DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Sep 5, 2018 at 5:18 PM
    #1081
    Jamers99
    Jamers99 Well-Known Member
    2012 Tacoma PreRunner XSP-X
    Well the ambient temp was already like 90 degrees here in Florida and also I think I let it idle too long while I was re-reading my printed instructions. After a 45min cool down, I ended up adding 3/4 qt and then draining out 1/2 qt so I think it's good now. I lost my crush washer for the check plug (just reused old one) so I'll get a new washer and re-check the fluid level while I'm installing the new crush washer in a few days.
    TheDevilYouLove likes this.
  2. Sep 5, 2018 at 7:00 PM
    #1082
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Couldn't find it while just looking, but swear I saw someone post that you are supposed to remove the wire once in temp check mode :notsure:
  3. Sep 5, 2018 at 7:18 PM
    #1083
    Jamers99
    Just took it out for a test drive after a full flush with Valvoline MaxLife. Drove about 18 miles. Shifting seemed a little smoother except now it occasionally gets a noticeable shutter around 40-45 mph. Happened 3 times during my 18 mile drive. What the hell? I will double check the fluid level tomorrow to make sure I don't have too much or too little. Tranny was running fine before with 125k miles.
  4. Sep 5, 2018 at 7:42 PM
    #1084
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Put some Lubegard in
  5. Sep 5, 2018 at 8:02 PM
    #1085
    Jamers99
    Should I use Lubegard or Lubegard Platinum? And what size? The 10 oz bottle?
  6. Sep 5, 2018 at 8:32 PM
    #1086
    taco2010trd
    Tampa, Florida
    They have an instant shudder fix. Try that. I put the regular Lubegard in mine.
  7. Sep 6, 2018 at 12:04 AM
    #1087
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Question for those who have a service manual. I read on here that people are pinning the transmission thermostat when doing the flush? If that's better, do you keep it pinned for the fill level check?
    I'm putting on a bigger trans cooler when I do the flush. How do I go about getting all the air out of the system? The long tru-cool radiator instructions state that it can be mounted in any direction. I plan to mount it with ports facing the side, fill at the bottom and return at the top.
  8. Sep 6, 2018 at 4:19 AM
    #1088
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I removed the wire as soon as it went in check mode and it didn’t run a little rough like it does with the wire left in.
  9. Sep 7, 2018 at 10:19 AM
    #1089
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Of all the parts needed, I'm struggling with finding a cheap graduated pail/bucket. Anyone know if Homedepot/Lowes/Autozone/Etc. stock one? Don't want to order an overpriced bucket!
  10. Sep 7, 2018 at 10:31 AM
    #1090
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    I used 2 one gallon milk jugs. Pumped old fluid out into one, placed the other one next to it and filled it with the new atf to the same level. I then filled a quart bottle from that so I could pump it in.
  11. Sep 7, 2018 at 10:52 AM
    #1091
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    https://www.amazon.com/dp/B0118HYDK...olid=33YO0W9ZKB9SA&psc=0&ref_=lv_ov_lig_dp_it
    Not sure what you consider "overpriced", but I'm picking this one up. Or "having delivered" to be more precise.
    Biscuits likes this.
  12. Sep 7, 2018 at 10:52 AM
    #1092
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Some drain pans have marks on them, I already had one that did. But you could make your own with a sharpie.
    gunn_runner[QUOTED] likes this.
  13. Sep 7, 2018 at 11:07 AM
    #1093
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    This is perfect and it’s cheap
    Toy4me[QUOTED] and taco2010trd like this.
  14. Sep 7, 2018 at 11:13 AM
    #1094
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I think $27 is a bit on the high side for a bucket.
    Edit: I just found these 5 gallon translucent buckets with measuring lines for $6.70 each. I will go this route. :)
    https://www.grainger.com/product/43...2125!&ef_id=W5BR5QAAAJcblG3M:20180907181052:s
    Biscuits and sioux[QUOTED] like this.
  15. Sep 7, 2018 at 11:50 AM
    #1095
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I just marked each pint of water adding it to a used washer fluid container and marked each one along the way up. I dumped out the water and began the flush. Cheap!!
    You can see each 1/2 quart graduated mark here if you look closely
    spitdog and taco2010trd like this.
  16. Sep 7, 2018 at 12:22 PM
    #1096
    TheDevilYouLove
    Marylandistan
    IMHO, 5 gal is way too big. If it’s not perfectly level you won’t get good measurements. Remember that you’re dealing with 2-3 quarts at a time. Gallon jugs are perfect. 60 cents each at WalMart with distilled water in them.
  17. Sep 7, 2018 at 12:25 PM
    #1097
    spitdog
    Yep, Its easy to make your own graduated container , It’s common sense to you and I and others. But there is a good percentage that try to do a flush or drain and have no clue on how to measure what they take out or put in. Your simple explanation will help some millennial
  18. Sep 7, 2018 at 12:35 PM
    #1098
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I used a paint measuring thing from Home Depot
  19. Sep 7, 2018 at 12:56 PM
    #1099
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    Ahh, I see. Thanks, I'll use jug method.
  20. Sep 7, 2018 at 4:14 PM
    #1100
    ImpulseRed008
    Susan
    SC
    :anonymous: gotta ask.... why the big deal with tracking what comes out? You have to check the fluid level when done, anyway, right? Mine was well over a quart low, so putting in what I took out wasn't a good option. :notsure:
