DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Sep 29, 2014 at 7:44 PM
    #261
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Hey Erik, how long have had the Mobil 1 Syn ATF in your truck? What do you think of it?
  2. Sep 29, 2014 at 8:20 PM
    #262
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's been covered in here. The machine at dealerships and other shops has its own pump. The home equivalent would be using 2 seperate containers. The fluid is only pumped out and NOT sucked back in.
    If you could come up with a container that used the pumped out fluid level to push new fluid in we would love to see it!
  3. Sep 30, 2014 at 7:52 AM
    #263
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    The return line from the cooler back to the trans just dumps fluid into the body/pan of the trans, doesn't it? There's no suction there - the suction is down in the pan - through the filter.
    So that flush machine you mention would have to have a matching flow rate pump to install the new fluid. How could I easily arrange that in my driveway?
    PHM
  4. Oct 1, 2014 at 6:12 AM
    #264
    Poodle Head Mikey
    You could stick a big funnel onto that hose and time how long it took a quart of ATF to run in via the return hose. And then so long as it's less time that the ATF is taking to pump Out - all would be well.
    By myself I think it would be too much to do all at the same time. Once the outlet hose showed bubbles - so I apparently ran the trans pan empty of fluid.
    Also; I don't why overfilling the trans pan while doing this DIY flushing would matter either. The engine only idling and say ten quarts of fluid in the pan instead of the standard four - in 30 seconds it would all be pumped out of the pan anyway.
    I might do it again - although another 100K miles seems Way down the road to me. <g> But my alternative idea is:
    I change the Mobil 1 every 15K miles (I used to change it at 10K but I'm not doing that any more) - so how about if I drain the ATF at the same time? Refill with the three or four quarts drained out and so essentially 'change the ATF' every 60K miles.
    PHM
  5. Oct 1, 2014 at 6:29 AM
    #265
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You will get some naysayers that adding clean fliud to dirty is not intelligent. But, the reality is that tranny fluid is not under the same stresses as engine oil. Engine oil is subject to exposure to the burning of hydrocarbons, which makes contamination of the oil over time a fact. Burning hydrocarbons is just a dirty process.
    The tranny, on the other hand, is not subject to this exposure, but is used as hydraulic fluid and lube for the clutches. Oil itself doesn't deteriorate too badly by itself, but the additive package does. Adding a pan drain's worth of new fluid to the exisiting replenishes the additive package and restores some of the viscosity breakdown that will still occur due to shearing of the hydrocarbon chains in the clutches. So, my opinion, from the research I've done, is periodic pan drains of the tranny are just fine.
    My truck is on a 25K pan drain interval. About to get the 50K one done in the next couple of months.
    Biscuits likes this.
  6. Oct 1, 2014 at 7:48 AM
    #266
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Any amt. of clean transmission fluid mixed in with dirty fluid is better than just dirty fluid.
    Don't know about the newer ones, but 4 cyl Accords from the 80s held 6 qts. - you drained only 3. There was no easy diy method to get the other 3 out. I would drain tranny fluid every other oil change and refill with 3 qts. Car had 375,000 miles on it when sold. Same tranny.
    Have done the same with my wifes '06 Avalon. Holds about 7 qts. - Drains 3.7qts. I do this every 25K - WS fluid. Car is pushing 200,000 miles and shifts beautifully. Pan has never been off; fluid has never been flushed.
    For my Tacoma - I will follow the flush method here, but will first see what drains in that unit at 25,000 miles and maybe, depending on how much is drained the 1st time, refill with that amt. - followed by a drive and one more drain/refill. Depending on how much I am able to drain from pan, I may do the drain and fill at 25,000 mile intervals and the flush at 100,000 miles along with a filter change/pan&magnet cleaning.
    If you are only doing pan drains, something that might help get a little extra out is to elevate the front of the truck with a floor jack as high as it will go. This approach drained an extra 1/2 qt. from the trannies in 2.4 & 2.7 liter automatics - 1st gen. I'll find out if it also applies here the first time I do a pan drain.
    This approach has yet to fail me in the 30 yrs. I've been using it.
  7. Oct 9, 2014 at 7:37 AM
    #267
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Very nice man, At this point one should ask himself? it is a lot of work, how much will be to have it done by professionals?
    This for older folks like me.
  8. Oct 9, 2014 at 12:59 PM
    #268
    UltraE05
    UltraE05 Well-Known Member
    2010 Tacoma Crew Cab
    Max 200 bucks
  9. Oct 9, 2014 at 1:15 PM
    #269
    SRC
    SRC Well-Known Member
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    I just did mine and it ran me ~$130 for fluid, new washers, and a $20 chemical sprayer that I used as my fluid pump (which worked awesome BTW). I drained/filled from right at the tranny cooler which is really easy if you pop the grille out.
    Toyota quoted me $260.
  10. Oct 9, 2014 at 5:45 PM
    #270
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    So how did all that work?
  11. Oct 10, 2014 at 6:00 AM
    #271
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    The chemical sprayer or doing it from behind the grille?
  12. Oct 10, 2014 at 6:09 AM
    #272
    wake100
    Syracuse, NY
    chemical sprayer really, trying to envision and just not
  13. Oct 10, 2014 at 6:26 AM
    #273
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    This is the one I bought. I removed the nozzle and cut the tip so it would flow more steadily. Then I attached a small piece of the clear tubing to the end of the sprayer and stuck that onto the metal return line of the vehicle.
    I had my buddy turn the truck on and off for me while I stood at the front pumping away. I couldnt keep up with the flow rate of the tranny pump so I'd have him stop at roughly 3L and let me catch up. I would think that if you removed the handle piece completely and just ran the straight tube to the vehicle you would be able to get much better flow but I was just happy to not have to get under the vehicle several times to fill.
    Other then the location I did it from and the pump I used, it was the same proccess as the OP so kindly layed out. Hope that makes sense.
    Cheers!
  14. Oct 10, 2014 at 6:47 AM
    #274
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    This seems like a great idea! How long of a process would you estimate this took you?
  15. Oct 10, 2014 at 6:56 AM
    #275
    SRC
    Shawn
    Guelph, Ontario
    2017 DCSB OR
    Had I been organized, and not extremely hung over I probably could have done the flush part in roughly 30 mins. Then the fluid level check is the big variable. I let it get too warm so I had to take a lunch break lol.
  16. Oct 10, 2014 at 7:37 AM
    #276
    Poodle Head Mikey
    I like the sound of it and it would play well at a corporate meeting. <g>
    "Let's have a professional do it." it has a nice ring to it. <g>
    But we're talking about having some fluid changed here. The profesional who will almost certainly do this job will be the newest helper-type guy who is being paid the least at the establishment you choose, and will be being screamed at all day long to work faster and cheaper.
    And look; I not trying to trash-talk the fluid flusher guy - that is not my point. I'm just pointing out that his priorities are almost certainly in at least some contrast to yours, and they could easily be diametrically opposed. <g>
    PHM
  17. Oct 14, 2014 at 8:59 AM
    #277
    Tacoma00
    Tacoma00 New Member
    Great post, thank you for the time and effort put in.
  18. Oct 14, 2014 at 8:45 PM
    #278
    Lester Lugnut
    It's possible he could be one of the more seasoned techs, but no matter. This is likely a flat-rate pay job(like most are these days) and the sooner he checks off on it the sooner get gets to start another.
    Use this thread and the one by Fortech and do this job yourself. It ain't that hard and in the end you will know it was done by the one and only person on the planet who gives a phuck about your Tacoma.
  19. Oct 28, 2014 at 10:12 AM
    #279
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
  20. Nov 3, 2014 at 9:12 AM
    #280
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    Excellent writeup except for one quibble.
    I see here and several other trannie threads saying replacing the crush washer is optional.
    I must disagree with not replacing the crush washers while spending time and money to flush.
    Simply not sound practice.
    By definition, crush washers are one time use.
    It is what seals and prevents seepage.
    A new crush washer and a torque wrench is the best defense against stripping the plugs while ensuring the plug is tight.
