DIY easy $10 trailer lights plugin fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 11, 2014.
  1. Oct 11, 2014 at 9:03 AM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    I decided to do this because I needed to fix my trailer lights but the damn things cost $40 and im on a very tight budget (fixed income) so I cut my non working module open to see whats in it that it has to cost so much.
    low and behold there is nothing to it but there is a huge design flaw with it.
    they run the wiring through a transistor which isn't needed but they often fail which is the only reason these things stop working, ever.
    the core of how they work is the four diodes in them so the diodes do all the work and the transistors are just there like a fuse that can go bad.
    so if you want to wire up trailer lights without buying the $40 contraption you can just follow these instructions but I prefer to think of this as a fix for one you already have wired in that failed on you.
    I don't like tapping into stock wiring by cutting it which is what you would need to do if you never had trailer wiring before so I would say this is a fix that is a more recommended thing to be doing after you already bought your $40 trailer light that comes with the stock plugs so you dont cut and wires and then when it fails on you as they often do, then do this fix and you will never have it fail again. but if you don't mind splicing into your trucks stock wiring, then there is no reason not to do it as your first trailer wiring setup but you will need to buy the wires and trailer plug connector as well.
    you just need a soldering iron, solder, heat shrink tubing, and electrical tape, then go buy 4 of these diodes or some like it: http://www.radioshack.com/product/index.jsp?productId=12673864
    now how it works:
    diodes allow electricity to go in only one direction and on our trucks the brakes have a separate wire then the flashers do, on many trucks the flashers are used as the brakes so those can be wired directly to the trailer plugs but on ours if you did this then every time you used either flasher then every light would flash like hazard lights and you would have no directional control. to solve this they use diodes to stop electricity from going to the other lights you don't want it to go to. simply cut the wires off of both sides of the module and connect the white and brown wires together, then solder in the diodes to the other wires as shown in the diagram.
    in the diagram below you see how this works:
    http://s1076.photobucket.com/user/keakar63/media/toyotatrailerlightmodulefix.jpg.html?sort=6&o=3
    you can see how incredibly simple these things are but they are made with bad solder connections and have transistors in then that go bad all the time and the transistors aren't even doing anything except making these things quit working. when one fails there is nothing wrong with the diodes its the transistor or the solder connections went bad.
    the power for the brakes goes through both middle diodes and sends power to both left and right flashers. when you need the driver flasher it goes through just the yellow wire and to the yellow flasher but the middle diode is also connected to it but the diode wont allow current to pass in the opposite direction so it acts like there is no connection there. the same happens on the opposite side for the passenger flasher.
    this setup is indestructible and there are no moving parts or anything to wear out so unless you physicly crush the diodes they never fail.
    this is a $10 repair to an otherwise $40 replacement harness for trailer lights and this setup will NEVER FAIL AGAIN.
    this is also a $10 trailer wiring diagram so you don't have to buy one in the first place but for me, and I suggest the best thing to do, is just buy one for the very first time you connect trailer wires to your truck. I don't think you should ever cut and splice stock wiring even though people have done it that way for years and years.
    NOTE: this was done for my Toyota but can work on other vehicles as well if your connector is wired with an extra wire other then the yellow, green, white, and brown. having the extra wire is what makes it necessary to use the diodes to prevent back feed of power to the other lights.
  2. Oct 11, 2014 at 4:40 PM
    keakar
    karl
    louisiana
    well if its your converter (and it may very well be) then it definately will but also check your grounds, intermittent issues are often bad grounds so make sure you use a ground wire to the lights and not rely on the metal frame as your ground.
    if you do use the frame as a ground then all unwelded connections (tilt connection, bolted on light stands or guides) need a wire to connect them to each other because just touching or bolts are not a good electrical ground connection
