DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Apr 1, 2015 at 9:27 PM
    #321
    iJDub
    iJDub Well-Known Member
    Can we get a full write up :D
  2. Apr 5, 2015 at 12:41 PM
    #322
    bent wrench
    bent wrench New Member
    Glen
    Albuquerque
    07 4-runner v-6
    Great post mountain lion. I have been an Allison Heavy/Medium truck tech pretty much all my working life. The total flush you describe is how it has been done since the creation of the slush box it's self. Thanks for adding instructions on the little idiosyncrasy's of the Toyota system. People do not waste your money on the dealership flush. Follow mountain lions instructions and do it yourself. I used Valvoline Max Life full synthetic trans fluid. It says right on the jug it is recommended for Toyota's calling for WS oil. I found the oil at my local Wal-Mart for under 17 dollars a gallon. Believe me, your trans needs a good flush every 50 to 60 thousand miles. Dirty/burnt oil is a tranny killer...
    Taco-Obsessed likes this.
  3. Apr 5, 2015 at 1:13 PM
    #323
    bent wrench
    Glen
    Albuquerque
    07 4-runner v-6
    Klipp 11 - You are on of the lucky ones, a man who can take his dip stick in his hand and not worry about all of the other B.S. Follow the first part of mountain lions directions. Drain tans and replace drain plug. Roughly re-fill the sump with what you drained. Dis-connect "from cooler" line from trans and attach whatever you need to get it into a marked jug. Start and run truck until you have run as much oil into the jug as you added in the initial re-fill. Stop engine and repeat this process as many times as needed. When oil coming from the "from cooler" line is as clean as it was when you added it to the sump, re-connect the "form cooler" line and top of trans sump(Engine running). Your slush box will love you long time for showing her this TLC.
  4. Apr 13, 2015 at 6:27 PM
    #324
    Chrisbnugget
    Chrisbnugget New Member
    Just started this guide for my 05 V8 RWD Tow Package. Here is the color of the 3 qts that came out. Hasn't been touched for 124 K miles due to multiple Toyota dealerships saying it's sealed for life and shouldn't be touched (no towing). Is the color due to a different spec of ATF or is that just how it looks from the mileage? It still smells sweet.
    Left: Old
    Right: New
  5. Apr 20, 2015 at 5:34 PM
    #325
    diyautoftw
    diyautoftw Member
    Nick
    Milwaukee, WI
    Thanks for the info!
  6. Apr 30, 2015 at 9:33 AM
    #326
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    Nice, do I really have to flush the transmission,? I have 46k now, first time doing transmission work.. Thx
  7. Apr 30, 2015 at 5:11 PM
    #327
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    I would just do a drain and refill until close to 100K, just my opinion if you don't tow or haul heavy loads a lot.
  8. May 7, 2015 at 6:14 PM
    #328
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    do you think by unplugging both hose i could use the line that go back in the trans to suck fluid directly from the container ??
  9. May 7, 2015 at 6:29 PM
    #329
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    No the trans pumps fluid out, it does not suck it in.
    Not even if you run the truck in reverse..
    hamburglar and beertimecontinuum like this.
  10. May 8, 2015 at 9:45 AM
    #330
    BazzokaJoe
    Olivier
    Canada,QC
    TRD OffRoad
    the trans pump to pumps fuild out need to suck in some fluid .....
  11. May 8, 2015 at 9:53 AM
    #331
    Sandman614
    Tim
    '06 SR5 Off Road
    You can't use the trans to pull fluid in, use gravity, or some other pump to put it back in.
    Such as this [​IMG]
  12. May 8, 2015 at 10:41 AM
    #332
    BazzokaJoe
    Olivier
    Canada,QC
    TRD OffRoad
    there is 2 line going to the cooler one is the pressure (push going to the cooler) the other "return" (suck going back in trans) if i unplug both line ,can return be use to suck in fuild ?
  13. May 8, 2015 at 10:45 AM
    #333
    Sandman614
    Tim
    '06 SR5 Off Road
    No. The trans only pushes out.. The second line has no suction.
  14. May 8, 2015 at 7:34 PM
    #334
    BazzokaJoe
    Olivier
    Canada,QC
    TRD OffRoad
    yeah but has long there is fluid going to the pan it should suck in from the return line i guess i nee to try
  15. May 8, 2015 at 7:59 PM
    #335
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Sorry but it doesn't work that way. But hey it's your transmission.
    Crom likes this.
  16. May 8, 2015 at 8:27 PM
    #336
    Sandman614
    Tim
    '06 SR5 Off Road
    Feel free to try but before you potentially screw up your truck poke a bunch of holes in a jug and try to suck the liquid out the top...
    We're not blowing smoke, it's been tested and doesn't work.
    I also caution you to read this entire thread because obviously you missed the dozens, myself included, that have asked this exact question.
    Crom likes this.
  17. May 16, 2015 at 7:05 AM
    #337
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    I don't know if it's been mentioned in this thread yet or not but...
    DO NOT SHUT THE TRUCK OFF WITH THE LEVEL CHECK PLUG OUT
    I made that mistake yesterday :D
    My transmission must have been a bit low from the factory as I'm fairly certain I put a bit more in than I pumped out but didn't get a trickle when I checked the level.
    I turned the truck off to add some and it started pouring out of the level check hole.
    Fortunately, I had a pan under there, I caught it quick, and I had enough fluid left over to fill it to the correct level. :thumbsup:
    Crom likes this.
  18. May 20, 2015 at 2:45 PM
    #338
    Z E R 0
    California
    02 Tacoma 4x4
    If I am not doing a full flush, just drain/fill.. How many quarts do I need? 4qts? Thx
  19. May 20, 2015 at 2:46 PM
    #339
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Like 3.5ish, so 4 will do it.
  20. May 20, 2015 at 2:49 PM
    #340
    Z E R 0
    California
    02 Tacoma 4x4
    Ok thx!
