DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Sep 15, 2018 at 7:54 PM
    #1121
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    I don't think you should bypass the radiator. Just make sure to mount it in the correct orientation and replace the lines from the stock cooler to the Hayden.
    Im loving mine so far. I took a 200 mile day trip and never went above 159F with an ambient of 95F at times and plenty of inclines.
    gunn_runner[QUOTED] likes this.
  2. Sep 15, 2018 at 8:19 PM
    #1122
    fivefoot
    fivefoot Scarlett, Scarlett Tacoma is the name!
    Temo
    Texas Panhandle
    2012 Tacoma TRD Offroad Barcelona Red
    It's up to you if you want to bypass the radiator cooler. I did bypass mine. I'm running a single cooler and so far it's been better than the stock inline oil cooler. I went with a tru cool cooler because it has low pressure bypass, where the Hayden doesnt. Low pressure bypass helps with cooler weather. Watch the video I posted earlier about my setup. Should help you answer some questions.
  3. Sep 17, 2018 at 9:42 AM
    #1123
    Jamers99
    Jamers99 Well-Known Member
    2012 Tacoma PreRunner XSP-X
    We know the temp has to be between 115-130 degrees to be in Temp Check mode where the A/T Temp light stays on. It starts to flash if you go over 130 degrees. We know that the A/T fluid expands greatly at hotter temps which is why you don't want to drain any from the overfill plug when the temp is too hot (above 130).
    Technically couldn't you remove the overfill plug immediately after starting the temp check process? I'm not talking about waiting until the A/T Temp light comes on solid either but just when it initially starts to blink as it's warming up from a completely cold start. At that phase you wouldn't expect any fluid to drain out since it's cold and hasn't started to expand yet. Could you remove the overfill plug and just wait until it the A/T Temp light comes on solid and then watch it until it just barely weeps and then re-install the plug?
    Does that sound correct?
  4. Sep 17, 2018 at 9:52 AM
    #1124
    Wenterkin
    Wenterkin Member
    Wayne
    Enterkin
    2014 Magnetic Gray Metallic Tacoma Limited.
    I’m sure this method would work. You’re essentially doing the same thing, just in a different order. Personally, I found it very easy to monitor trans temp until it reached 115 before pulling the plug and draining the excess.
  5. Sep 17, 2018 at 9:58 AM
    #1125
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Why would you even think about altering the procedure? The procedure is simple enough after you practice jumping the wire to the pins and getting it in check mode. I would assume the factory method assures all the fluid is at the correct temp. where your method my not, since it is able too escape during the warm up period.
  6. Sep 17, 2018 at 10:08 AM
    #1126
    Jamers99
    I wouldn't expect any to escape during the warm-up (unless you were greatly overfilled to begin with) since the fluid has expanded yet. Once it expands given the right temp range then it should start to peek over the overfill plug and come out. Isn't this a correct assessment?
  7. Sep 17, 2018 at 10:18 AM
    #1127
    spitdog
    You could be right. But what if it doesn’t heat up evenly?
  8. Sep 17, 2018 at 10:53 AM
    #1128
    Jamers99
    Good point.
  9. Sep 17, 2018 at 12:38 PM
    #1129
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I found that mine took a while to get it to reach temp and was rising slowly. You should have plenty of time to get the check drain plug out. You can leave the fill plug loose, and if it needs more fluid just squirt some in until it starts weeping, then button it up.
  10. Sep 17, 2018 at 5:47 PM
    #1130
    Jamers99
    OK, I'm having a problem getting this into A/T Temp check mode (I think). I follow the steps and get the initial 2 seconds illumination of the A/T Temp light after putting it back into N for the final shift and then when I put it into P the A/T Temp light just comes on solid. This was after a 5 hour cold start. I was getting a IR Gun Pan reading of 95 degrees before even starting it so I don't think the fluid was at Temp yet. I did read post #369 where John says that the A/T Temp light not turning off after shifting back into Park but rather staying lit is a sign of "Overfill". After leaving it it Park for another 5 mins or so the light blinks indicating it's now too hot (over 100 degrees). I have tried the same thing the other day after an overnight cold start and still ended if with the A/T Temp light just staying on solid after put into P (no way it was at temp). While it is possible I maybe put in nearly 1 quart more than I took out I can't be sure since I spilt some and lost track. How would the tranny know it was overfilled on a cold start anyway? Any suggestions?
  11. Sep 17, 2018 at 5:57 PM
    #1131
    spitdog
    So what was the ambient temp. when you used the IR gun?
  12. Sep 17, 2018 at 6:00 PM
    #1132
    Jamers99
    about 85 degrees
  13. Sep 17, 2018 at 6:15 PM
    #1133
    spitdog
    Since the ambient temp. was close to what the IR gun read, you didn’t have to far to go to get to 115 degrees, which is the check mode temp. I think as soon as you saw a solid tranny light, you were good to pull the check screw and let the excess trickle out. When the fluid is warm to start with, It doesn’t take very long. You can always let it sit over night and recheck in the morning when it’s cooler.
  14. Sep 17, 2018 at 6:55 PM
    #1134
    Nixinus
    Oregon
    2010 4x4
    This. I had the same thing happen to me. It took me about 1 minute or so to reach temp after trying to get into temp mode for about 2 minutes with a 90F ambient temperature. I rechecked later on after it cooled down outside and it was correct.
  15. Sep 18, 2018 at 1:52 PM
    #1135
    spitdog
    @james99, So, what happen? Maybe others can learn from your problems.
  16. Oct 13, 2018 at 9:59 AM
    #1136
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Problem was due to low oil level. I end up adding 1-1/2 quarter.
    gearcruncher[QUOTED] likes this.
  17. Oct 13, 2018 at 2:47 PM
    #1137
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Personally I don’t think it’s super important. I guess you could fill it sitting on level ground and then drive it up on ramps to level the pan and see how much the fluid level is off. I doubt there would be much difference. It doesn’t have to be exact, just fairly close.
  18. Oct 23, 2018 at 9:59 AM
    #1138
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Excellent write up. Best I've seen for tranny fluid change
  19. Oct 24, 2018 at 5:36 AM
    #1139
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I’ve been using fusion app to monitor my tranny temps. I’ve noticed the tranny is normally 10 degrees warmer than ambient temp. Also, I’ve noticed that the temp check range on my truck (2010) is 97-115. So if the weather is too warm it’s not practical to check my fluid level.
  20. Nov 25, 2018 at 1:52 PM
    #1140
    TheDevilYouLove
    Marylandistan
    @chris4x4 would it be possible to make this thread sticky? I’ve had to reference it a few times and it has proven difficult for me to quickly locate using search since there’s so many other threads that use relevant search terms. Thanks for considering!
    GonzoQuick and sioux like this.
