DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. May 19, 2017 at 12:48 AM
    #681
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    In hot climate and doing a lot of stop and go; I can really see the benefit of a secondary cooler; however I think during the winter it'll be best to find a way to block airflow to the secondary cooler as it'll help keep the transmission running at optimum running temps. Yeah once your on the highway and you really get going the temps really stay in check well.
    But wow 8200lbs is really pushing it for the little tacoma lol
    07 sport 4x4[QUOTED] likes this.
  2. May 19, 2017 at 3:33 AM
    #682
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I have always been told that as long as the torque converter is locked it's not generating heat. When the converter unlocks and you notice the small rpm increase, such as going up a hill or increasing speed, it's generating heat. But, if you were to try to force the converter to stay locked it would lug the engine, which isn't good either.
    On a side note, I noticed last night that Pennzoil makes a 'Platinum LV' fluid that is Toyota WS compatible. Can't say I've seen it for sale anywhere though.
  3. May 19, 2017 at 10:15 AM
    #683
    Borealis
    Borealis Active Member
    Willy
    Yukon Territory
    1980 4x4 Pickup, '96 White Taco,'96 Blue Taco,'06 TRD Taco
    bush-road clusterfuck
  4. Jun 24, 2017 at 7:18 AM
    #684
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Huge thanks for this thread. Did my flush yesterday. Everything went smooth. I used a modified sprayer as seen in some of the pics. I did it 2 qts at a time and pumped a total of 12 out and 12 in (3 gallons). I did not drain the pan first. I'm at 60k and figure I'll drop the pan at 100k and see what she looks like. The old fluid at 60k looked like coffee - brown. Glad I did it now. And I don't tow or wheel - just a lot of sustained highway driving at 70 mph.
    The other reason I'm glad I did it was I was about a half quart low from factory. I was super careful when I drained to measure everything and put back in exactly what came out. When I pulled the check plug, not a drop came out. I put in another 1/2 quart and still nothing. I added a couple more ounces and she started to trickle.
    Only PITA in this process was the temp mode. I jumped the OBD wires and could get it to work but it was too hot yesterday because I drove to the store to buy and extra quart. Took forever to cool down. I ended up letting it sit overnight and then warming it up from cold. That was taking a while so I made 2 trips around my block and it finally hit the sweet spot and the light stayed on. I think I'm going to find a way to get a temp reading without the wire jumping business. I spent way too much time bent over to see the OBD port, and then starting, and pulling the wire, and doing it again...it works but swapping the fluid in and out was the easier half of the process. I think if I had a temp reader it would be even easier than an oil change.
  5. Jun 24, 2017 at 9:14 AM
    #685
    jca
    jca Well-Known Member
    My bad. Here it is. I just plumbed the factory cooler's outlet line into the auxiliary cooler's inlet line, then auxiliary outlet line back to factory return line. My normal route involves driving through a bunch of inclines and this mod has certainly paid for itself. As people have stated, over cooling was something to keep in mind, so I went with a 677, since it seemed that a 678 or 679 could have been overkill.
    Pabloeeto[QUOTED] likes this.
  6. Jun 24, 2017 at 7:54 PM
    #686
    Johnjaz
    Johnjaz Well-Known Member
    AZ
    07 DCSB 4x4 Sport
    Dented Bumper
    Wanted to thank mountain lion for this! Went through this today along with my front and rear diff, and serpentine belt. Shamefully it's the first time in 145k that I have done any of this maintenance. Overall, my fluids were not too bad.
    Edit to add that I wasn't able to complete the entire project as my tranny was too hot to check the level due to the damn AZ heat. I'll get er tomorrow morning.
  7. Jun 26, 2017 at 8:15 AM
    #687
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Yikes!
  8. Jun 26, 2017 at 11:14 AM
    #688
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    One of our 3/4 tons was out of commission. The taco tows it well, just gotta make sure to leave plenty of stopping distance. Take it easy and you'll be fine. The road I was on was pretty flat, it's not like I was taking it through the Tennessee mountains.
  9. Jun 26, 2017 at 1:05 PM
    #689
    bendilzerian
    bendilzerian Well-Known Member
    Houston
    2015 DCSB White TRD Sport PreXrunner
    What's everyone going with for fluids?
    Pabloeeto likes this.
  10. Jun 26, 2017 at 1:12 PM
    #690
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    I went with Valvoline MaxLife WS.
    NAAC3TACO likes this.
  11. Jun 26, 2017 at 1:19 PM
    #691
    bendilzerian
    Houston
    I ordered Amsoil ATF. Haven't used Valvoline before but I did see a lot of guys went that route. How long can I expect to run this fluid? I'm doing my swap early, only 26k on the truck
  12. Jun 26, 2017 at 1:20 PM
    #692
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I went with Maxlife on my last drain/fill. Currently running a mix of WS and Maxlife. These transmissions aren't picky. Toyota or Aisin WS is good stuff though.
  13. Jun 26, 2017 at 1:21 PM
    #693
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Valvoline says to follow the manufacturers recommendation.
  14. Jun 26, 2017 at 3:02 PM
    #694
    Pabloeeto
    Paul
    San Diego
    I'm not totally sure about the change interval on the AMSoil or Valvoline and Toyota's change interval recommendation seems a bit long, I'll probably do a drain and fill every 40k on my truck.
  15. Jun 26, 2017 at 3:21 PM
    #695
    80schild
    Chad
    Flori-Bama
    I used Maxlife full synthetic in all of my vehicles. I have done 3 drain/refills on both of my Tundras, and 2 on my Tacoma.
    My 09 Tundra uses the same 5-speed auto as the Taco, and around 97k miles I started noticing a weird misfire type feeling when it would shift through the gears under moderate acceleration. I thought maybe it was a leaky spark plug tube o-ring that had fouled a plug, it didn't feel like typical "rumble strip" type shudder. Amazingly, after changing the fluid with Maxlife the misfire/skipping feeling went away and now it shifts smoother than ever.
  16. Jun 26, 2017 at 4:00 PM
    #696
    bendilzerian
    Houston
    Thanks, that's what I was thinking, every 50ish.
  17. Jun 27, 2017 at 9:56 AM
    #697
    Bigbunzilike
    Bigbunzilike Well-Known Member
    Jeff
    Pittsburgh
    2011 TRD Sport DCLB
    Clazzio leather seats, Bedrug, Leer topper RX100 cover, bull bar, 4X4 lighted switch, Heated Seats, LED bed lights.
    Will this work on only the 2 wheel drive Tacoma or is it also good for the 4 wheel drive?
  18. Jun 27, 2017 at 11:59 AM
    #698
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    The OP did this on a prerunner. The transmission is the same, just has a different tailshaft for a prerunner.
  19. Jun 27, 2017 at 12:50 PM
    #699
    Bigbunzilike
    Jeff
    Pittsburgh
    2011 TRD Sport DCLB
    Thanks
  20. Jun 27, 2017 at 5:33 PM
    #700
    westtexasbaja
    westtexasbaja Member
    Thanks for the write-up. Completed this last weekend without any trouble on my 2012 DCSB 4wd Tacoma. Just bought it used with 60,000 miles. I had a full 4 liters from drain + pan drop. Typical slightly fuzzy magnets. WS fluid was typical redish-light tan (smelled different though). Replaced WS with Maxlife Synthetic. Replaced filter & gaskets. Used all four gallons (flushed too long...). Completed AT Temp check mode and topped off. Went on a 10 minute highway test drive and seemed to shift fine. Came home and stopped but still in D and there was a short period of low vibration then it quit. Shift to R, foot on brake, low vibration then quit. Shifted between D & R several times (8-10 seconds each), foot on brake and it slowly went away. Doesn't do it now. Thoughts?
    Other thoughts:
    If you drop the pan, be sure your rag doesn't leave behind a bunch of lint.
    Double check those torque specs. Almost used ftlb instead of inlb...
    I pulled the cool hose completely off the trans cooler so that cooler got flushed too.
