diy front truetac install
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98fourbangertaco, Jul 31, 2010.
  1. Jul 31, 2010 at 6:12 PM
    98fourbangertaco
    98fourbangertaco [OP] Well-Known Member
    Taylorsville, NC
    98 toyota tacoma, 4wd, SR5, 2.7L, 5-speed
    daystar 2.5in suspension lift kit, detroit truetrac in rear, custom transfer case skidplate, deckplate mod, green high-performance drop in filter, Huskyliner floor mats, 31x10.50 wild country radial mtx tires, yakima roof rack, load warrior basket, stubbs welding rock sliders, arb front bumper with warn 9,000lb winch and procomp black series 100w offroad lights, trail-gear rear bumper, borla exhaust, blacked out factory wheels, shovel mounted on roof rack, de-mudflaped
    I'm planning on installing a detroit truetrac in the front of my taco, me and my dad installed one in the rear couple months ago and I love it, has anyone else installed a truetrac or any other locker/lsd I'm the front of their tacoma, any input would be greatly appreciated
  2. Jan 13, 2012 at 7:54 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    im curious about a front lsd for my truck instead of locker because of breaking cv axles with the locker
  3. Jan 13, 2012 at 9:50 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    oh awesome. they do make a powertrax lockright for front axles dont they?
  4. Jan 13, 2012 at 12:07 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    A litte OT, but you get snow in NC Ryan? I was thinking about a truetrac, but I cant find any reviews in the snow on a DD.
  5. Jan 13, 2012 at 6:24 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with lots of midtravel bling.
    I belive you can modify your cv to run a truetrac on a ADD truck (need to talk to ECGS) . If you have manual hubs no problems.
  6. Jan 16, 2012 at 7:34 AM
    MMyota
    MMyota Well-Known Member
    Brandon
    Salem, AL
    01 Prerunner TRD 4x4
    TRD cat back, TRD headers, Airaid CAI, poweraid throttle body spacer, Saw 2.0s, toytec AAL, RG 1" body lift, 4x4/5-speed swap, aussie locker front
    if you have add then i wouldnt recommend a lunchbox locker maybe a arb something selectable, if your running manual hubs then i recommend a aussie locker.
  7. Jan 16, 2012 at 8:25 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    aussie it is then!!!
  8. Jan 16, 2012 at 2:43 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    F all that BS about a mechanical locker up front. I ran one in the snow for 5 months and never had a problem in 4wd. Same with the rear, never had one issue. :confused: Meh. L2Drive with it :D
  9. Jan 18, 2012 at 9:46 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    can the ADD be wired to disconect each side seperatly?
  10. Jan 18, 2012 at 9:48 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    In order to install a front locker, you first need a front differential ;) :D
  11. Jan 18, 2012 at 9:56 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    thanks for the info update but im trying to pick a front diff to buy to do all of this. . . :cool:
  12. Jan 18, 2012 at 12:15 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    4wd toyota enthusiast, the magazine, did a whole DIY article on installing a front Aussie locker. I think it was the June or July issue. Detailed everything with pics.
  13. Jan 18, 2012 at 12:40 PM
    SargeSlapnuts
    Nick
    alpharetta, GA
    dang it i just wanna know if the ADD can be modified to be selectable from inside the truck via switch!!!!!!!!
  14. Jan 19, 2012 at 4:31 PM
    MMyota
    Brandon
    Salem, AL
    well if your a prerunner and your looking for a diff do this. Find either a ADD or Non-ADD diff and spindles,cvs, and hubs from a non-ADD truck. I have a ADD diff that i modified the actuator to stay locked all the time with manual hubs. If your in alpharetta i seen a CL post for a whole front end from a Non-ADD tacoma for like $250 i think somewhere around atlanta
  15. Jan 19, 2012 at 4:33 PM
    MMyota
    Brandon
    Salem, AL
  16. Jan 20, 2012 at 1:39 AM
    x2468
    Vermont
    Great but no need for a front anything if you have a Prerunner, since that means you're 2wd.
    No, i don't believe so. The disconnect point is the transfer case.
    So you're doing a 2wd to 4wd conversion?
    Well Add, being the opposite of manual hubs as i understand it, does imply that it is selectable from inside the cab. I think most add taco's use an electronic switch but some use a mechanical J-shifter. It would depend on which one you buy.
  17. Jan 20, 2012 at 4:29 AM
    SargeSlapnuts
    Nick
    alpharetta, GA
    that guy already sold that front end unfortunately na dit was the wrong gearing to match my rear end 4.56 gear. im still searching for more info. i have also been looking into centrifugal super chargers as they are by far more efficient than roots type that come with a trd package. still need to find some more info on it though
  18. Jan 20, 2012 at 5:41 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Not just a front differential but a transfer case with all the necessary adapters and crossmembers.
  19. Jan 20, 2012 at 6:27 AM
    macgyver
    Brad
    Canton, GA
    I understand all that's needed to have 4WD. I was just giving Nick shit for being 2WD asking about a front locker. :D Just a joke.
    IMO do your 4WD conversion first (well...actually just sell your prerunner and buy a 4x4 and save yourself the headache and time of the conversion) then figure out if you really NEED a front locker. There are plenty of people who get through lots of tough situations without a front locker.
    Not to mention...personally I would rather have a selectable locker in the front so it doesn't affect normal street driveability.
  20. Jan 20, 2012 at 7:08 AM
    MMyota
    Brandon
    Salem, AL
    A selectable locker up front will not affect normal driving unless. You are driving around in 4x4. If your looking for a front different with 4.56 gears then good luck I'd find whatever was available and re-gear it. To answer the precious question yes an electric add actuator can be wires to a remote switch in the cab BUT a vacuum actuator can not be to my knowledge.
