DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Mar 16, 2014 at 1:47 PM
    #221
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    +1 I don't know what the heck that was.
  2. Mar 24, 2014 at 1:03 PM
    #222
    C1ph3r
    C1ph3r Well-Known Member
    A.W.
    Concord NC
    Nothing special
    2014 DCSB 4x4 TRD OffRoad Super White TRD sport grill, Custom mesh grill, Tailgate theft mod, bed mat, tint, chopped antenna, 16x8 Konig Counter, Weathertech mats and window shades, Relentless Fabrication bolt on sliders
    Thank you! I had no idea what bolt was what on the bottom of the trans. I need to check fluid level.
  3. Apr 4, 2014 at 7:31 PM
    #223
    jsheilm
    jsheilm New Member
    06 Double Cab 4x4
    I've been having a great deal of trouble with my '06 4.0L 4x4 lately. I've been experiencing a lot of the same symptoms as others have described as driving over a rumble strip. The problem is, those folks only had a few thousand miles & I have over 149K. Until the past couple weeks, everything's been fine. Then all of a sudden things started getting bad.
    It happened with increasing frequency when driving between 20-30mph in "D" under light acceleration. Lightly tapping the brake made it go away.
    At first, I thought it was fuel/air related. I cleaned my K&N air filter, MAF sensor & throttle body. My idle settled down, but the rumble strip was still there.
    Then I though it must worn u-joints and/or center bearing. So I changed those. The rumble strip was still there.
    Then I started reading about changing that transmission fluid I was never supposed to worry about (unless I towed all the time or ran my truck in Baja races).
    Last weekend I did a 'change" - just replacing the 3 quarts from the pan with what I thought was the correct Amsoil alternative to Toyota WS. It was not. However, I immediately noticed an improvement & the rumble strip stopped happening as frequently - even under conditions that almost guaranteed it before.
    A few days ago, I ordered a case of the correct type of Amsoil ATF & just did a complete flush following Mountain Lion's guide. It's a little early to tell, but I even got up the slight incline I've been using to demonstrate the rumble strip to my neighbor and local automotive expert without so much as a hitch.
    Hopefully, replacing that near-black ATF did the trick. Now on to diagnosing & fixing that bearing whine coming from the driver's side front.
  4. Apr 4, 2014 at 7:36 PM
    #224
    jlleiber
    jlleiber Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    Glad to hear it seems to have remedied the problem. I bet that was frustrating trying to figure out. I'm at 106k with smooth shifting and just want to do this for peace of mind...
    How did the complete drain and fill go for you with the 4x4? Were the directions still straight forward even though OP was demonstrating on a 4x2 without tow package? I've never been too afraid to work on my truck but something about messing with the tranny scares me a bit
  5. Apr 5, 2014 at 5:00 AM
    #225
    jsheilm
    jsheilm New Member
    06 Double Cab 4x4
    I really had no problems. I made a mess that could have been avoided if I had not been trying to rush to beat sunset, but otherwise the OP instructions were spot on. I do not have the tow package, just the hitch. I am considering adding the tranny cooler at some soon, however.
    Only thing I forgot to mention in my initial post was re: volume of old fluid. It did not appear to be low....just badly in need of replacement.
  6. Apr 5, 2014 at 6:42 AM
    #226
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Same here, not a bad job at all. I made a few messes because I rushed a little too. I added a B&m Trans cooler while I was at it. Check my build thread for that.
  7. Apr 9, 2014 at 11:49 AM
    #227
    jlleiber
    Justin
    Indiana
    So one of the pictures in the OP is kind of confusing to me. I am talking about the picture where he is pointing to the oil cooler inlet and outlet at the front of the truck where you disconnect the outlet tube (at the red arrow). It's the tenth picture
    As far as I can tell, this picture is looking towards the driver side. But in the wording, you are supposed to disconnect the passenger side outlet tube (which would be the closest one to you in this pic). Anybody care to confirm this? I'm gonna try to get this done tonight and just want to be 100% sure I know what I'm doing
  8. Apr 9, 2014 at 6:11 PM
    #228
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    It looks like from looking in front of the truck it would be the hose closest to the passenger side frame, I think one of the red arrows are pointing to the clamp where you need to remove it at. I have not changed mine yet.... so maybe someone else can let you know for sure.
  9. Apr 9, 2014 at 7:26 PM
    #229
    jlleiber
    Justin
    Indiana
    So, just did this tonight and am still fairly certain that the arrows in the tenth picture should be mirrored. You can see the far tubes turn up to the radiator meaning they are the drivers side.
    But following OP's explanation was perfect and made this very easy to do. Only trouble I had was with my cheap ass hand pump. But I ended up draining a little less than 12 quarts and replaced with all 12 quarts that I had. After the level check though only a couple drops came out so I'm assuming it was low when I started. Took it for a drive and it shifted very smoothly so I'm just gonna grab another quart tomorrow and redo the level check.
  10. Apr 14, 2014 at 1:55 PM
    #230
    bicyclist
    bicyclist Well-Known Member
    Did mine today. It's an 07 2.7 with the 4 speed trans. The lines are different from the OP's pics, but the return comes from the same place, the lower line coming out of the radiator, so that part of the procedure is the same. It's easier with mine because it has a dipstick, so filling the trans is just a matter of pouring the fluid into a funnel in the dipstick tube.
    I did note that the Haynes manual says that the torque figure for the drain plug is 15 ft-lbs or 20 Nm. That's different from the figure the OP gives.
  11. May 7, 2014 at 1:39 PM
    #231
    udelslayer
    udelslayer Well-Known Member
    North Carolina
    09 Taco 2wd 5AT
    Do you have the overflow plug or the A/T temp light? I have a 09 2.7 and dont see either of those features on my truck. I would figure a drain and refill three times of the precise amount at room temperature would work. I'm not too fond of screwing with the coolant lines to "flush" the stuff out. I also noticed that the dip stick says that there is no need to change fluid under normal conditions.
  12. May 8, 2014 at 7:19 PM
    #232
    bicyclist
    No overflow plug nor temp light. The overflow plug isn't needed because the trans has a dipstick. The owner's manual says that only 4wd trucks have the temp light.
    There doesn't seem to be a service requirement for the 2.7 trans, although a Toyota service advisor told me that it should be done at 100K. The fluid that came out of my truck at 73K looked pretty good, but it wasn't the nice clean cherry red of the new stuff that went in. As I plan to do some towing, I feel that having fresh fluid in the trans is a good idea. I also added a trans cooler, which the truck didn't have.
    You could certainly do 3 drain and fills in a row, running the engine and shifting through the gears between each one and that would get rid of a lot of the old fluid, but it wouldn't do as thorough a job as a flush. The flush is easy and doesn't take any more time than it would to do a series of drain and fills, so I'd encourage you to do that. With the 2.7, you don't have to screw around with setting the level with an overflow plug at just the right temperature because you have a dipstick to check it with. It's easy; go for it!
  13. May 11, 2014 at 8:37 AM
    #233
    chetweewax
    chetweewax Well-Known Member
    NJ
    15 TRD Sport
    Homelink mirror (Adding soon) Came with truck: FUEL Rims, Mickey Thompsons, Vinyl Tonneau Cover, Remote Start, 20% front window tint
    I bought 4 gallons of Valvoline MaxLife ATF to do a flush, but now I am having second thoughts. My truck just turned over 90,000 miles so I was prepared to do the flush, truck is 9years old too.
    I am having second thought because I have a warranty on the truck until 126,000 miles. The trans is shifting fine, just feel like regular maintenance is the key to longevity. When I rolled under there yesterday I noticed the fill bolt has some sort of tamper proof on it, so I guess the stealership would know someone opened it up, which adds to my hesitation. Any advice?
  14. May 11, 2014 at 5:52 PM
    #234
    chetweewax
    NJ
    15 TRD Sport
    I guess I am just over thinking it, I'll check with the dealership just to make sure
  15. May 11, 2014 at 7:43 PM
    #235
    chetweewax
    NJ
    15 TRD Sport
    I completely agree. All my previous vehicles have been done between 45 and 60,000 intervals. I have read through the maintenance manual, and I am still dumb founded by the fact the it doesn't say anywhere to replace the trans fluid. During regular driving it only says to check it.
  16. May 12, 2014 at 12:02 AM
    #236
    gearcruncher
    Canadain bumper technician
    If you do not have a transmission cooler on your truck and you plan to tow or haul heavy loads or you are in heavy stop and go traffic , consider purchasing a cooler . The cooler thats built into your rad is designed to cool the transmission with the weight of just the truck by itself .
    160 - 200 are considered normal temps providing your engine radiator is functioning properly . If your engine overheats , your transmission will also overheat
    Normal fluid temperature in transmission to be 175 deg. F.
    Rate of oxidation to double for each temperature increase of 20 deg F above normal (175 deg F). As oxidation rate doubles, useful life of fluid is cut in half.
    At 175 deg F life is 100,000 miles
    At 195 deg F (20 deg above 175) life is 50k miles
    At 215 life is 25k miles
    At 235 life is 12k
    At 255 life is 6,250
    At 275 life is 3,000
    At 295 life is 1500
    At 315 life is 750
    At temperatures much above 300 deg F the metals in the transmission will tend to warp, twist etc. high temperatures causes the formation of varnish deposits which impair or pre vent transmission operation.
    At a fluid temperature of 415 deg F fluid life is 30 minutes!
    Source: Empire Lubricants Inc.
  17. May 13, 2014 at 5:31 AM
    #237
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Finally went ahead and did the Tranny fluid flush at 142k miles and everything went smooth and according to this DIY except at the end when putting the Truck in AT temperature mode. After the sixth shift to "D" the AT light came on and stayed On constantly, IS THIS NORMAL? ANYBODY? I checked the fluid and just a little came out. I was just wondering if anybody got the same results for a 2005 prerunner ? truck seems to be running okay/normal, but than it was running normal before I did this flush and the original fluid that came out was still red and did not smell burned. (I don't offroad or pull anything heavy) The outside temperature was about 75-80 F.
  18. Aug 17, 2014 at 5:40 PM
    #238
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I finally did this about two weeks ago at 60,710 miles on the odo. Thanks to "mountain lion" and everyone else who posted with great info and tips.
    I replaced the fluid with Valvoline Max Life. I got it for $15.99/gallon at one particular AutoZone near me. All other AutoZones around me wanted $23.99/gallon and Walmart was at $16.99. Lucky score! I flushed a total of about 14.5 quarts and ended up adding about 16-16.5 quarts (tranny was low from factory, but I've read that it's a common issue with these trucks). When I initially drained the pan 2.5 quarts came out, and when I completely dropped the pan to clean the magnets and fluid strainer I got another 1.5 quarts for a total of 4.0. In all honesty, the used fluid I drained looked and smelled just as new as the fresh fluid. I don't tow, I rarely wheel, and I have the tow package with ATF cooler, so I'm sure these factors all kept the original fluid in great shape.
    In addition to the fluid, the only new parts I installed were the o-ring on the mouth of the fluid strainer and the pan gasket (roughly $2.50 and $22.00, respectively, from the dealer).
    The truck still drives fine, and it feels as though down shifts are slightly less abrupt and smoother than before the flush. I'm sure having the correct level of fluid helps!
    Even though my truck may have not required a flush just yet, having the peace of mind is priceless. Thanks again for the helpful, TacomaWorld!
  19. Aug 20, 2014 at 1:41 PM
    #239
    esse10
    Texas
    IMO, You probably didn't need to change it just yet. I changed mine at 140k plus thousand miles and the old fluid came out still red and didn't smell burned at all. Well at least I'm good for another 140k miles so next time I plan to change it at 300k miles if I still own the Truck.
  20. Aug 26, 2014 at 12:25 PM
    #240
    Bw1605
    Bw1605 New Member
    CB, Truxedo cover, CCM off-road 2inch level kit
    I have 52K on my 2012 Double Cab 4X4 Offroad Tacoma with transmission cooler. I am wanting to put amsoil in it but I am concerned about the screen. Do I need to drop the pan and do anything with it? I had a transmission go out on my Xterra after 120K because I took it to the dealer at around 90K and the did a flush. I am a little nervous now but I will be doing it myself. Any advice on the screen. how many quarts of the Amsoil do I get 14?
    Thanks in advance guys
