DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Nov 5, 2016 at 12:10 AM
    #601
    MysteryScienceTaco
    MysteryScienceTaco New Member
    Bradley
    Denver, CO
    07 DCSB TRD Sport
    3 in lift, 18in wheels, BFG TA/KO2
    I just did this on my 07 4wd. I cant be sure, but I'm pretty sure it was the original fluid with 77,XXX miles. Fluid was a bit dirty, but didnt smell burnt. Took me about two hours - using a drill pump helped a ton. Used 11.5 quarts of Valvoline MaxLife. Shifts super smooth and I saved a load of cash doing it myself.
    Props to the OP!
    Pabloeeto, NAAC3TACO and Crom like this.
  2. Nov 7, 2016 at 10:56 AM
    #602
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i did this on my 2006 on saturday. pretty easy process, because i had no service records on my truck ( and 78K miles of uknown amounts of service) i took it a step further. i dropped the tranny pan and pulled off the valve body and cleaned. i replaced the valve body o-ring and pan gasket and reassembled with all new bolts and a new drain plug. my bolts and plugs were pretty crapped up with rust. to my surprise, the fluid was not all that dark, it didnt look to be in too bad of shape. but hey, i bought the 14 quarts and all the parts, i may as well finish the process. the only issue i ran into was the check plug was stripped out, i could not get my allen tool to bite into it. eventually got it out with a bolt extractor, but luckily i figured this would happen so i was able to replace it with a brand new bolt and washer. all said and done, i flushed out about 13.5 quarts through my system. i was surprised, there was a noticeable difference. my harsh 1-2 shift is gone and the downshifts are much crisper. definitely worth the 3 hours i spent on it lol, thanks to all who posted in this thread!
    fla_sun, MysteryScienceTaco and Crom like this.
  3. Nov 26, 2016 at 10:22 AM
    #603
    Rosa Klebb
    Rosa Klebb Member
    Tucson, AZ
    2012 4X4 Access Cab
    Still Thinking ? ? ?
    After originally planning to do a drain/refill, I eventually decided on the full flush after reading all the threads multiple times. Everything went fine but took longer than planned (~ 3 hours). The transmission feels much smoother now at the correct fill level and with the new fluid. Some observations/comments:
    • My 2012 with factory towing package had 83,000 miles and was low by almost a quart. Based on the comments here regarding factory under fill contributed to my decision to do the full flush.
    • The old fluid was slightly dark with no bad smell. It could have gone longer.
    • I used the sprayer method at the transmission cooler with a new 1 gallon garden sprayer from Ace Hardware (+ 20% off coupon) and 3/8" ID plastic tubing. Pumping was a easy and very little spills or leaks
    • The biggest spills came after disconnecting the 2 transmission cooler hoses. I stuck the hose ends in a couple of empty water bottles to stop the mess from growing.
    • The most unexpected time-consuming step was removing the front grill. I struggled for around 45 minutes. Removal will be easier next time.
    • Did the temperature check using an OBD2 WiFi code reader, iPad, and OBD Fusion app with custom PID. I had tried the wire temperature check method several times and could not get it consistently right.
    Many thanks to mountain lion and the others here that provided the helpful details and gave me the confidence to do it :)
    Biscuits and Kolunatic like this.
  4. Nov 26, 2016 at 3:28 PM
    #604
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Same here. Finally got mine done this past week only I used drill pump. Can't hardly feel it shift.
    Thanks TW!
  5. Nov 26, 2016 at 7:48 PM
    #605
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    What am I missing here? I've flushed twice and have never touched the front grill.
  6. Nov 26, 2016 at 9:16 PM
    #606
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Easy access to trans lines at cooler if with tow package.
  7. Nov 26, 2016 at 9:26 PM
    #607
    Chuy
    Lakeside, CA
    Silver Taco
    I have the tow package. Seemed pretty easy from below. Tap into the return line to push through the new fluid and catch the old stuff coming out.
  8. Nov 27, 2016 at 12:59 AM
    #608
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I washed and cleaned my radiator afterwards. To each his own. Besides 2 screws and 2 clips it takes a couple minutes to Remove. I also replaced the lines to the cooler afterwards.
  9. Nov 27, 2016 at 12:31 PM
    #609
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    yea I left it on and was able to wedge a 1 gallon jug in there put the hose in to it. Just pumped old fluid in to it, drill pump new fluid back in. Repeat 2x = done. Except drive around a bit then pull check plug some came out. Good enough for me. It worked great. Anyhow its good to know its all flushed. :thumbsup:
  10. Dec 12, 2016 at 7:57 PM
    #610
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Where r u buying the AT fluid? couldn't find any at wally mart. too expensive at POS autopart stores.
  11. Dec 13, 2016 at 9:37 AM
    #611
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I guess valvoline maxlife doesn't seem expensive at $7.40/quart anymore.
  12. Dec 13, 2016 at 8:52 PM
    #612
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    You can get the gallons at Walmart for ~$18.
  13. Dec 13, 2016 at 9:03 PM
    #613
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Yes when in stock
  14. Dec 15, 2016 at 1:26 AM
    #614
    Chuy
    Lakeside, CA
    Silver Taco
    You can buy it online and pick it up at your wallyworld with no shipping charges. The site will also tell you if your store, or a nearby wallyworld, has it in stock.
  15. Dec 15, 2016 at 7:36 AM
    #615
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Gotcha, I'm buying at autozone. I'm getting $20 back after a few more purchases of $20 or more so that'll compensate. :thumbsup:
  16. Dec 15, 2016 at 6:51 PM
    #616
    Chuy
    Lakeside, CA
    Silver Taco
    You fell right into the dealer/manufacturer's trap. If the bottle/can says it's compatible with WS, it's OK to trust them. They wouldn't be in business if they made false claims; just stick with reputable name brands. In this case the known WS compatible non-Toyota brands include Valvoline, SuperTech, and Amsoil.
    See https://www.tacomaworld.com/threads...a-ws-atf-automaitc-transmission-fluid.373083/
    Crom likes this.
  17. Dec 19, 2016 at 8:41 AM
    #617
    HB Taco
    Curt
    Yup stick with the OEM stuff :) So when I need some Maxlife ATF it'll be on the shelves. It seems word is getting out on how good the stuff is so no more :(. I've put it in several vehicles all with good results. I guess I got lucky I needed 3 gal and that's all they had.
    07 sport 4x4 and NAAC3TACO like this.
  18. Jan 26, 2017 at 5:11 PM
    #618
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Did this today
    Biscuits likes this.
  19. Jan 26, 2017 at 5:12 PM
    #619
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  20. Jan 26, 2017 at 7:08 PM
    #620
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
