DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Sep 7, 2018 at 4:30 PM
    #1101
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Well, because it is kind of expensive, and unless you already know you are low, it's just a waste.
  2. Sep 7, 2018 at 5:14 PM
    #1102
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I wanted to know because I was curious if the factory under filled it. Which they did by 3/4 qt.
  3. Sep 7, 2018 at 5:24 PM
    #1103
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Because you’re taking the old fluid out at the same time you’re adding new fluid. If were like an oil change you could just drain it all out and put the right amount in, but it’s not.
    TenBeers likes this.
  4. Sep 7, 2018 at 8:14 PM
    #1104
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    +1 on all of the reasons above in addition to not allowing the tranny to pump dry when you flush it. Thought I saw something that pumping more than 3 quarts out would increase the chances of having the tranny pump itself dry and do damage. Doing MORE damage while doing maintenance is not the point! :thumbsup:
    spitdog likes this.
  5. Sep 7, 2018 at 10:42 PM
    #1105
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Did the flush today and upgraded the tow package cooler to a tru-cool. Mounted it in the stock location with 2 of the 3 stock mounting points. I added 2 more to secure it and relocated the horns. It was an easy job.
    Trans runs at the normal temp still. Tried to heat it up but it wouldnt go above 158F. Not 100% sure when the trans thermostat fully opens. I think I'll only be able to test it when I am towing. I'll try to answer any questions.
  6. Sep 8, 2018 at 7:42 AM
    #1106
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    It is actually cheaper. Walmart gets $16 for a gal or $5 for a quart btl. there's almost $20 saved there. And you'd have to keep swapping quart bottles anyway refilling one to pump from just takes a few seconds. Then I have the gal jugs to keep dumping the old fluid into for recycling so it worked out well for me.
  7. Sep 9, 2018 at 12:26 PM
    #1107
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Anyone getting P0748 after full flush?
  8. Sep 9, 2018 at 1:16 PM
    #1108
    Wenterkin
    Wenterkin Member
    Wayne
    Enterkin
    2014 Magnetic Gray Metallic Tacoma Limited.
    I just finished this process. Followed the OP’s directions to the letter, except I used my ScanGauge II to monitor transmission oil temperature. Easy job and I had exactly the amount of extra fluid I added drain when checked level. Did the service at 95K on the clock. Mainly because I have no idea how the original owner drove the truck. Old fluid was dark, but still clear and not muddy, so I feel good about the condition of the transmission. Great write up and I figure it saved me >$200, not to mention the piece of mind and satisfaction of performing my own maintenance.
    Toy4me likes this.
  9. Sep 10, 2018 at 7:00 AM
    #1109
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    libagui[QUOTED] and taco2010trd like this.
  10. Sep 10, 2018 at 7:11 AM
    #1110
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Calling @gearcruncher, he seems to be the resident TW transmission expert that I would trust to point me in the right direction.
  11. Sep 12, 2018 at 9:26 AM
    #1111
    gearcruncher
    Canadain bumper technician
    Who did the full flush ?
    That solenoid code identifies the transmission fluid pressure sensor .
    If for some reason , the truck was running and somehow became very low on transmission fluid , PO748 would trigger .
    My first guess is the trans got too low on fluid during the flush or dirty particles from the bottom of the pan accidently managed to travel through the solenoid partially blocking the fluid path .
    Try clearing the code and re-test drive to see if it comes back
  12. Sep 13, 2018 at 10:46 AM
    #1112
    fivefoot
    fivefoot Scarlett, Scarlett Tacoma is the name!
    Temo
    Texas Panhandle
    2012 Tacoma TRD Offroad Barcelona Red
    I too upgraded the stock aux cooler to a single Tru-Cool cooler. I bypassed the inline oil cooler.
    Here is a short video of my setup:
    https://youtu.be/U5w6Wwmahhw
    fla_sun and ktmrdr like this.
  13. Sep 13, 2018 at 10:52 AM
    #1113
    fivefoot
    Temo
    Texas Panhandle
    What year is your truck? My 2012 does not have a thermostat for the transmission. I just followed what the OP wrote and worked out perfectly. Pumped out 11 quarts, put back 13 quarts without any issue.
    Biscuits likes this.
  14. Sep 13, 2018 at 11:11 AM
    #1114
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Which tru cool did you use?
  15. Sep 13, 2018 at 1:12 PM
    #1115
    fivefoot
    Temo
    Texas Panhandle
    It's mentioned in the video. You should watch it, it might help you with your setup. I went with the Tru-Cool 4589 :)
    gunn_runner[QUOTED] likes this.
  16. Sep 13, 2018 at 4:01 PM
    #1116
    Nixinus
    Oregon
    2010 4x4
    I have the exact same cooler setup minus the electric fan. Which fan and controller did you go with?
    fivefoot[QUOTED] likes this.
  17. Sep 13, 2018 at 4:04 PM
    #1117
    fivefoot
    Temo
    Texas Panhandle
    Just a generic aux fan I got on Amazon. It’s a 9” fan. There’s no fan controller. It’s a manual switch on/off when I need to cool the oil, which is rare.
    Nixinus[QUOTED] likes this.
  18. Sep 13, 2018 at 4:09 PM
    #1118
    Nixinus
    Oregon
    2010 4x4
    I have a 2010. I found a couple posts about the thermostat (like post #11 here), but they look to all be 3rd gen. I did the flush twice now, 45k and 85k, without issues by following the same steps. Im guessing it's new for 3rd gen.
  19. Sep 13, 2018 at 4:41 PM
    #1119
    fivefoot
    Temo
    Texas Panhandle
    The TC does produce a lot of heat, but if you upgrade coolers, like I did, the cooler is large enough to keep up with the heat generated by the TC. The large cooler I installed does a great job at keeping the oil cool when the TC is unlocked. I’ve had to use the electric fan a few times but I am thinking about ditching the fan and putting an even larger cooler, the Tru-Cool 4590 because I know that cooler will do a great job without a fan.
    ktmrdr likes this.
  20. Sep 15, 2018 at 7:07 PM
    #1120
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I ordered a Hayden cooler to replace my stock cooler on my 2013 Sport. I'm going to install the cooler and flush the system. I see that the transmission cooler lines first run through the radiator, then to the cooler. I'm assuming that I do not bypass the radiator, right?
