DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Feb 20, 2018 at 11:39 AM
    #961
    jca
    jca Well-Known Member
    Hey everyone,
    Posted this in the tech section and got no answers.
    Flushed 5K miles ago, but finally got around to changing the trans filter and pan gasket on my 2nd gen at 60K miles. Having never stripped a pan bolt ever, it happened yesterday on my drain plug. Lesson learned, do not torque these to FSM spec. Other than that, everything else went smoothly, with no leaks to be seen. This truck is my DD, but I don't wanna risk any huge metal shavings floating around in the fluid. I inspected the bolt before puming any new fluid in and the threads look a little marred, and it was just a bit tougher tightening the bolt onto the pan. Will I be safe driving this thing until my new pan arrives?
  2. Feb 20, 2018 at 12:04 PM
    #962
    SebSA
    SebSA Active Member
    2013 DCSB 4x4 4.0 Auto
    Sounds like I may have done the same thing as you JCA. I had dropped the pan and done a drain and fill and was torquing the drain plug when I felt it strip. It had gotten pretty tight, but had not reached 15 ft/lbs. I put a little pressure on the wrench to see if I'd really screwed up and it felt pretty tight. I had a trip the next day and drove on it for over 1200 miles. I removed the plug when I got home and the threads were not evenly spaced but i don't think any metal had come off. I had a new plug and when I threaded it on the pan it turned freely (the stripped plug did not).
    Unless you want to change your pan, you may want to just try changing the plug. My pan threads were fine, it was only the plug bolt that stripped. I think i torqued to 10-12 ft/lbs and quit tightening. I agree with you; spec seems awful tight.
    jca likes this.
  3. Feb 20, 2018 at 12:27 PM
    #963
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    This is why I never use a torque wrench for drain plugs. So much easier to get a true feel with a ratchet.
    jca likes this.
  4. Feb 20, 2018 at 12:32 PM
    #964
    jca
    Okay, I feel a little relieved now. Either way, I'm taking this as a lesson learned.
  5. Feb 20, 2018 at 7:21 PM
    #965
    jca
    Yup, glad I changed the pan. Threads were ready to break off the original pan
  6. Mar 9, 2018 at 12:29 PM
    #966
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Napa has Valvoline Maxlife ATF on sale for $3.99/quart through 3/31/18. IMG_8204.jpg
    Biscuits, fla_sun and DoorDing like this.
  7. Apr 2, 2018 at 7:38 AM
    #967
    add144
    add144 Member
    2015 Tacoma PreRunner
    Can anyone help me verify the gaskets? #35178-30010 for the overfill and drain, right? Does the fill have a gasket?
  8. Apr 3, 2018 at 12:51 PM
    #968
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I agree when installing my new pan. 12ft lbs seems to work using a new oil drain washer.
  9. Apr 3, 2018 at 12:53 PM
    #969
    fla_sun
  10. Apr 3, 2018 at 1:02 PM
    #970
    fla_sun
  11. Apr 6, 2018 at 6:31 PM
    #971
    tmangini2
    tmangini2 Well-Known Member
    Charlotte NC
    2021 Tacoma TRD Off Road
    good write up, thanks man, good find on here
    DoorDing likes this.
  12. Apr 23, 2018 at 9:00 AM
    #972
    Spoon93
    Spoon93 Well-Known Member
    Rogue valley
    06 DCSB SR5
    I've got a Scanguage set to read my trans temp so I am going to ask the dumb question; Do I still need to do the OBD port jump and shift sequence to get the AT Temp light on? Or can I just wait until I am seeing 130 give or take on the Scanguage?
  13. Apr 23, 2018 at 10:21 AM
    #973
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    No you do not. The wire jumping method tells you when the temp. is correct to check. But since you have a scan gauge, it will tell you the correct temp. Thus no need to do the shifting sequence and all of that. once its at the correct temp.with your scan gauge, let it idle, pull the check plug and replug after a small trickle.
  14. Apr 23, 2018 at 11:23 AM
    #974
    Spoon93
    Rogue valley
    06 DCSB SR5
    Perfect thank you!
  15. Apr 23, 2018 at 11:43 AM
    #975
    Driftns2k
    Driftns2k Well-Known Member
    C
    Corvette ls2
    Built and blown
    Nice write up! I need to do this
    Biscuits likes this.
  16. Apr 24, 2018 at 4:55 AM
    #976
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I think the lower end of the range is 115 or so, and it took quite a while to get it to that temp. I went back and forth between D and R just sitting in place to try to drive it up a bit. I don't think you'll see 130 unless it is super hot outside or you drive it around.
  17. Apr 24, 2018 at 7:46 AM
    #977
    Spoon93
    Rogue valley
    06 DCSB SR5
    Thanks for the heads up. This morning on my 3 mile drive to work the Scanguage didn't report a temp over 82. Started at 61 degrees.
  18. Apr 24, 2018 at 1:04 PM
    #978
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    My 07’s temp check range is 97°F to 115°F. I put it into temp check mode and then plugged my Ultragauge in the last time I did a drain and fill. Gonna just use the ultragauge to Check the fluid level from now on.
  19. Apr 24, 2018 at 2:43 PM
    #979
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    I'm due for the flush. Thanks for the write up, it looks like something I can tackle. :thumbsup:
  20. May 2, 2018 at 5:27 PM
    #980
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Sub’d
