DIY Front Brake Pad Change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badguybuster, May 20, 2009.
  1. Aug 21, 2010 at 8:20 PM
    #121
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    no bleed, brakes are working great.. will check the fluid level every weekend though to see if I get any leaks..
  2. Aug 22, 2010 at 5:49 AM
    #122
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Great to hear! But if your observant, you'll probably notice wet spots on the ground on the inside of that tire before you'll see it in the master cylinder level. Easier to see as you back up.
  3. Aug 22, 2010 at 10:35 AM
    #123
    raycie
    Oahu, HI
    In need of $$$
    thought about that as well. Will also actually be taking tire off every now and then to inspect that brake caliper as well.. I guess that is the one good thing about working on your own truck. You not only know what may be problematic, but you know what to do about it. If I took it to some brake place, they probably wouldn't even tell me if something was a "possible" problem and just sent me on my way. Then if something did go bad later on, they wouldn't take any responsibility and claim normal wear.
  4. Aug 22, 2010 at 12:46 PM
    #124
    pinktaco808
    pinktaco808 Hot Steppa
    what grade sandpaper you guys use???
  5. Aug 27, 2010 at 6:32 PM
    #125
    PeRuViAnDeMoN82
    PeRuViAnDeMoN82 New Member
    Bruno
    California ( NORCAL)
    05 tacoma SR5 4x4
    3" lift kit, wheels , in-dash dvd player, 8' sub, 6x9 speakers
    i just did mine and u do need to open the bleeder, thanks badguybuster
  6. Aug 30, 2010 at 10:23 PM
    #126
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Subscribed!
  7. Aug 30, 2010 at 10:41 PM
    #127
    pinktaco808
    umm someone do a better write up with better pics shoots
  8. Aug 31, 2010 at 7:19 AM
    #128
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I think there was a how-to sticky somewhere the forums for front brakes...
    grade sandpaper doesn't matter, I use whater medium or coarse grade i got in the box. Just work it till the shine is gone and it's not essential, but does assist bedding the new pads.
  9. Aug 31, 2010 at 10:03 PM
    #129
    pinktaco808
    where the link of the diy with 5 lug setup and not 6
  10. Sep 26, 2010 at 5:13 PM
    #130
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    did mine today. And did not bleed the brakes. I compressed the pistons with a big pair of pliers/ installed the new pads and done. Brake fluid went from add to full>>>
  11. Oct 20, 2010 at 11:25 PM
    #131
    THROUGHITALLDUDE
    THROUGHITALLDUDE Someone didnt put the tailgate down!
    Jeff
    Southern California
    2005 Silver Tacoma
    285-75-17 Definity ATs - 16'' Chrome Moto Metal 951s - 4'' Maxtrac spindles - Rear Icon Progressive Leaf Pack - Magnaflow exhaust - Aftermarket LED Taillights - BHLM - Custom Wet Okle Seat Covers - Moog Tire Rods - US Spec Ipod - K&N High Flow Filter - Daytime Running Lights - TRD Skid Plate - Grillcraft - Hellas Mounted behind the grill
    hey guys i was looking at some other how to's to change brake pads and none of them talk about the bleeder valve needing to be open.....they just say to open the reservoir cap and the pistons can be pushed back with a screw driver enough to pull them out and put the new ones in
    also any advice on good pads?
  12. Apr 8, 2011 at 12:34 PM
    #132
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    Just completed mine yesterday according to this article. Didn't open the bleeder valve, just opened the master cylinder cap and was able to work the pistons back enough to fit the new pads in.
    I'm using Wagner ThermoQuiet ceramics from Advance Auto Parts ($49.99). Brake squeal is gone now. =)
    Thanks for the write up! Seriously the easiest brake pad change I've ever done. Got just under 54000 miles on my original pads till they started to squeal. (mine is a 2007 doublecab prerunner)
  13. Jul 27, 2011 at 11:53 AM
    #133
    rlanicek
    rlanicek Member
    Rick
    Dallas, TX
    2010 Tacoma PreRunner SR5
    Time for new front brake pads and I came here first. Excellent thread - I've read all the posts but something is still unclear to me.
    How do you push in the pistons (with a screwdriver or c-clamp) without removing the caliper? It seems to me that you risk damaging the rotor.
  14. Oct 9, 2011 at 11:33 AM
    #134
    rjlto1972
    rjlto1972 Member
    05 Double Cab Tacoma
    I change my front pads yesterday and now they are not working correctly - Red "Brake" staying on...ahhhh. I compressed the calipers so the new pads could fit and fluid squirted out. Put everything back together yesterday, but did not try out the brakes/pump them. This morning went to finish/check everything out and fluid (brake) was leaking behind the wheels.
    In the "on" position brakes are tight and "Start" position pedal goes to the floor with the "brake" light on.
    I did not bleed my brakes...is that what I need to do now? Any help is greatly appreciated. Brake reservoir is now low so heading to the store for some more and maybe this will resolve the issue.
    Thanks in advance as I have been searching this sight for the past hour in desperation.
  15. Oct 9, 2011 at 11:44 AM
    #135
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Did you take the cover off the master cylinder B 4 you compressed the calipers ? Where exactly is the fluid coming out of ? If you just changed the pads and did it correctly you shouldn't have to bleed the brakes so you must have done something incorrectly. Exactly what steps did you go through when you did the job ?
  16. Oct 9, 2011 at 1:17 PM
    #136
    rjlto1972
    rjlto1972 Member
    I don't recall, but I may have taken the cover off before the compression...fluid was coming out of a small hole when I was compressing. Have a kit/tubing and will now attempt to bleed my brakes.
    :frusty:
  17. Oct 9, 2011 at 3:20 PM
    #137
    george3
    New Jersey
    Sorry, not clear enough info for me to figure out.
  18. Oct 9, 2011 at 4:23 PM
    #138
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Just changed my pads today at ~75k miles, had about 2mm left. I did not use bleeder or open the master cylinder cap, just compressed one side at a time and slid the pads in.
  19. Oct 9, 2011 at 5:15 PM
    #139
    rjlto1972
    rjlto1972 Member
    I guess I somehow got air in the lines, sohad to learn how to bleed my brakes. Took a while, but finally got them doneand the brakes now work...ahhh. Changed pads numerous times but this was afirst where I had to bleed the brakes. At least they are working now! :confused:
  20. Oct 10, 2011 at 12:35 AM
    #140
    george3
    New Jersey
    Congratulations:D Why was fluid coming out of a little hole and what little hole :confused: That's why I thought you had a bigger problem then bleeding the air out.
