Meaning they can rotate past 200. Many hinges do not allow full rotation. The hinges will stick up above the 2x4 by 1/4" or so. This won't damage the drywall, but you will want to make sure you load the drywall carefully, so you don't smash into the hinges. You could notch out the 2x4, but that's a lot of extra work.
    I used my Krieg pocket jig to drill holes so that the arms sit flush with the cross beams. You'll see what I mean in the pics. Accordingly, my dimensions are for that setup. If you choose a different method of joining the 2x4, you'll need to adjust your measurements.
    I don't recall the exact thread pitch of the bolt, but it is SAE, not metric. The D-ring nuts in the bed are not covered, so you can buy whatever length and not bottom it out. I think I bought 2.75" or 3" bolts. The 2x4 will eat up 1.5" of your bolt length, so buy accordingly. I spent almost 2 hours searching for the right thread pitch and lengths.
    When not in use, I just attached the 2 swinging pieces together by driving some screws through the 2x4. Makes it much easier to carry.
  2. Jun 30, 2020 at 2:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I like it. Pretty smart.
    Gregthespy and Revelations[OP] like this.
  3. Jun 30, 2020 at 3:00 PM
    Kilo Charlie
    Kilo Charlie I have lost my way
    Iowa
    2017 Inferno Off Road
    AWESOME! Thank you!!
    Revelations[OP] and Gregthespy like this.
  4. Jun 30, 2020 at 3:08 PM
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    Nice work on the documentation! Looks really easy to follow.
    Thank you for doing this. I’m keeping this thread subbed for when I need this!
    Revelations[OP] likes this.
  5. Jun 30, 2020 at 8:00 PM
    Revelations
    2014 MGM DCSB
    The hole size might be off. I believe I drilled 1" holes and used fender washers for the bolts. The center to center measurement is an approximation, so that's why I drilled large holes. Also, when you put it in the bed, it needs to go down at an angle if you have a tonneau cover like mine.
    Kilo Charlie likes this.
  6. Jun 30, 2020 at 8:38 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  7. Jun 30, 2020 at 9:08 PM
    Revelations
    2014 MGM DCSB
  8. Jul 1, 2020 at 10:23 AM
    TRM
    TRM Well-Known Member
    Tyler
    Knoxville, TN
    15 DCSB TRD Sport 4x4
    Great job. I love this!
  9. Jul 4, 2020 at 7:17 PM
    fatrip
    fatrip Well-Known Member
    Vince
    Upstate NY
    07 Taco 4D Short
    Bilstein 5100's , 885.
    Great build thanks for the measurements too.
  10. Jul 5, 2020 at 8:15 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Did you have issues carrying drywall that led to this? I just put it in the bed with one side on the Wheel well and the other in the bed bottom. Never had one break.
  11. Jul 6, 2020 at 9:16 AM
    Revelations
    2014 MGM DCSB
    Not a huge fan of hauling a 10 foot section in that manner. Lightweight drywall will flex quite a bit.
  12. Jul 6, 2020 at 9:52 AM
    Crosis
    Dunedin Fl
    Ah I only use 8 foot ones.
