DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. May 3, 2018 at 3:26 PM
    #981
    Csilver3
    Csilver3 Active Member
    I’ve done all the steps... when is the perfect time to Check my tranny fluid when the A/T Temp light is blinking or when it stays on? I’ve seen other posts where it says blinking light means it’s too hot to measure the fluid..I’m confused
  2. May 3, 2018 at 4:25 PM
    #982
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    When it stays on.
    07 sport 4x4 likes this.
  3. May 3, 2018 at 5:21 PM
    #983
    Csilver3
    You know how it says it will stay on for 2 seconds on N then going back to P another 2 second then goes away.... well mine just stays on it never goes away..
  4. May 3, 2018 at 5:21 PM
    #984
    Csilver3
    Does it have to disappear after two seconds when on N and and P?
  5. May 3, 2018 at 5:22 PM
    #985
    taco2010trd
    Tampa, Florida
    Let the truck cool down. Then try it again.
  6. May 3, 2018 at 10:15 PM
    #986
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
  7. May 4, 2018 at 11:45 AM
    #987
    Csilver3
    I got it to work... what the description doesn’t tell you is you count from N shift to D as two!!! So shift from N(that’s one) to D(that’s two) and continue to do so until you get to six... then shift back to P...
    My problem was I counted shift fromN to D as one when it should be two!!! I’m sure most of the people here that have been unsuccessful are doing or have done the same problem... but I’m good now and it worked thanks!!!
  8. May 4, 2018 at 11:49 AM
    #988
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    When I did mine, I just played the video while I sat in the truck and copied the moves on the shifting as it played. Did it two other times and muscle memory took over. Glad you got it figured out.
  9. May 4, 2018 at 11:56 AM
    #989
    Csilver3
    I guess I should’ve just done that... FYI I was also able to do it on an fj cruiser so it also works for an fj cruiser.... took me a whole day to do both cars...
    spitdog likes this.
  10. Jun 7, 2018 at 8:40 PM
    #990
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    OK, not to be the idiot here, I plan on doing this soon via the trans cooler.. when 3/8 tubing is mentioned, is this the 3/8 tubing with the 1/4 inside diameter?
  11. Jun 7, 2018 at 9:01 PM
    #991
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    3/8 inner diameter
  12. Jun 7, 2018 at 9:02 PM
    #992
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Ahh ok. Thank you! Crom's DIY flush post had the wrong type of tubing linked, lol!
    Csilver3 likes this.
  13. Jun 16, 2018 at 9:48 AM
    #993
    Cole_MT
    Cole_MT Well-Known Member
    Cole
    North Dakota
    2023 TRD Off Road
    I turned the first post into a PDF that is more print friendly, its 12 pages. Hopefully it helps someone else.
    DoorDing and PzTank like this.
  14. Jun 16, 2018 at 11:43 AM
    #994
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Just did mine today for the second time.
    I found that there is no need to use the fill plug on the tranny to replenish after pulling the drain plug. What I did was pulled the level checking bolt. Fill from the cooler line until you see fluid out of the check level. About 2 quarts. Plug the level check, then add another quart.
    I was using a drill pump.
    Then had the wife run the truck while filling. Have to say, the truck was draining faster than I could add. If I started to go too fast, my hose would pop off. What a fing mess.
    The fluid that came out didn't look too bad at all. I might go an extra 10k next time. Was 30k, this time and even did some towing with it. Have to say the Valvoline held up pretty well compared to the breakin/WS fluid as it was pretty dark on first change.
    Filled her up, ran the truck till she hit 115 on the scanguage. Check fluid while runng. Done.
    This is a great thread op. Thanks for posting.
    Kolunatic likes this.
  15. Jun 16, 2018 at 6:11 PM
    #995
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Just flushed mine today via the Crom method with the Wally World 5 dollar sprayer. Went through 4 gallons because the old fluid was BROWN! Then i had to buy another gallon because i wasnt paying close enough attention and drained more than i put in, so the check plug had nothing at all come out at 115. Also added 10 oz of lubragard platinum and i am definitely noticing a smoother shift now.. not sure if because of lubragard or the fluid change or both, but definitely not placebo! Used the bluetooth OBDII and torque app to measure trans temp. Easy process just kind of time consuming but its nice saving 200 bucks doing it myself!
    Kolunatic and taco2010trd like this.
  16. Jun 18, 2018 at 12:28 PM
    #996
    MariettaTaco
    MariettaTaco Well-Known Member
    Scott
    Marietta, GA
    2013 Superwhite 4x4 Dblcb
    Just did the full flush on my 2013 4x4 SR5 at 54k miles using Valvoline Maxlife ATF. It took 4 hours to do it myself at a normal working pace. The thing that took the longest was pumping 13 quarts in using the
    Custom Accessories 36670 Pennzoil Fluid Transfer Pump - Quart
    https://www.amazon.com/gp/product/B001DKQZ9Q/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    From Amazon. Don't use it. It took 300 plus pumps to empty each quart.
    For the tubing, I used the
    Valterra W01-1400PB 3/8" I.D. x 10' Clear Vinyl Tubing with Header
    from Amazon also and that worked real well. It went right on without having to do a relief cut.
    Thanks to Tunnel Vision 4x4's video on Youtube. That was really helpful. My WS ATF was dark red and didn't smell burnt. It looked like it could go another 10k, but I don't go off road or tow a trailer. I'll update my post if I regret using the Valvoline Maxlife ATF. So far, it shifts real well.
  17. Jun 18, 2018 at 1:33 PM
    #997
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Next time use a 5 dollar walmart pump sprayer with a 3/8 hose clamped to the stem, as per Crom. Super easy and i just tossed the sprayer after using it, although wasteful i couldnt justify cleaning the atf out just to store it to use in another 4 years.
  18. Jun 18, 2018 at 1:40 PM
    #998
    spitdog
    You need a drill pump. $7.99 Just attach you drill and pump away.Check below in the products discussed from Amazon.
    ImpulseRed008 and mrlee like this.
  19. Jun 18, 2018 at 4:07 PM
    #999
    MariettaTaco
    Scott
    Marietta, GA
    Thanks. I wished I had known this before. Probably would have cut 2 hours off of the 4 hour job! Those hand bottle pumps are ok for differentials, but not for transmissions.
  20. Jun 19, 2018 at 7:10 PM
    #1000
    mrlee
    Yeah, the drill pump is the way to go.
    Think I completed mine in under an hour. Honestly, it took more time setting up and getting the leaks taken care of during fill than actually flushing. Didn't have the right sized clamps. Nothing but an addl run to auto store. I despise the messy work, but push through as I know it needs done
    Did my son's Impala the same way. Didn't even drain the pan, and after 3 gallons it was looking pretty good.
