DIY Front Brake Pad Change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badguybuster, May 20, 2009.
  1. Jul 30, 2013 at 8:44 AM
    #221
    Frogdaddy
    Frogdaddy Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    #213
    Let me preface this by saying I'm not a mechanic but know the directions of pads so don't take offense but that brake setup in your picture doesn't look right. Your outboard pad looks like you've got it inside out. Meaning, the pad material is facing out toward the pistons and the back of the pad is against the rotor. Especially since the grooves of each pad are facing same direction instead of toward each other. I wonder if you addressed this since it's a month since it was posted or found out the hard way? Just curious since it does look like a clean setup but noticed the pad direction.
  2. Aug 3, 2013 at 6:59 PM
    #222
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Wow, yes his are def wrong!! Hopefully he corrected that before driving!!
  3. Oct 4, 2013 at 7:50 AM
    #223
    fenderpicks
    fenderpicks Well-Known Member
    So regarding pushin the pistons back in.
    U need to open the bleeder valve and clamp it so the old fluid will come out of the bleeder, instead of pushing back into the lines?
  4. Oct 4, 2013 at 8:03 AM
    #224
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Absolutely NOT!
    Compressing the pistons will just force the fluid back into the system/reservoir.
    DO NOT open the bleeder! If you open the bleeder, you'll be exposing air into the system and will need to bleed the brakes.
  5. Oct 12, 2013 at 10:43 AM
    #225
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Thanks for this thread, I changed my pads today and it was easy but I forgot how the spring clip went back on. That picture in the OP saved me some searching!
  6. Oct 29, 2013 at 3:52 AM
    #226
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I did my brakes, but I thought the calipers were floating. (And I didnt read this post.) So I started to remove the bolts that hold the calipers together and fluid started to leak out.
    My buddy told me that I may have got air in the caliper. He said that If I just loosened up the bleeder screw on the caliper until a solid stream of fluid comes out and then tighten it back up.
    The brakes do seem fine though, there is no pulling to one side when I come to a stop.
    I just wondered what the thoughts are on the loosening up bleeder screw to let any air air.
    I thought if I opened that screw it would add air to the system.
    Thanks.
  7. Oct 29, 2013 at 5:41 AM
    #227
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    I don't know why some people are saying you should open the bleeder valves, seems like that's just making the job harder and completely unnecessary.
    As for taking your calipers off, I'm not sure what bolt you opened but nothing should have leaked out if you just unbolted the calipers?
  8. Oct 29, 2013 at 6:11 AM
    #228
    boxxed
    Denver, CO
    09 Off Road
    In my case it was because I opened up the caliper.. There are 4 bolts on the back side of the caliper that holds it together...I didnt know about the 2 bolts that are holding the whole caliper to the back side of the rotor. ( I dont know the correct name) At the time I did it I didnt know better..
  9. Oct 29, 2013 at 6:33 AM
    #229
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    when i saw the title i thought "who needs a writeup to to change brake pads?"
    but now that i checked it out, Good write up! Im sure it will help some people who otherwise would be lost in the sauce, maybe even save them money :)
    so, i admit.. i was wrong lol
  10. Oct 29, 2013 at 1:49 PM
    #230
    Janster
    Jandy
    Lancaster, PA
    If you're leaking brake fluid....regardless of WHERE its coming from....you have allowed air to get in and you should bleed the brakes.
    Opening up the bleeder screw should only be done when you're bleeding the brakes. The only time you open up that bleed screw is when the brake pedal is being pressed to the floor during the bleed process. It must be closed FIRST before allowing your pedal to return to the upright position. This allows for only outward motion of the fluid (and not allowing air to get sucked in).
  11. Jan 22, 2014 at 4:20 PM
    #231
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    I don't know if it's been covered because I didn't read all the pages but you can open the fluid resevoir cap before pressing the pistons back so that it won't cause any pressure. If not, the piston will keep coming back out (or the pressure will damage something although many times I forgot to open the cap and the pistons had to be held back for a long time before they settle in the "in" position. Nothing was damaged). I have never opened the bleeding screws until the end when I decided to bleed the brakes.
  12. Jan 22, 2014 at 4:39 PM
    #232
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I always open the reservoir then press the piston back - I've never opened a bleeder screw to swap out pads.
  13. Mar 7, 2014 at 2:55 PM
    #233
    07TacomaDan45
    07TacomaDan45 Well-Known Member
    Dan
    Ventura County
    07 Prerunner Long Bed Indigo
    Ipod Cable, Painted stock wheels, Prevent Tailgate Theft Mod
    Great DIY video: http://www.youtube.com/watch?v=Gzgh_LVAIDE
    I think I am going to attempt to change the pads in a week or so without removing the caliper. I have never touched the brake system, and I have 105,000 miles on the truck.
    Question 1: I should be able to reuse my shims, right?
    Question 2: Another member mentioned to put anti-sieze on the pins that hold the brake pads in. Is that a good idea?
    Other than that, I should be able to just take the old pads out and put the new ones in, right? Just like the video above shows....
  14. Mar 7, 2014 at 3:10 PM
    #234
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    As far as Question #1 - Maybe. Mine were rusted all the way through when I did mine last.
  15. Apr 25, 2014 at 1:29 PM
    #235
    quantum
    quantum Well-Known Member
    so.............
    i changed my brakes and rotors and may or may not have torn the rubber boot surrounding one of the brake pistons......did i majorly fuck up?
  16. Apr 26, 2014 at 12:13 AM
    #236
    yota20000
    yota20000 Member
    Monroe, WA
    00 4X4 SR5 V6
    Not majorly-it's just a dust boot but you want to replace it as soon as possible. There is a groove in the caliper and on the piston that the boot needs to seat in and a spring clip to hold it on. Don't know if you can get just one boot-might have to buy a kit.
  17. May 10, 2014 at 9:23 PM
    #237
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    So i changed my brake pads today and took the rotors in and got them turned. When installing the new pads however, I didn't use any sort of grease or lubricant on the pads, just threw em in straight out of the box. Did I mess up? What sort of issues will arise if this is bad to not do? I used Wagner Thermoquiet Ceramic Brake Pads that didn't
  18. May 14, 2014 at 5:45 AM
    #238
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Should be fine for non-rust belt area. I've never used anything on mine and haven't had any problems (on any of my 3 sets of pads).
  19. Jun 23, 2014 at 4:28 AM
    #239
    newfieblue
    newfieblue Active Member
    Newfoundland
    07 TRD
    What is the brake line called that goes from the caliper to the first clip. Mine is solid line but I have seen others have flex.
  20. Jun 23, 2014 at 5:41 AM
    #240
    quantum
    Question: I changed my rotors and pads about a month ago and am getting alot of brown dust (possibly rust) on my wheels. Anyone have any idea what's going on?
    Pads: Hawk Performance Ceramics
    Rotors: Centric Premium High-Carbon
