DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Oct 15, 2012 at 8:34 PM
    #101
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    Its more noticeable in person, crappy iPhone vid, but the needle is jumping constantly. Only by few rpms, but thats just at idle. When driving, it'll jump up to 2nd gear for a second, then back down, then back to 2nd.
    This is with a constant foot.
  2. Oct 15, 2012 at 9:05 PM
    #102
    TrdSurgie
    TrdSurgie revised
    Oahu
    I think you are confused. Normal for the rpms to jump alittle at idle. And when driving you will only be in 1st for a very short period. Rpms go up as the motor works then drops at shift points then goes back up.
  3. Jan 6, 2013 at 7:12 PM
    #103
    campnowell
    campnowell Member
    Dave
    forest lake mn.
    06 Tacoma TRD SR5 4x4 crewcab
    Outstanding thread!! Just finish'd my 06 w/179,000 miles - almost as dark as used engine oil - Not sure fluid has ever been change :(, just bought her 6 months ago. Wasn't as bad as I thought it - follow'd your procedure and it work'd great.
  4. Jan 6, 2013 at 7:17 PM
    #104
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subd. gonna do it soon
  5. Jan 12, 2013 at 1:38 PM
    #105
    gnarcal
    gnarcal Active Member
    Max
    Washington State
    '09 Tacoma 4x4
    Bilstein 5100's SPC Performance upper control arms Diff drop 1.5° shims Carrier bearing drop 1" AL blocks in rear
  6. Jan 12, 2013 at 6:40 PM
    #106
    staymates788
    staymates788 Well-Known Member
    SEAN
    Anaheim, CA USA
    2005 4x4 Double Cab Long Bed w/ TRD Sport
  7. Feb 18, 2013 at 7:31 PM
    #107
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    damn.. I thought there was only like 3-4 quarts in the tranny... hahaha...
    So basically if you just drain and refill the pan, it doesn't do shit... it just mixes your new fluid in with the dirty fluid.
  8. Mar 14, 2013 at 8:17 AM
    #108
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
    subd great write up
  9. Mar 19, 2013 at 6:54 PM
    #109
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
  10. Apr 7, 2013 at 10:48 PM
    #110
    skygear
    skygear                    
    just quoted 368 from a dealer and 170from another
  11. Apr 9, 2013 at 3:47 PM
    #111
    skygear
    skygear                    
    Are there any other fluids I could get at an Advanced, Auto Zone, or similar? I didn't see the Amsoil or Redline there.
  12. Apr 11, 2013 at 5:17 PM
    #112
    acrossawire
    acrossawire Well-Known Member
    Fresno, CA
    2010 DCSB 4x4 Sport
    Icon Coilovers & AAL
    lots of people on here & BITOG have had good experiences with Valoline Max Life. It's recommended for Toyota WS applications & is way cheaper than toyota's. I have 4 gallons sitting in my garage ready for a full flush. Walmart has the best price i could find. Auto Zone carriers it as well.
  13. Apr 11, 2013 at 6:07 PM
    #113
    skygear
    skygear                    
    Appreciate it. Thats what the guy at advanced recommended,. Plus I have a store credit there.
  14. Apr 16, 2013 at 5:56 AM
    #114
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    I did this last night...started out with 14qts.
    Drained 3, put 3, did this 4 times for 12 qts, then only did 2 for the last bit.
    Got to the end, got ATF up to temp, let truck idle and crawled under while idling. Pulled check plug...hardly any drip come out...WTF...I put back what I took out..Ok now head to autozone for another quart....got 2 quarts to be safe..
    Came home put half a quart....let it temp, idle, and go check...WTF!!!! nothing hardly coming out.
    Put the rest in.....same thing......WTF....still nothing.....WHere is all my fluid going?
    If I turn the truck off with the plug out, it will come flowing out of the plug. So i quickly put the plug in.
    So i dumped the other half and quart in and figured if its over full when I check it will drain out the plug.
    Went through the process again...let it get to solid light AT Temp...let idle and go pull plug while idle....WTFFFFFF!!!! hardly anything coming out while idling.
    Yes I am pulling the right plug...its the one in the middle area of the pan on the passenger side with a hex in the middle. Where is all my damn fluid going? I know it has to be full because more is obviously in there now than what came out. So at 16qts, how is this possible?
    I drove it to work anyway this morning cause I dont have a choice, but I am confused on this. Anyone??
  15. Apr 16, 2013 at 6:04 AM
    #115
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :eek: autozone fluid.. Sorry that's all I got..
  16. Apr 16, 2013 at 6:20 AM
    #116
    gearcruncher
    Canadain bumper technician
    When you turn the truck off , the trans pump doesnt pump allowing fluid to drain back into the pan and is why you get oil running out of the fill hole with the truck turned off . Continue filling until it comes out the fill hole while warm and running in park as explained in the service manual . Sounds like your trans was very low from the start - a common problem with these trucks from the factory .
    I cant beleive Toyota . There should be a filler tube with a level indicator on these transmissions . A sealed unit ? what a joke . What happens when these transmissions leak . Its easy for a leaky trans to go un-noticed for a while and having to check fluid level by going under the truck is simply Toyotas way of hoping owners wont check the fluid .
    Taco-Obsessed likes this.
  17. Apr 16, 2013 at 6:52 AM
    #117
    93civEJ1
    09 DC TRD OR
    No....Valvoline Maxlife suitable for WS.
  18. Apr 16, 2013 at 6:53 AM
    #118
    93civEJ1
    09 DC TRD OR
    The fill hole? HAHA...that is pretty dang full if it comes back out the fill hole.
    You mean the check plug on the pan?
  19. Apr 16, 2013 at 6:56 AM
    #119
    Sandman614
    Tim
    '06 SR5 Off Road
    Keep us updated, I say the debate on it. Toyo WS is too $$$$.
  20. Apr 16, 2013 at 6:59 AM
    #120
    93civEJ1
    09 DC TRD OR
    It could be underfill from the factory...but how is that now possible after I have been through 16qts?
    I drained the 3 from the pan in the beginning. Replaced it with 3.
    Drained 3 more and replaced with 3. Thats 6
    Drained 3 more and Replaced with 3. Thats 9
    Drained 3 more and replace with 3. Thats 12
    Drained around 2 and replaced 2 with Thats 14.
    Then added 2 quarts to get some to come out of the check plug hole..and nothing ever really came out with it idling.
    Im super stumped. Unless it was super low in the beginning.
