DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Mar 10, 2016 at 10:00 AM
    #501
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Neither do I.
    El Tano[QUOTED] likes this.
  2. Mar 14, 2016 at 9:44 AM
    #502
    NikoVee
    NikoVee you're a towel
    Niko
    Santa Cruz, CA
    '08 PreRunner V6 SR5
    6" Fabtech Kit, Bilstein 5100's, Total Chaos UCA
    woo..just read all 27 pages of this very informative thread. thanks mountain lion and everyone that's contributed their experiences here! i am looking forward to doing the flush sometime this week, but before I begin I have a few questions i'm hoping some of y'all could help me with:
    1. I plan on doing the full pan drop and screen replacement. I'm at a little over 61k, but I bought the truck used with very little service history, and I don't know how rough the original owner was so I just want to get this done for my peace of mind. it was mentioned in somewhere in the thread that the pan bolts are prone to corrosion due to the design allowing for crap to get on the end of the threads. Is it ok to soak the bolts with PB blaster or liquid wrench beforehand? Would I have to be super careful and clean all the threads afterwards so none of it gets in the tranny? And someone mentioned torque ratings being "dry" vs. "wet" - how much of a concern is this?
    2. I need to perform the output shaft seal replacement as it hasn't been done yet and there's clearly a slow leak of fluid on the output shaft. Should I do this before the flush, or after?
    3. I don't have the tow package, and don't really plan on towing much, but I will be putting bed rails and throwing on a tepui, along with hauling a decent amount of camping gear for some long excursions, so I'm considering adding an aftermarket cooler. Should I install it inline with the radiator cooler, or bypass it? And again, should I install it before or after the flush?
    Thanks for all the help!
  3. Mar 14, 2016 at 4:32 PM
    #503
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    I would fix the seal first then add the trans cooler if you like, but with only 61K i would not mess with removing the pan because the metal screen should be fine and doesn't need replacing, that's up to you....
    NikoVee likes this.
  4. Mar 14, 2016 at 6:36 PM
    #504
    NikoVee
    Niko
    Santa Cruz, CA
    Thanks for the input, that's probably the route Im going to go. I realize it's not necessary to change the screen but I really don't know how the original owner drove the truck and if there are any shavings I want to get them out for sure. It's probably overkill but at least I'll know the pan is clean!
    toyotaman29 likes this.
  5. Mar 14, 2016 at 8:14 PM
    #505
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yep, do the seal replacement and add trans cooler first, preferably same day you do flush so that you don't have to top off ATF multiple times, which you will see can be a PIA, especially if adding ATF via the filler hole. I think torque on pan bolts is 50 in lbs, which seemed excessive to me - my other Toyota products call for 30-35 and that's what I went with and have no leaks (I check torque every other oil change).
    RE #3, you can go either way with 'wiring' trany cooler with the radiator cooler. There are pros and cons to both. I prefer NOT 'cause you'll have more hoses that can break/leak on you. Mainly, 'cause if the radiator cracks (due to overheating, road debris, etc...) and leaks coolant into the ATF reservoir, you'll ruin your trany; ask the mid 2000 Nissan owners how that feels like! Just make sure the after market cooler capacity is equal or larger than current reservoir capacity (I don't know that that is).
    toyotaman29 and NikoVee like this.
  6. Mar 15, 2016 at 2:28 PM
    #506
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
  7. Mar 16, 2016 at 6:21 PM
    #507
    NikoVee
    Niko
    Santa Cruz, CA
    Thanks! Went with the hayden 679, gonna do the bypass. only cons I seem to find to that is lower startup temp, but where I am at it rarely ever gets below 40F at night/dawn. I'd rather sit in the driveway warming up a lil longer than having to deal with radiator fluid in my tranny. Broken radiator is what killed my previous vehicle, which led me to getting the taco. Silver linings!
    Any updates on this? Im experiencing similar symptoms, except in the mornings when I go to work and hit the highway. Though juxtaposing these two quotes one after the other makes me wonder if its a warm up issue..
    Did you blast them from the bottom or the top, or both? And how meticulous were ya wiping of the excess pb before reassembling?
  8. Mar 16, 2016 at 8:10 PM
    #508
    ChandlerDOOM
    ChandlerDOOM International tent trafficker
    Chandler
    STL
    Truck
    37s yo
    subbed for later
  9. Mar 29, 2016 at 10:04 AM
    #509
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :bowdown: Thanks for the idea of the drill pump. Made changing the fluid so easy.
    Used these tubes and the drill pump to pump the new fluid in. Didn't take very long!!!
    Fluid had 61000 miles on it and wasn't too dirty.
    Crom[QUOTED] likes this.
  10. Mar 29, 2016 at 2:19 PM
    #510
    jasonct
    jasonct Well-Known Member
    CT
    2021 F150, C7 Grand Sport
    50 in/lbs is only 4.17 ft/lbs.
  11. Mar 29, 2016 at 2:48 PM
    #511
    Chuy
    Lakeside, CA
    Silver Taco
    When I started torqueing my bolts after having done so on my other three Toyota products, calling for 30-35 in/lbs and having same size bolts and pan gauge, 50 just seemed too high - it felt as if I was distorting the pan holes and the filter started squishing out. I stayed with 30 and don't regret, yet. I am constantly checking for leaks and re-torque them. Everything OK so far, and it's been about 30K since last ATF filter change.
  12. Mar 29, 2016 at 3:36 PM
    #512
    jasonct
    CT
    Even 12 ft lbs for the strut tops on my Subaru's was easily exceeded with just 3 of my fingers on a 1/4" drive ratchet. I had to buy a special in lbs torque wrench when I modified my Cub cadet. Are you sure your torque wrench is in in lbs and not ft lbs? :cool:
  13. Mar 29, 2016 at 4:35 PM
    #513
    Chuy
    Lakeside, CA
    Silver Taco
    Yes, I have three torque wrenches: quarter, three eighths, and half inch. Guess which is the in/lbs? ;)
    As I mentioned, torque for the other three Toyota products with same size bolts and pan thickness ranges 30-35 in/lbs. (Lexus ES350, Corolla, & Camry.) I will concede if I had done the Tacoma first, the other three may have felt under torqued. :humble:
  14. Mar 29, 2016 at 4:52 PM
    #514
    jasonct
    CT
    Gotcha! :thumbsup:
    What size are the bolts? an M6 x 1.00 is supposed to be at 92 in/lbs dry; M5 x 0.80 at 54 in/lbs dry. Or the other possibility can be like the Brembo torque problem with STI's where they didn't convert it right and had:goingcrazy: everyone stripping their caliper mounting bolts tightening to 114.3 ft/lbs vs 114.3 N-m aka 80 ft/lbs.
  15. Mar 29, 2016 at 5:07 PM
    #515
    Chuy
    Lakeside, CA
    Silver Taco
    Yep, M6 bolts. 92 inch is max, right? Whats the minimum? can be very low if you use threadlocker.
  16. Mar 29, 2016 at 5:17 PM
    #516
    jasonct
    CT
    92 in lb is to meet the clamp load as 75% of proof load per ISO 898-1. Lubed, this number drops to only 69 in/lbs. (This is based on a 8.8 grade bolt.)
    Edit: here's a cool calculator I found online: https://www.fastenal.com/en/83/torque-calculator
  17. Mar 29, 2016 at 6:16 PM
    #517
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    How many miles are you going between filter/strainer changes? Any pics? Most people say not to bother changing the filter, it's just a screen and shouldn't clog for a long time. What do you use to re-seal the pan, a preformed gasket or gasket maker?
  18. Mar 30, 2016 at 2:16 AM
    #518
    Chuy
    Lakeside, CA
    Silver Taco
    07 sport 4x4 likes this.
  19. Apr 1, 2016 at 2:46 PM
    #519
    NikoVee
    Niko
    Santa Cruz, CA
    got my report back from blackstone, first tranny flush at 63k, nothing out of the ordinary
  20. Apr 1, 2016 at 8:32 PM
    #520
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    So your saying you can still go over 63k miles, not change the oil and it's still ok?
