DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Jan 25, 2010 at 2:32 PM
    Tripletpkc
    Tripletpkc Active Member
    Pete
    NJ
    2009 Red DBL Cab Prerunner
    Excellent write up.
    I was wondering if Mountain Lion got his oil condition sample results (results to affirm whether or not this early of a flush really needs to be done or not) back from Blackstone. Maybe I just missed the updated post. Has anyone seen the results?
  2. Jan 25, 2010 at 3:38 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Interested in this also. Reports from bobistheoilguy suggests Toyota WS begins to shear way before the 100K.
  3. Jan 26, 2010 at 6:51 PM
    JAG
    JAG Well-Known Member
    +1 for sticky
  4. Feb 4, 2010 at 2:14 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    awesome write up... first one ive seen about the 4.0 liter tranny, i have the TRD 4x4, is this the same tranny??
  5. Feb 4, 2010 at 2:26 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    Get job. I'm really interested in the oil analysis. Any word yet?
  6. Feb 24, 2010 at 4:32 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Exceptional write up! Good job! :thumbsup:
  7. Mar 1, 2010 at 9:00 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
    How about if you not only used the tranny's pump to drain the old but how about putting the return line in a container of fresh fluid? Would it suck up the new and would it do so at a similar rate as the discharge?
  8. Mar 1, 2010 at 9:47 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    Doubtful. If the tranny uses a gear pump the return line would not have any vacuum on it. Relying strictly on the pressure exerted by the pump. You might be able to use a gravity system on the return line to add fluid, but the levels need to be watched very closely. If you could setup a sealed system that used two tanks and air pressure from the expelled fluid to force new fluid in it might work. You'd still want to start by draining the pan and adding clean fluid...
  9. Mar 1, 2010 at 10:03 PM
    BTO
    California
    I'm thinking about trying the gravity feed method.
  10. Mar 22, 2010 at 9:38 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Helpful. At what mileage should this service be done?
  11. Mar 22, 2010 at 10:53 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    how much is this service at Toyota?
    I mean, you just paid $150 for just the fluids.....
    And update on oil results?
  12. Mar 22, 2010 at 11:59 PM
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    Around 100K. Toyota says 90k I think.
  13. Mar 23, 2010 at 12:42 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Thankks but why did he do it at 45? Just to do it?
  14. Mar 23, 2010 at 9:59 AM
    mountain lion
    mountain lion [OP] Member
    VA
    06 PreRunner
    URD TCAI, MAF Cal, o2 Sim, DT Headers
    They will not do this service at Toyota for you. They do the drain fill which is 4 qts of WS. It's not a full flush.
    I paid $105 + $10 Amsoil premier account for the 14 qts I used. $115 total. The dealership isn't going to get close to that price and only use 1/3 of the fluid. Last I was quoted was around $180 w/ discount.
    This doesn't even make sense. If Toyota says 90, why would do 100 then? Don't spread misinformation.
    The recommendations are 60k mile interval for severe usage. IE towing, excessive city driving, off road, etc. This really is most city owners.
    Standard is / (was?) 100k miles, but reports are saying they're bringing it back down to 60k miles regardless of severe classified use or not. This was posted somewhere on TW from a valid source.
    Partly yes, and partly because I don't trust the WS fluid to last that long - especially to 100k.
    I still have the original sample fluid in the garage. I didn't get it tested yet. I forgot but also I knew the results would be skewed with breakin metals. I need to have TBN on it, but just didn't feel like spending the $35 at the time. I'll send it in at some point, maybe with another UOA.
    If you trust it to 100k miles, that's fine. If your mom and dad bought your truck for you and you don't care about it, that's fine too. For the rest of us who like preventative maintenance - here's how to do it.
    If you have any other questions, just PM me - I'm still around and don't need the thread filled up with bad info or people answering on my behalf.
    There isn't a write up other than ForTech's drain/fill process - and I did it for myself and for everyone here to benefit from who wants to go a step further. If you've got nothing constructive to add (which you haven't), move along. If this helped you out, throw up a thanks or send me a PM if you have another question.
  15. Mar 23, 2010 at 2:01 PM
    #35
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Blake,
    Sarcasm and joking around are not well understood all the time in the forums. Oftentimes misunderstandings develop over this. When I saw your post I understood it same as mountain lion, I thought you were pissed off or something.
    If you intend sarcasm in your post, please it helps to use one of these ---> :rolleyes:
    Or maybe a big fat grin ---> :D
    All the best,
    -Crom
  16. Mar 23, 2010 at 2:03 PM
    #36
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    i'm just glad you didn't accidently drain your engine oil while doing this.
  17. Mar 23, 2010 at 8:26 PM
    #37
    Wrencher86
    Wrencher86 Well-Known Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    That is exactly how a lot of trans flush machines works. I'm really surprised to hear that Toyota only does drain and fills at the dealer. This is a great write-up. But what a pain in the ass.
    One more reason to drive a manual, I guess.:D
  18. Mar 23, 2010 at 8:57 PM
    #38
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Nice write up! I went to 3 local dealers trying to get a cost for the full flush. 1 of them said they don't even do it, another said they would but they don't have the right machine (apparently need a separate machine just for WS), and the third, Michael's Toyota in Bellevue, said I don't need to do it, but they will if I want them to. They quoted me $260. I'm not sure if they have a separate machine or if one is even needed, but the lack of consistency between shops made me a bit leery. That and the price of course.
    I did the drain/fill myself, thinking of tackling this full flush at some point. Glad to know there's a good DIY! :D
  19. Mar 24, 2010 at 9:16 AM
    #39
    mountain lion
    VA
    06 PreRunner
    No hard feelings dude, I didn't read it as a joke - and a lot of work went into all this - I just wanted to keep things on track, apologies from my end too. :cool:
  20. Apr 5, 2010 at 8:31 PM
    #40
    motox_315
    motox_315 Member
    Sean
    Sac
    2010 DCLB SR5 4x
    3" truxxx lift
    This is not a good idea to do. Youre fluid level can be way off with only a few minutes / degrees difference and cause major shifting and or slippage issues. If you only have 45 or 50 thousand miles and you wreck your trans its on you. If you have the dealer do it its on them. Not trying to come off as being rude but with the dollar savings comes great liabilities. PS. If you had looked at your WS fluid it would have looked darker at just 5k miles. Just because WS fluid looks discolored does not mean that it is time to change it.
