DIY Front Brake Pad Change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badguybuster, May 20, 2009.
  1. Jan 11, 2010 at 7:38 AM
    #81
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    It's a shame I still don't know how to change my brakes
  2. Jan 11, 2010 at 9:18 AM
    #82
    JAG
    JAG Well-Known Member
    IF your doing just the pads it super easy. Just do one side at a time and you can reference the other complete side when you have to put the clips back. IF its anything else like turning rotors... Imo I would pay somebody.
  3. Jan 11, 2010 at 9:37 AM
    #83
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    How do you know if the discs needs to be resurfaced?? changing the pads looks kinda easy, but im wondering if taking out the discs is a lot harder
  4. Jan 11, 2010 at 9:44 AM
    #84
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If the rotors are warped you would know it because when you brake you'll feel vibrations. It would be very noticeable.
  5. Jan 11, 2010 at 4:18 PM
    #85
    silvertac0
    silvertac0 Member
    Phoenix, AZ
    08 PreRunner DC TRD OR
    Im pretty sure that what he means is that you want to grease the *shims. In other words, apply the antisqueel lubricant that comes in the pack to the shims (*the thin peice of metal between the pad and the caliper to reduce the amount of unnecessary squeel by absorbing vibrations caused by braking).
    Lubricant applied between the brake pad and the rotor would defeat the purpose of brakes, which is to provide stopping power via friction produced between the brake pad and rotor.
  6. Jan 12, 2010 at 7:33 AM
    #86
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I was taught that it is prudent to re-surface the rotors every time the pads are changed so that you start with two absolute true surfaces working together. This will minimize the risk of squeeks and evenly distribute braking pressure. A visual inspection isn't going to reveal whether or not the rotor needs re-surfacing. Furthermore, the shop that does the re-surfacing (if reputable) will give you get an exact measurement of your rotors.
  7. Feb 2, 2010 at 11:17 AM
    #87
    SurfnWolf
    SurfnWolf Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    Is this front caliper more difficult to get off or have problems with, seems like people say they screwed up by taking the caliper off. On all front pad changings I have ever done I have always unbolted the caliper, usually 2 bolts... then applies a c clamp to the piston? Any different for this tacoma?
  8. Feb 2, 2010 at 3:41 PM
    #88
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Nope, just 2 bolts and use a c clamp.
  9. Feb 2, 2010 at 4:54 PM
    #89
    elchimpo
    elchimpo Well-Known Member
    Gustavo
    Long Beach
    2009 SR5
    rims and stereo system
    thanks
  10. Feb 2, 2010 at 5:41 PM
    #90
    Joe Taco
    Joe Taco Well-Known Member
    Joe
    Charleston, SC
    '10 Tacoma PreRunner TRD OR
    Purchased truck on 1/3/10
    What is the torque amount for the caliper bolts?
    I did the brakes on my 4Runner and torqued them to 110 ft-lbs. It was a guess.
    BTW..The brakes on the (2005) 4 runner, 2010 Tacoma and (a 1999) Land Cruiser appear to be identical.
  11. Feb 5, 2010 at 7:38 PM
    #91
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Somebody needs to do a video of changing there pads for a 05-10 tacoma...I think chris 4x4 is a good candidate!:D
  12. Feb 5, 2010 at 7:45 PM
    #92
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Subscribed
  13. Feb 5, 2010 at 11:55 PM
    #93
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    It's the same as most other vehicles.
  14. Feb 9, 2010 at 2:49 PM
    #94
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    the proper way to do a brake job is to remove the caliper. now you can get away with not removing it on certain makes and models. when it comes time to place the new pads in, you use a caliper tool made for gently pressing the piston back with out causing damage. normally in between the pads getting swapped, you have your rotors cut on a lathe, but i won't burn yall on that. other than that it was a good write-up
  15. Feb 19, 2010 at 5:57 AM
    #95
    cjh
    cjh Well-Known Member
    10 doublecab
    One thing I have to add to the process is to grease the pins that hold the pads in place whenever you have the pads out. Trust me on this one, the pins WILL seize to the caliper. It is just a matter of time, especially iy you live in the snowy regions. Once the pins are stuck in the caliper, a 20 min. job turns in to a 2 hour P.I.T.A. If the pads get stuck on the pins due to corrosion, the pads basically become non-floating and will rub excessively on the rotors.
  16. Feb 19, 2010 at 6:06 AM
    #96
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Sand them down before you grease them as well.
  17. Feb 20, 2010 at 10:46 AM
    #97
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Flugelhornjazz Where do you buy ate blue brake fluid ? The auto parts store around here, north jersey, not even Harrington Speed carry it. On line the cost for shipping is as much or more then the liter can making it $25-$30 instead of $10-$15. I'm coming up on my 30k service but I'd like to pay less then $25 for brake fluid. Thanks
  18. Mar 9, 2010 at 12:11 PM
    #98
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Do people change the Brake shoes in the rear the same time they change the brake pads?
  19. Mar 9, 2010 at 4:05 PM
    #99
    george3
    New Jersey
    You may change the front pads 2 to 4 times B 4 you need to change the shoes.
  20. Mar 9, 2010 at 8:03 PM
    #100
    tim920
    Tim
    Boston, MA
    ^Cool. Thanks man!
